LG nb3530a Zener Diode Identification
  • mikay786
    • Aug 2014
    • 765
    Ive got a shorted zener diode on a power board for a sub but struggling to make sense of the markings to identify a replacement.
    From what i can make out says 33B5T
    This is what a google brings up
    https://datasheetspdf.com/pdf/102878...ents/MZC33B5/1
    Was looking at this as a replacement 3.3v Is this suitable?
    https://www.ebay.co.uk/itm/161636082...Cclp%3A2334524
  • R_J
    • 9551
    Re: Zener Diode Identification
    What Make & Model sub? it could be a 33v zener (33BST)
    • mikay786
      • Aug 2014
      • 765
      It’s just a wireless sub part of a LG sound bar setup
      LG nb3530a
      Actually found another shorted zener directly after a octocupler from the primary to secondary side.
      I’ll get some board pics up shortly
      And yes the 5 could be a S, so 33BST
      I’ve just bought a kit of Amazon which includes loads of values
      • CrimsonKyber96
        • Aug 2021
        • United Kingdom
        I have the same problem and I stumbled upon this thread.
        Did you manage to solve your problem? If so what value zener diodes did you use as replacements?
        I have two shorted zeners on the output of the optocoupler. One zener diode on the feedback pin and one on VCC. The feedback pin has a max rating of 5V and VCC has a max rating of 25V. Wouldn't this mean 33V zeners are unsuitable?
          • 31063
          Originally posted by mikay786
          I've just bought a kit of Amazon which includes loads of values
          like mine?
          https://www.aliexpress.com/item/1005001780550855.html
            • 31063
            why not read the print on the shorted ones?
            • CrimsonKyber96
              • Aug 2021
              • United Kingdom
              The print reads 33B5T and I can't find any information regarding the values online. I've been searching for the past few hours for a data sheet that looks something like but I've had no luck.
              • lotas
                • Jan 2016
                • 4621
                • Russia
                Rather, a regular 33v zener diode (stands in the role of power protection).
                • lotas
                  • Jan 2016
                  • 4621
                  • Russia
                  Re: LG nb3530a Zener Diode Identification
                  found a circuit for the power supply:
                  ZD901 - 33V
                  ZD902 - 22V
                  ZD906 - 10V
                  ZD908 - 5.1V
                  • radio-ged
                    • Jan 2022
                    • United Kingdom
                    Very helpful info - thank you.
                    • dkneyle
                      • Dec 2013
                      • 441
                      yep, standard design appears to be to use a 33v zener in that position
                      • unimatrix93
                        TV backlight zener diode
                        by unimatrix93
                        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                        The led strips has 9 6V leds.
                        02-10-2025, 12:13 PM
                        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                        by sam_sam_sam
                        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                        I bought this from an eBay seller but unfortunately they only had one
                        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                        I bought three of from them to also make battery packs with this output power limit in mind
                        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                        04-23-2025, 05:50 AM
                      • nev1001
                        What zener diode might fix the sound on Maestro Mayhem gaming chair?
                        by nev1001
                        Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                        The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                        It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                        I think an issue could be a zener diode (or capacitor) which has shorted out.
                        The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                        04-17-2025, 05:09 PM
                      • Vincenzo2
                        Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                        by Vincenzo2
                        My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                        Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                        I put some pictures here to show that it is labeled "M7"....
                        09-07-2023, 07:43 PM
                      • chth96
                        Is there any Diode Replacement for MPG06J?
                        by chth96
                        is there any replacement for MPG06J diode?
                        https://www.vishay.com/docs/88682/mpg06.pdf
                        It is very hard to find this MPG06J diode in my place.
                        I think that replacement should have the same ratings with MPG06J, But it is impossible for me to hunt down replacement for MPG06J diode.
                        Any reply would be appreciated.
                        03-01-2024, 07:07 AM
