Origin Electric PSE-324 Power Supply
  • crtfool
    • Jun 2010
    • 82
    I am looking for a schematic diagram and a component parts list for this power supply. The board that I have has been very poorly repaired by it's previous owner, and it is a mess and still does not work properly.
    Specifically, I need the original values for the following components:
    SMD Resistors R352, R353, R354, R355 - currently installed resistors are 4.7 ohms each and are not SMD
    SMD Resistors R356, R357, R358, R359 - currently installed resistors are 0.47 ohms each and are SMD marked R47
    Transistors Q7 - 2SK2717 and Q6 - 2SK2127
    This power supply comes out of a 32" Sony Plasma TV Model # KE-32TS2U
    Thank you for any info that you can supply.
  • dobber
    • Jul 2008
    • 83
    Re: Origin Electric PSE-324 Power Supply
    Ok Guys, I also now need the same info from above post. I was able to change out the 2 450 volt 230 mfd caps and now have sound, but now need to address the burnt out resistors and transister. This is a real common problem with the old Sony Bravias, but nobody wants to give up the ghost to fix them. Help please, I hate to let things like these get the best of me.
    • dobber
      • Jul 2008
      • 83
      Ok, now I really need to get this going. I just fixed a 47" Vizio for the same customer and he gave me the Sony Plazma for free. I wish it was as east of a fix as the Vizio fuse number 3. Please help guys I would like to get this up and going soon.
      • Toasty
        • Jul 2007
        • 4171
        http://elektrotanya.com/
        Put in the model number. Set the drop downs to ALL and ALL.
        There is a service manual PDF there.
        Toast
        veritas odium parit
        • dobber
          • Jul 2008
          • 83
          Thanks for the site Toast, it is real good. I did download the PDF, and went to the charts on the bottom, and guess what none of these parts are listed. everthing is there exept the info on the power board. I think that Sony is just to worried about injury, and won't give out the info. I guess it is back to pounding the internet. somebody has to have posted a fix out there somewhere.
          • dobber
            • Jul 2008
            • 83
            I hate when sony calls this a OEM part and you have to replace the hole thing. No Scematics for it just replace it.
            • dobber
              • Jul 2008
              • 83
              Ok here is what I do know. R352-R355 go from a Resistor with the marking of (224) and go to a Capacitor marked (2J224 L2N1) and R356-R359 go from a transistor marked (K2717 21) 900V 5A and go to the other leg of the same capacitor.
              • dobber
                • Jul 2008
                • 83
                I think R47 specs are RESISTOR, 2512 R47
                Resistance:0.47ohm
                Resistance Tolerance:± 5%
                Power Rating:1W
                Voltage Rating:3.16V
                Series:RL73
                Temperature Coefficient:± 200ppm/°C
                Resistor Element Material:Thick Film
                Resistor Case Style:2512
                No. of Pins:2
                External Length / Height:6.3mm
                Package / Case:2512
                Temperature Coeff. +:200ppm/°C
                Temperature Coeff. -:200ppm/°C
                Tolerance +:5%
                Tolerance -:5%
                Voltage Rating VDC:3.16V
                External Depth:0.4mm
                External Width:3.1mm
                Full Power Rating Temperature:70°C
                Operating Temperature Max:125°C
                Operating Temperature Range:-55°C to +125°C
                Reel Quantity:4000
                Temperature Operating Min:-55°C
                Termination Type:SMD
                • redmond1501
                  Were you guys able to fix this power supply module? I have the same burnt out R47 resistors and presumably the related transistor too. Any guidance would be appreciated.
