Help identifying caps needed for recap
  • digge
    • Apr 2006
    • 296
    First of all sorry if this is the wrong part of forum but didn't know quite where to put it, since its not exactly a psu for a computer or similar but rather the power end of a microcontroller.
    So here is my dilemma, i have this circuit board for an oven that semi works when it wants to. I tracked it down to that when it doesnt work i dont get any voltage from the mosfet so i thought i replace the critical parts of voltage area meaning the 2 caps, rectifier and mosfet. I can clearly see the rectifier has been very warm.
    Ive tracked down replacements for the rectifier and mosfet but since I'm not very good at electronic design I'm not sure what to replace the caps with, are they low esr caps or would just about any cap work?
    The caps are Nitsuko brand, ill list everything on them that i could read from them and hope you can help me with it
    Nitsuko
    35V
    1000uF (M)
    CE04W
    MR(E) 105degrees
    N222
    And here is some pics if that helps
  • Toasty
    • Jul 2007
    • 4171
    Re: Help identifying caps needed for recap
    >>i dont get any voltage from the mosfet<<
    What MOSFET? You are showing a voltage regulator there. 5v
    The rectifier -looks- fine.
    This is a linear power supply. A cap replacement type is not as critical. Actually, they are probably fine. I think your problem lies elsewhere.
    veritas odium parit
    • digge
      • Apr 2006
      • 296
      sorry i meant voltage regulator not mosfet, made a slip in my head while translating there and the rectifier might look good in the pic due to bad pic quality, but it has actually been so hot its partially desoldered and is not seated flat on the pcb anymore, and it also has a brownish tone to it.
      think replacing the rectifier and regulator would be enough? reason i wanted to replace the caps as well was that i thought they might short the circuit since i get no voltage from the regulator sometimes. Usually if i power it up from being unpowered for a while it works for 5 mins an then dies, so seems that heat has something to do with it. if i cycle the power it might come on but stay on for shorter time.
      • Toasty
        • Jul 2007
        • 4171
        Does the regulator get hot also? I'm thinking more of an overload in whatever it is supplying than a failed component here. The rectifier gets hot because there is an overload on the regulator. The regulator is thermally protected and that is probably why the voltage output shuts off.
        Rectifier is capable of 1.5A / 200v
        Regulator is capable of 1A max of 10v input
        A bench supply would be of use here to test the output and determine the load. You could also break the connection on the output and use your VOM/DMM on current setting to see what the load draw is.
        Being a linear supply, a low ESR cap is not critical here. But the price difference being negligible for 2 caps, I'd likely go with Panasonic FM's.
        Check downstream components for an overload or failure.
        Toast
        veritas odium parit
          • 31304
          tou need to look at all those yellow translucent caps.
          if any have cracks replace them.
          or they will burn-up soon.
          (moisture gets into them)
          • digge
            • Apr 2006
            • 296
            Swapped the rectifier, voltage regulator and the two electrolytics and now the board seems to work.
            The yellow caps are not part of the voltage circuit to the microcontroller and stuff, they go to some relays on the side of the board (barely seen on left side of first pic), even though they have tiny cracks on them i think they will be fine for now since its only on the surface.
            Not sure what of the things i replaced that was to blame, cant measure the caps since i couldn't find a meter that would measure as high as 1000uF, so i guess ill have to just be happy it works for now Thanks a lot for your thoughts on this.
            • trepachka
              Help identifying a chip for Lenovo Slim 7 16IAH7 - schematics needed
              by trepachka
              I have this Lenovo Slim 7 16IAH7 notebook that is not booting properly. All voltages are there: 5v, 3.3v, 1.8v but it's still a no-go.
              I spotted this IC chip with markings "6611c" on it. The coil near this chip measures around 200 Ohms which I think is too low. But without the schematics, it's just a guess.
              I wonder if someone has the schematics for this board or perhaps, can help me identify this particular ship. Thanks....
              08-08-2025, 02:04 AM
            • sofles
              Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
              by sofles
              Hi there,
              Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
              With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
              05-30-2025, 01:11 PM
            • bohaboha
              Help Identifying a component and advices needed
              by bohaboha
              Advice on this: VPMS2GMB I found some but they don't have the same indications on the chipset
              Does it have to be exactly the same or is it enough that it is a VPMS2GMB
              Identification: this Ic Q80B-104HIP when I search with Q80B-104HIP I get results for :EN25Q80B-104HIP as you can see the first characters are not in the picture is :EN25Q80B-104HIP the right one ?
              the last mentioned are from a samsung mainboard BN41-02751B-000
              Now the last one ic from USB AMCAP DIGITAL MICROSCOPE is blown but you can almost see many signs but not all of them if you can assist with some identification...
              02-20-2025, 03:43 PM
            • fl0w
              GeForce 6800GT recap, need help identifying caps and finding replacements
              by fl0w
              I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
              But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
              I need to replace:
              • 2x 2.5V 1500µF => I plan to use this
              • 2x 16V 330µF=> I plan to use this
              • 1x 6.3V 680µF=> I plan to use this
              Am I correct with the cap choices?
              Thanks for...
              10-02-2024, 11:28 AM
            • MyBrainIsAStrainer
              Quicko T12-955 Repair (Board Rev 3.3): Help identifying components needed
              by MyBrainIsAStrainer
              Hello! I'm newbie-ish in electronics and hope you can help me.
              I use a Quicko (or Quecoo, not sure which is correct) T12-955 soldering station as my daily driver. Recently, I had a mishap. While changing tips, the metal contact inside the handle got bent and must have shorted against some other contact. Since then, the station only shows "Error" on its display. I fixed the bent contact but the error didn't go away. In fact, now it's completely dead.
              After opening it, I found obvious two faults: A chip that looked molten (U5), and another chip which got very...
              06-17-2023, 10:59 AM
