pinout and voltage for STK5472 IC?
  • Wizard
    • Mar 2008
    • 2296
    I have this in a hifi VCR mitsubishi HS-U82(C). Had bad caps (repaired corroded traces) and blown resistor on the power board itself. Reason I'm trying to revive it is all analog and have S-Video feature that I can output from tuner to a scaler box like DVDO Edge for best results.
    I need to know why this still responds to transport mechanism when I put tape in but no display and no video output or no video pass through.
    Thanks & cheers, Wizard
    • 31304
    Re: pinout and voltage for STK5472 IC?
    display is usually a low voltage AC supply from the transformer - buffered through an electrolytic cap that goes open.
    the loopthrough and output need power to the modulator/mixer unit - forget the stk & look at the outputs from the transformer that go towards the display.
    • Wizard
      • Mar 2008
      • 2296
      It is AC of around 3.4VAC or so on that display heater. And I'm not sure if this design uses AC or DC for heater. There are several designs that do same function that why I need more specific data.
      Please, I need info on this STK5472 and voltages as I have other problems, example I can't get any output when I play the VCR with a tape or OSD on the TV. There was other faults too that why I need more info.
      Cheers, Wizard
      • retiredcaps
        • Apr 2010
        • 9271
        You mean like this?
        http://margo.student.utwente.nl/el/c...RHYBRINDPS_017
        6.11) STK5472 (ECG1883)
        Pin 1: VO3/5.3 V @ 1 A
        Pin 2: Cutoff
        Pin 3: VI2
        Pin 4: VO2/12.0 @ .8 A
        Pin 5: VO1/12.1 @ .8 A
        Pin 6: Vb
        Pin 7: VI1
        Pin 8: GND
        Cheers, Wizard
        --- begin sig file ---
        --- end sig file ---
        • Wizard
          • Mar 2008
          • 2296
          Yes, What does Vb, VI1, VI2 are? That's why full documentation is important. I'm unable to find one in PDF datasheet. Hence request here.
          Cheers, Wizard
            • 31304
            volts-in i suspect.
            3 seperate regulators with a common control pin.
            • Wizard
              • Mar 2008
              • 2296
              Well, I determined this VCR is a total loss, the STR5472 checks out ok.
              Cheers, Wizard
              • ChaoZ
                • Oct 2007
                • 37
                I repaired the psu of a dvd player before. Not as complex but there are couple of rails of power... and the logic board is picky on the voltage range.
                the inductor shorted(yes, puny coils) and it had 5 - 8 bad caps. did the replacement and it begins to work again. i remembered the psu did some odd voltages... 14? 21?
                hope it helps.
                • RetroComputingGrotto
                  IBM LTO 7 Tape Drive - Dust Sensors??
                  by RetroComputingGrotto
                  I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
                  I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
                  09-19-2024, 01:54 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                • UNITRAX
                  Tape recorder Sharp RT 1155 - DC voltage in the VU Meter circuit
                  by UNITRAX
                  I have a faulty right VU meter.
                  At the poles, the DC voltage varies between 0.5 - 1.5 V
                  The indicator does not respond to the ohmmeter at all.
                  I checked
                  transistors Q202, Q203
                  capacitors
                  C230, C231, C412
                  D202 diode.
                  Variable resistor VR 204
                  T 201 coil
                  Anyone have an idea how to get rid of the DC voltage?...
                  05-13-2023, 04:28 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
