Antec EA-430D 5VSB issue
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Antec EA-430D 5VSB issue
    Originally posted by stj
    maybe it should have something faster in parallel - like a polyester brick.
    You have a way with words! Maybe polypropylene? I'm pretty sure I've seen film caps in parallel with the big lytics in some PSUs.
    PeteS in CA
      • 31259
      they are lego bricks filled with metalised polyester - the description was valid
      • Rgyver2
        • May 2012
        • 17
        Just wanted to give an update to let everyone know that the power supply is now fixed.
        Ultimately the main issue was the main 450V ( 270uf Aishi) cap. I replaced it with a Rubicon MXK 450V 390uf. And i replaced the TNY278 IC ( blown due to bad main cap). Now the 5VSB works and the power supply runs without issue.
        Thanks again for everyone's helpful comments and insight. I learned a lot and now have a deeper understanding of how it works. And would not got this far without the help to theorize and understand what was happening.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Awesome! Great to hear your PSU is working again!
          And that Ruby 450V/390u should provide much better hold up time (from the larger capacity) in addition to lasting longer, as it should be capable of higher ripple current.
          I've only seen ceramics. But even those will help!
          That said, I did put film P.P. caps (2.2 uF, 450V) in a few PSUs with APFC that I've repaired. Not sure if that will help and for how long (as these PSUs haven't been put back to permanent use again, yet.) Hopefully, we will see... or not?
          *Ahen* I believe LEGO bricks are made of ABS plastic.
          (Sorry, but as a former "Lego nerd", I had to include this correction here. )
          Also, polypropylene might be a better choice than polyester, as the former usually has more consistent specs/characteristics over a much wider range of frequencies.
          Originally posted by ChaosLegionnaire
          if not, i'd be shitting in my pants everytime i powered on a system with an apfc psu!
          In all honesty, I always hesitate to press the power button on my PCs that have PSUs with APFC (especially the ones that still have cheap caps or just 400V caps) - just kind of anticipating a big bang some day.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
          • ahmarzo
            Acer laptop battery draining issue
            by ahmarzo
            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
            08-02-2025, 06:39 AM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
