Does anyone have the schematic of a Tagan BZ700 PSU?
  • Pimpom
    • Mar 2018
    • 9
    • India
    Does anyone happen to have a circuit diagram (schematic) of a Tagan BZ700 PSU that they can share? I searched but had no luck.
    One of two MOSFETs in the PFC circuit blew about 5 years ago. Not having the exact type, I replaced both with a similar type and it's been running fine, 10-16 hours a day every day, until one blew again last month. On both occasions, the transistor blew when there was a severe power fluctuation and the UPS kicked in and out in rapid succession.
    The first time it happened, the PSU simply became inoperative. This time it took out the fuse in my UPS along with it. I replaced the transistors again but the PSU stays dead (but no longer shorted).
    If this had happened 20 years ago, I'd have simply traced the circuit and drawn the diagram, but my eyes aren't up to it anymore and, frankly, I've become lazier with age (I'll be 70 in a few months). You know how congested PSU PCBs are. Can anyone please help?
    • 31246
    Re: Does anyone have the schematic of a Tagan BZ700 PSU?
    5 years for PFC is pretty good - i'd say your transistor choice was o.k.
    your primary capacitor is probably trashed though - PFC kills them and the fact that it couldnt smooth over the transition to the ups is a givaway.
    check the pfc diode too.
    • Pimpom
      • Mar 2018
      • 9
      • India
      Thanks for the reply. I'll check the main cap, but I'd really like to dig deeper into the circuit. I'm a pro - semi-retired now - in electronics and not wanting to trash this PSU isn't just a matter of money.
        • 31246
        get datasheets for any chips you see.
        they often have example schematics that match the board.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          There have been reports of APFC circuits blowing up with the square wave that the majority of cheap line inyeractive UPS units generate
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • Tarot Superstars
            Short Circuit tester
            by Tarot Superstars
            Hello.
            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
            Link
            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
            https://www.youtube.com/watch?v=0eixDdCpiO4
            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
            09-25-2023, 09:11 AM
          • Alimash
            op amp circuit function?
            by Alimash
            I am repairing a ups which doesn't turn on ,it has the following ICs:
            SG3525 used to drive inverter mosfets.
            couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
            A LM358 and TL074 for control mechanism and of course the uController.
            The SG3525 is shutting down every time the ups is turned on.
            I want your help to know the function of LM358 and TL074 in the system.
            I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
            07-31-2025, 07:45 AM
          • M1NEBLANK SHOW
            MSI B250 Gaming M3 Short circuit in CPU power supply circuit
            by M1NEBLANK SHOW
            Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
            (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
            Schematic and Boardview here
            04-04-2025, 03:57 PM
          • chth96
            Is ESR value different between on Circuit and off Circuit?
            by chth96
            A few days ago, I purchased MESR-100 ESR meter, and When I measured a SMD capacitor on circuit,MESR-100 showed ESR value of 30, But I managed to desolder this SMD capacitor from circuit and measured it then MESR-100 showed ESR value of 18.
            I also measured it with Mega328 Transistor Tester, and It showed ESR value of 17.
            Is my MESR-100 defective, if the ESR value is different between on Circuit and off Circuit?
            11-19-2022, 04:32 AM
