Schematic and print lay out EPS 886098
  • Bektronics
    • Apr 2018
    • 11
    • Belgium
    Hello dear friends.
    I found another printed circuit board from the old box. It is an adjustable power supply from the magazine Elektuur (Elektor).
    I only have the number of the circuit board: EPS 886098.
    I would like to build this power supply. Does anyone have the schematic, printed circuit board and parts list from an old Elektor Electronics? I can't find it on the internet. Would be a huge help. May be in pdf form. Thanks in advance. Regards. Bektronics.
    • Jul 2011
    • 6059
    Re: Schematic and print lay out EPS 886098
    Here are the boards that are available now and I do not find this one
    https://www.elektor.com/products/projects/pcb?page=4
    • redwire
      • 3912
      886098 I think is around 1988? Elektor does put a number like that to every picture and PCB. But USA and UK etc. might be different. I could not find a power supply project in 1988.
      Try look here: https://archive.org/search.php?query=%22Elektor%22
      • redwire
        • 3912
        Elektuur is also there: https://archive.org/search.php?query=%22Elektuur%22
        • Davi.p
          Level shifter circuit schematic project request for Samsung TV, please!
          by Davi.p
          Hola... i suspect a faulty circuit on a tcon board, i'm almost newbie on schematic creation, i ' ve made many and many attempts with various Android tablet simul. software but all them fails, not sure if simulation is ok, i need a clock signal level translation from 0-3v to -6-+30v, with those last voltages taken from the board, thank you a lot.. this repair is still since years!
          07-30-2023, 03:39 AM
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • atunguyd
          Acer x163w Monitor PSU schematic
          by atunguyd
          Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
          The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
          03-05-2025, 02:08 PM
        • Tarot Superstars
          Short Circuit tester
          by Tarot Superstars
          Hello.
          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
          Link
          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
          https://www.youtube.com/watch?v=0eixDdCpiO4
          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
          09-25-2023, 09:11 AM
        • macabook
          A2442 TOUCHID NOT WORKING
          by macabook
          I have an issue with a Mac A2442 , that had initially a short circuit on Q5800 after replacement it turn on without any other issue, only finger print not working. I follower the post " MacBook Pro M1 2021 A2442 Touch ID stopped working" by measuring in diode mode all SPI seems ok, but when checking for voltage i notice something strange regarding PP1V2_S2.
          The chips UT620, UT520, UT540 are powered by PP1V2_S2 (according schematic and board view), this voltage is missing, and when I check continuity with PP1V2_S2 rail, found that it is not connected to it. Compared on another...
          04-13-2025, 10:28 AM
