AXP AXP-500P12P 3.3V line issue
  • zunasthegreat
    • Dec 2017
    • 82
    • EU
    Hello all
    I have this PSU from a friend, it has very high 3.3V line output (3.55-3.6V) on the DMM that makes most boards buzzer beep and shut off. Once a while on some old P4 board (P5PL2) it run fine for a bit with voltage hitting ~3.4V. It started doing it after like 2h of usage.
    The original caps had TUL CE branding without any other info, 2200uf 10V for 3.3V+5V. All caps are near ~3000uf with very high vloss so I swapped them with GP caps and on the 2nd round with some KY/PW, no change in high 3.3V with any cap setup. It was there with the originals too.
    The 5Vsb and +12V are both fine and I use some KY/PW there as well. Nothing seems odd but I went ahead and changed the Mospec S20C40C with a SBL2040CT, voltage on dmm starts at 3.35V and quickly drops to 3V while I clip running it with just dvd and some fans. Anyone having some suggestion on how the 3.3V is so crappy ?
  • zunasthegreat
    • Dec 2017
    • 82
    • EU
    Re: AXP AXP-500P12P 3.3V line issue
    Update: After some playing with the load resistor for 3.3V (50ohm) the psu worked for like ~1h on the same P5PL2 with very stable 3.3V line @ ~3.4V but at some point it switch off. The mainboard standby led is still on and the 5VSB looks fine at 5.05V, the PSU does the same 1-2sec fan spin and will switch off. It will do it on any board run for 1-2sec and then switch off. I even re-installed the old S20C40C but that made no difference. Primary caps Transistors etc look fine.
    • zunasthegreat
      • Dec 2017
      • 82
      • EU
      The fix was either the TL431 or the 2SA1015 transistor, replaced one more zener nearby that seemed dodgy and PSU works fine again.
      • zombie.guitarist
        Synthaxe Midi Controller footswitch
        by zombie.guitarist
        Hey all! I have this midi controller called a "Synthaxe" which is pretty rare. It was made around 1986 and the company only made about 100. I was told less than 25 still work today. Theres a guitar player I love that is known for using this and to play his material you basically need one of them because it does things no other midi-guitar controller can do. So since I got it, ive been trying to learn about it so I can extend its live as long as possible.
        The one that I bought has 2 issues. One I'll cover another time but I think this one is easier and simpler to fix....
        06-25-2023, 12:06 PM
      • Technomancer
        Nintendo 2DS SD Card Reader issue. Problem on the clock line?
        by Technomancer
        I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
        Here is what I have done so far:
        -Tried SD card in another 2DS and on PC, works great.
        -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
        -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
        06-07-2022, 09:01 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • feliks912
        ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
        by feliks912
        Attached schematic 🙂.
        Laptop gives no signs of life. No fan and no CPU heat.
        Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
        Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
        Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
        What do you guys think happened? I've got two theories:
        If the...
        I think ThinkEngine shorted first
        50.00%
        1
        I think 5V SMIC shorted first
        0%
        0
        I think something else happened
        50.00%
        1
        05-07-2024, 04:44 PM
      • Raygen
        No VCC to bios chip - Huawei Matebook d15 DAH98AMBAD0 REV:D HF Model H98A H898A
        by Raygen
        Hello, I received to repair this Huawei laptop (model in the title).
        The laptop will charge the battery fine throught the USB C port, but it wont turn on. The charging led will blink fast and repeatedly when trying to turn it on.
        I've attached photos of the board. (the wires are for briging the power button, I did not inject voltage)
        Upon visual inspection, a couple of ICs were blown. Along the 5V line leading to one of the USB A ports. They wasnt fully shorted but just a couple of ohms to ground.
        I replaced the blown IC on the board (the one circled in red,...
        09-23-2024, 04:21 PM
