cooler master rs-750 load problem
  • Guilty_2121
    • Jan 2021
    • 43
    • Türkiye
    my power supply shuts off under load, starts with out problem, the i tried to play game or benchmark, pc shuts off. I check the caps they looks good and looks like no weak solder. what shout i suspect?
    model: cooler master rs-750-amaa-b1
    • 31151
    Re: cooler master rs-750 load problem
    caps still - they need to be removed and metered with an esr meter
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Can you post some pictures here of the internals of the power supply? That way we can see what you have.
      Also, did you try your PC with another PSU and confirm the system can stay turned On under heavy load? Just asking to make sure we are not troubleshooting an issue that may not exist (i.e. possibly having the system be faulty and not the PSU.)
      • Guilty_2121
        • Jan 2021
        • 43
        • Türkiye
        Yes, i take my friends 600w and try for 3 days and everything is good on PC.
        back side is looks ok. no weak solder.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Ok, good to know. So it likely is the PSU, then.
          Based on the pictures you provided, I see a lot of CapXon capacitors. Generally, CapXon does show signs when it goes bad (bulging, leaking, and etc.) But because it's a very crappy brand, it really is hard to know if any of those caps are actually good or not without pulling them out of the PSU and measuring them with an ESR meter. If you have an ESR meter (one of those cheap GM328 multi-function testers will do - they cost about $15) or if you have a friend / know a repair shop that has one, then it would be best to remove each cap and test it. Capacitance should be within +/-20% of what is printed on each cap. And ESR should be less than 0.1 Ohms for most of the caps (the really small 5x11 caps may show up to 2-3 Ohms, which isn't considered terrible.)
          Again, because none of the caps look bad, my suggestion would be to start with the small ones seen in this picture, as they are most prone to drying out and not showing visible signs of failure when they do go bad:
          https://www.badcaps.net/forum/attach...5&d=1618137991
          If they test OK, remove and test the two big caps shown here:
          https://www.badcaps.net/forum/attach...3&d=1618137991
          And if those test OK, then check the rest of the secondary-side electrolytic caps, which can be seen here:
          https://www.badcaps.net/forum/attach...7&d=1618137991
          Also, post a clear-focused picture of the under-side of the PSU, if possible. I would like to see if anyone of us can spot anything on there that perhaps may have gotten overlooked.
          • Guilty_2121
            • Jan 2021
            • 43
            • Türkiye
            At first thank you so much master. And here is the pictures you want.
            I like to fix my thing and i can spend several hours on try. But this is a little hard for me but i will try my best and tell the what happen
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Well, just to say here that I'm battling the same (or very very similar issue) with a Rosewill Valens 600 PSU. The PSU itself is quite different from this one, but it's doing something similar: it will turn On and run fine without a load (or with a very very light load, like an HDD or two) with all voltages in spec. But the moment I try to run any motherboard with it or heavier load, it turns Off. So if I find anything that might be related, I'll report back too. I haven't had a chance to check the caps yet, but I suspect that the issue might be either a small "startup/run" cap somewhere gone bad or perhaps the APFC / main input filter cap gone/going bad.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                I would bet the main APFC cap has lost most of its capacitance
                • Guilty_2121
                  • Jan 2021
                  • 43
                  • Türkiye
                  I don't know which one you are pointing but i change the all caps in the middle area(nearly 6) and problem fixed. And I change the output area too. Only 2 big ones left(2 caps with 400V).
                    • 31151
                    he's talking about the mains side caps
                    • stomanata
                      Problem with PSU Cooler Master MPX-5501-AMAAB
                      by stomanata
                      Happy new year.
                      This PSU use WT7527V supervisor.
                      On purple cable i have 5V, but on #4 of WT7527V i have 0.21V.
                      If i try to start PSU with short between green and black it star for a second and stop.
                      For what other to check? I now that is needed more info but i don`t know what else to share
                      01-07-2024, 11:48 AM
                    • bimole
                      Weird behavior on 3.3V rail of a CORSAIR CX600
                      by bimole
                      A colleague gave me an apparently ill CORSAIR CX600.
                      He told me that he heard a banging noise, and smelt the magic smoke.
                      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                      It's another story on the 3.3V rail...
                      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                      02-13-2025, 04:49 AM
                    • Topcat
                      Cooler Master ATC-S + Some other CoolerMaster Case - 2-fer in 1 Thread
                      by Topcat
                      This is a Coolermaster case double-header.... The reason this one didn't get added to my 'misc build' thread is becasue the Cooler Master ATC-S aluminum case....That case is a class-act way above & beyond anything in that thread! However, we have to get through a mediocre build to get to the treasure!
                      ...but here's the two Cooler Master cases in question; both of which were drop-offs for recycling.... The one on the left, I'm not really sure what model it is. It's nothing overly special, but it is well-made. The one on the right is an ATC-S solid aluminum, best I can determine...
                      03-12-2022, 10:58 PM
                    • AJ847.63e
                      Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                      by AJ847.63e
                      Hi Folks,
                      Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                      I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                      The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                      05-06-2025, 10:37 PM
                    • Gjackson
                      ADP-160FR ps4 slim PSU, shuts down under load and has severe coil whine.
                      by Gjackson
                      Hi all, the PSU originally had a no 12v issue where as soon as I bridged the 5v standby to the ACDC_stby the psu would switch itself off completely. I monitored the voltage on the main filter caps while doing this and saw that the PFC was bringing the voltage up to around 360vdc before shutting down. Given that I saw that as a little low I replaced the PFC feedback resistors from a donor PSU and that got it to power on, without a load no coil whine is present and there is a stable 12v however as soon as I put it in the PS4 it starts whining really badly, however 12v remains stable but after a...
                      01-13-2024, 10:34 AM
