Sonos Playbar Psu Issue
  • dobrykamil
    • Jun 2013
    • 63
    Hi
    I'm trying to fix my sonos playbar which I bough as faulty because It wouldn't turn on. This is a second unit with exactly the same no power problem due to short in bridge rectifier. I've replaced faulty part + the fuse and psu is working but with some issues. Output voltage without any load fluctuating between +15-16V but under a load it drops to +8-9V (default output should be around +15V)
    Pwm IC is FAN6300. I've also noticed that voltage on pin 6 VDD also fluctuating between 9 and 14V. So far I've replaced 3 x 1000uF in the output stage, pwm chip, 2 x 100uF/400V and 100uF cap directly connected to pin 6. There is no short in the output side. I've checked all smd resistors and they seem to be ok.
    I haven't checked all smd caps around pwm IC. Has anyone seen this problem before or have any ideas?
    • 22135
    Re: Sonos Playbar Psu Issue
    model number ?
    • dobrykamil
      • Jun 2013
      • 63
      Originally posted by SMDFlea
      model number ?
      No sure what do you mean by model number. There is only one playbar in the Sonos speaker family.
      • dobrykamil
        • Jun 2013
        • 63
        Problem solved, there was an issue with the person how was trying to fix it not the psu.
        • bosscharles
          • Mar 2013
          • 83
          Hi @dobrykamil what solved your issue? I've got my hands on a PlayBar that had a dodgy power supply. I fixed the PSU as far as I can tell. Symptoms as follows, PlayBar powers up and is detected by the app however there is are no lights and there is no sound. What are the output voltages that should be generated by the PSU? I have 4 rails outputting close to 16V each.
            • Jul 2011
            • 6070
            Is there a micro controller on this device
            • beetle1303
              Wine Chiller - SMPS issue - fluctuating voltages
              by beetle1303
              My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
              Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
              Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
              Checking further on the primary side: Incoming line input to bridge...
              09-04-2023, 10:33 AM
            • rotorrocket
              Sonos Playbar No Power (again) after successful repair
              by rotorrocket
              My Sonos Playbar wouldn't power on, a typical power board issue.
              I tested the rectifier and the MOSFET with a multimeter. I had to desoldered the MOSFET to ensure I got an accurate reading and it tested good. Used fresh thermal paste for the heatsink and resoldered it to the board. The rectifier tested good on board and wasn't removed.
              I replaced the two 400v 100uF capacitors that looked suspect and know to fail. The ESR meter table doesn't have a 400v capacitor listed so I just replaced both with the same. The smaller capacitors tested good with an ESR meter on board....
              03-16-2023, 07:58 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
              by ugamazing
              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
              12-17-2024, 07:05 PM
            • shahnld
              Lenovo legion 5 pro startup issue
              by shahnld
              Good day Experts
              I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
              A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
              And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
              08-24-2025, 12:31 PM
