Is ESR value different between on Circuit and off Circuit?
  • chth96
    • Nov 2022
    • 116
    • indonesia
    A few days ago, I purchased MESR-100 ESR meter, and When I measured a SMD capacitor on circuit,MESR-100 showed ESR value of 30, But I managed to desolder this SMD capacitor from circuit and measured it then MESR-100 showed ESR value of 18.
    I also measured it with Mega328 Transistor Tester, and It showed ESR value of 17.
    Is my MESR-100 defective, if the ESR value is different between on Circuit and off Circuit?
  • Per Hansson
    • Jul 2005
    • 5894
    • Sweden
    Re: Is ESR value different between on Circuit and off Circuit?
    There are several things to keep in mind when measuring capacitors in circuit:
    If there are two capacitors in parallel you will have no idea if one of them is bad.
    If there are resistors in parallel this will show an artificial high reading.
    If there are really sensitive semiconductors in parallel these could in theory be switched on by the low testing voltage and affect the reading.
    Another thing to keep in mind is that ESR is highly temperature defendant (just refer to the datasheets).
    So when you desolder a capacitor you heat it up: this gives it a much better ESR value until it has had time to cool down internally.
    And if you heat it up allot you can even boil the electrolyte which could have both bad and good results depending on pure chance.
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • Tarot Superstars
      trying to fix a 6V 0.5A T1 (Transformer) AD050120T2 power supply
      by Tarot Superstars
      Hi. I am trying to fix a 6V 5A power supply that would was used a lot.
      I want to fix it partly for learning, and part because I don't want to buy a new one.
      It has distinctive smell of burning but not seen obvious burned components yet. I'm not sure where the fuse is.
      I tested the only slightly bulged capactitor (out of circuit) and it measured normal capacitance and ESR.
      Everything else was tested in circuit with a multimeter.
      In circuit tests
      I tested the large diodes underside and they seem fine.
      I tested...
      08-14-2023, 12:45 PM
    • Tarot Superstars
      Short Circuit tester
      by Tarot Superstars
      Hello.
      I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
      The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
      Link
      The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
      https://www.youtube.com/watch?v=0eixDdCpiO4
      My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
      09-25-2023, 09:11 AM
    • M1NEBLANK SHOW
      MSI B250 Gaming M3 Short circuit in CPU power supply circuit
      by M1NEBLANK SHOW
      Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
      (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
      Schematic and Boardview here
      04-04-2025, 03:57 PM
    • прямо
      Viper22A 5VSB circuit
      by прямо
      So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
      In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
      01-13-2024, 07:05 PM
