equivalent for HT3582DM
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    looking for equivalent or better than HT3582DM . or somewhere i can get one in short time . https://html.alldatasheet.com/html-p.../HT3582DM.html
    • Jul 2011
    • 6040
    Re: equivalent for HT3582DM
    Here is a website link that has a Reverse Engineered Schematics
    https://danyk.cz/reverz30_en.html
    • petehall347
      • Jan 2015
      • 4427
      • United Kingdom
      thanks ..
      i had already seen that and figured mine was same ic . one i have has chinese writing on the ic . it appears to be shorted .i did something silly and blew it up .
      i just need the ic so i can charge my torch batteries .
      another thing i know its badly made but actually worked fine until i blew it up .
        • Jul 2011
        • 6040
        Where did you buy them from can you post a link to them
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          i haven't bought any .. i need to find them yet that can be delivered in short time like a day or even a week . most say around a month or 2 delivery
            • Jul 2011
            • 6040
            Here is an alternative to repairing this unit
            I have used this type of charger and they work pretty good if can find one that is built very good
            https://www.aliexpress.com/item/2251...98515936%21sea
            Here where are you can find them at
            https://www.ebay.com/itm/16545799492...AAAOSwmdFiWNDT
            I was asking where did you buy the flashlight from
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              Estimated between Fri, Jun 10 and Mon, Jun 27
              that charger requires a holder . or add a socket to my one but i suppose a holder is cheaper
                • 31077
                what battery is in your light?
                infact show the light - i suspect i know the type
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  18650 battery . torch is xml-t6 ultrafire ..
                  now we have the unnecessary info out of the way does anyone know where i can get a chip in reasonable time .
                    • 31077
                    no.
                    the reason for the "unnecessary info" is because i was thinking of alternative solutions.
                    i cant find your lamp model,
                    i assume it has a micro barrel connector on it going directly to the battery terminals though.
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      the battery is separate and looks like this .
                        • 31077
                        6800mAh my ass, i'd love to throw that in my Li500 analyser
                        get a decent charger - they arent too expensive.
                        • petehall347
                          • Jan 2015
                          • 4427
                          • United Kingdom
                          been looking for a decent charger and they cost a lot . thinking of getting a tp4056 module for now ..
                          i will let one of the people i work for buy me a nice one along with a bench power supply and battery spot welder . plus anything else needed for rebuilding battery packs properly .
                            • 31077
                            what voltage is in the "charger" ?
                            if it's 5v then you could put a tp4056 inside it
                            • petehall347
                              • Jan 2015
                              • 4427
                              • United Kingdom
                              i thought of buying a holder and module then using a usb charger i already have . costs less than £4 to get my torch batteries charging for now . then go for something big and fancy with digital readouts later on for sorting cells for rebuilding/repairing 80v packs .
                              i am sure i have plenty of components here to build a 4.2v charger circuit with led lights included but cant really be bothered . modules can be had for about £1.50 . it would possibly cost more using parts from my stock .
                                • 31077
                                i can probably send you a module - i think i have some spare.
                                you have the holder already i presume?
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  • United Kingdom
                                  have just ordered a module and holder thanks .
                                  • petehall347
                                    • Jan 2015
                                    • 4427
                                    • United Kingdom
                                    built it up earlier .. rough and ready and working fine . glued to nice lump of aluminium just in case anything gets hot .
                                    • petehall347
                                      • Jan 2015
                                      • 4427
                                      • United Kingdom
                                      quick follow up ..5 chips arrived from china . first one charging at 4.3v . not happy so randomly picked another one 4.12v . i think that's near enough .
                                      • DynaxSC
                                        Extreme High Current & Low Voltage Short Killer ??
                                        by DynaxSC
                                        Hi Folks
                                        I'm looking for a extreme high current short killer solution for a reasonable cost.
                                        I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                        After taking off the socket, the shorts dissappear again.
                                        The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                        10-15-2024, 10:13 AM
                                      • Stephen
                                        MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                        by Stephen
                                        I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                        02-06-2025, 12:03 PM
                                      • Victor Moreira Silva
                                        Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                        by Victor Moreira Silva
                                        I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                        Well, my decice specs are the following:
                                        Model: Acer Nitro 5 AN517-54-55T5
                                        CPU: Intel Core i5-11400H
                                        GPU: NVIDIA GeForce GTX 1650
                                        Motherboard: GH51G LA-L181P Rev:1c
                                        The symptom:
                                        When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                        05-26-2025, 10:49 AM
                                      • aaronkatrini
                                        Help me find the short circuit on this WORKING Nvidia GTX1650
                                        by aaronkatrini
                                        Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                                        Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                                        04-18-2024, 03:15 PM
                                      • Geeker007
                                        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                        by Geeker007
                                        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                        I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                        01-28-2025, 03:31 PM
