Help identify mosfet 2000w noname power supply
  • Ken123
    • Oct 2021
    • 58
    • Sverige
    Hi.
    Im troubleshooting a 2000w power supply for a mining rig.
    Im looking for replacement mosfets for the 070N080C2 shown in picture attached.
    And also why did they blow? What else should i check?
    Do i need to replace some controller chip also?
    /Ken
  • CapLeaker
    Leaking Member
    • 8352
    Re: Help identify mosfet 2000w noname power supply
    Google 70N80.
    If all 3 pins are shorted look at the gate drive, if there is a low ohm resistor, check it for spec.
    • Ken123
      • Oct 2021
      • 58
      • Sverige
      Ok thnx. I seem to have problems finding some to buy but there is a datasheet and should be able to find a subtitute.
      • Ken123
        • Oct 2021
        • 58
        • Sverige
        Datasheet
        • Ken123
          • Oct 2021
          • 58
          • Sverige
          Datasheet says N-MOSFET 80V, 6.0mΩ, 118A
          Have found 75v 3.3mohm 120A
          Do those work? Do i have to replace all of them?
          • CapLeaker
            Leaking Member
            • 8352
            You should be replacing all of them, unless you are in a pinch. You could cheat and put some different Mosfets in there, but it will change the rating of the inverter. Lower voltage rated isn’t a good idea. Look at HM70N80 at AliExpress…
            Also google “finding mosfet substitute” and read up.
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • Acnologia
              How to diagnose mosfet with lab-supply ?
              by Acnologia
              Hello to everyone ,
              So far most of the repairs that i've been doing was novice, i would say. With a lot of help from you gents.
              Now ,i got in my hands a lab-supply. So , i have a laptop in my hands that doesn't turn on , remains dead , but at the same time there is no short circuit in the main line (as i think off).
              I know that i should put 1v-2v to ground (black wire) and red wire to close the circuit to a specific place after the DC-IN port.
              Now the question is, where do you place it most of the time , i mean in which specific place after the power...
              09-14-2025, 06:35 AM
            • Jane
              How do you test MOSFET in laptops ?
              by Jane
              I tried to use this method:
              Testing an N-channel MOSFET:
              Step 1: Discharge the Gate (turn off the MOSFET)
              Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
              Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
              Step 2: Charge the Gate (turn on the MOSFET)
              Now, place the red probe on the Gate (G) and the black probe on the
              09-27-2024, 03:31 AM
            • zwerw3
              High side mosfet of the power supply of the RTX2060 graphic chip burned out
              by zwerw3
              Hello. They brought a personal computer for repair in which the video card was GeForce RTX ™ 2060 WINDFORCE OC 6G (rev. 1.0). Graphics core power mosfet burned out.
              Is there a chance to restore the site where the mosfet was? I started to grind the mosfet substrate with a dremel, which stuck to the board, but for now I stopped and decided to ask you for advice. I also noticed dark spots on the PCB near the video memory chips. Does this mean that the video memory is out of order? I cleaned the place where there was a burnout, a short circuit of 12 V was removed. On the coils on the power...
              12-12-2022, 12:15 AM
