AXP AXP-500P12P 3.3V line issue
  • zunasthegreat
    • Dec 2017
    • 92
    • EU
    Hello all
    I have this PSU from a friend, it has very high 3.3V line output (3.55-3.6V) on the DMM that makes most boards buzzer beep and shut off. Once a while on some old P4 board (P5PL2) it run fine for a bit with voltage hitting ~3.4V. It started doing it after like 2h of usage.
    The original caps had TUL CE branding without any other info, 2200uf 10V for 3.3V+5V. All caps are near ~3000uf with very high vloss so I swapped them with GP caps and on the 2nd round with some KY/PW, no change in high 3.3V with any cap setup. It was there with the originals too.
    The 5Vsb and +12V are both fine and I use some KY/PW there as well. Nothing seems odd but I went ahead and changed the Mospec S20C40C with a SBL2040CT, voltage on dmm starts at 3.35V and quickly drops to 3V while I clip running it with just dvd and some fans. Anyone having some suggestion on how the 3.3V is so crappy ?
  • zunasthegreat
    • Dec 2017
    • 92
    • EU
    Re: AXP AXP-500P12P 3.3V line issue
    Update: After some playing with the load resistor for 3.3V (50ohm) the psu worked for like ~1h on the same P5PL2 with very stable 3.3V line @ ~3.4V but at some point it switch off. The mainboard standby led is still on and the 5VSB looks fine at 5.05V, the PSU does the same 1-2sec fan spin and will switch off. It will do it on any board run for 1-2sec and then switch off. I even re-installed the old S20C40C but that made no difference. Primary caps Transistors etc look fine.
    • zunasthegreat
      • Dec 2017
      • 92
      • EU
      The fix was either the TL431 or the 2SA1015 transistor, replaced one more zener nearby that seemed dodgy and PSU works fine again.
      • zombie.guitarist
        Synthaxe Midi Controller footswitch
        by zombie.guitarist
        Hey all! I have this midi controller called a "Synthaxe" which is pretty rare. It was made around 1986 and the company only made about 100. I was told less than 25 still work today. Theres a guitar player I love that is known for using this and to play his material you basically need one of them because it does things no other midi-guitar controller can do. So since I got it, ive been trying to learn about it so I can extend its live as long as possible.
        The one that I bought has 2 issues. One I'll cover another time but I think this one is easier and simpler to fix....
        06-25-2023, 12:06 PM
      • Twiesel
        MSI X470 GAMING PRO CARBON (7B78) USB Overcurrent
        by Twiesel
        I am currently working on a MSI X470 Gaming Pro Carbon that has a weird issue: The board is working fine on startup, but after the BIOS initializes, the board shows "USB overcurrent detected" on the screen and shuts down after 15 seconds. The issue is only happening when the system is ready to boot.
        What I have tried so far:
        -optical inspection: no damages whatsoever
        -BIOS update: The BIOS was updated to the latest stable version (I) using the CH341 1V8
        -PM_OC: I checked every double mosfet (7002N) that is connected to that line. All the PM_OC-signals are...
        09-02-2025, 10:40 AM
      • DqMagetz
        Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
        by DqMagetz
        Good day!
        I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
        Here are the voltage readings:
        • Input – 19V (stable)
        • +LCDVDD – 3.3V briefly, then drops to 0V
        • EDP_HPD – 3.3V briefly, then drops to 0V
        • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
        • EC BKOFF# – 1.8V briefly, then drops to 0V
        • PANEL_OD_EN – 0.3V
        Is it possible that the EC chip is corrupted or damag...
        07-12-2025, 09:37 PM
      • Technomancer
        Nintendo 2DS SD Card Reader issue. Problem on the clock line?
        by Technomancer
        I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
        Here is what I have done so far:
        -Tried SD card in another 2DS and on PC, works great.
        -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
        -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
        06-07-2022, 09:01 PM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
