Need help with PS blowing fuses.
  • JimBanville
    • Aug 2020
    • 118
    I'm an amateur at repairing electronics. I have fixed obvious issues on electronics before, but I could use some help on this fix. I picked up a Pioneer CLD-D504 laserdisc player that won't power on. There is no standby light. I was told it may have gotten wet but I see no obvious water damage. It had a blown fuse. I've downloaded the service manual. Nothing, including the fuse itself, says wether it's fast or slow blow, but I'm guessing it's slow, seeing as its right at the point where the AC power goes to the PS. I'm guessing it's the standby power that's "bad". I put in another fuse and it blew as soon as I plugged the player into the wall. I completely removed the PS from the chassis so it was not connected to anything. I replaced the fuse. As soon as I plugged it into the wall, that fuse blew. I've started measuring components on the primary part of the PS while still "in circuit". I haven't removed anything. The first thing I noticed was that R2 measures 2M ohms. I believe it should be 22.5 ohms. Could that be the "problem"? What should I measure next? I've ordered a pack of new fuses that should be here in a couple of days. Thanks!!!!!!
    • 31020
    Re: Need help with PS blowing fuses.
    can you link or upload the service manual.
    it's probably a shorted diode or bridge rectifier.
    is this arcade-related??
      • 31020
      btw, check the main transistor on the heatsink too.
      leave R2 alone if you want to live - it links the mains neutral to the metal chassis!!!!!
      • JimBanville
        • Aug 2020
        • 118
        Here you go...
        http://manuals.lddb.com/LD_Players/P.../CLD/CLD-D504/
        Arcade related? Did I post this in the wrong forum? Sorry
        • JimBanville
          • Aug 2020
          • 118
          Thanks. I'm measuring all this with the PS unplugged. Does that R2 impedance reading of 2M ohms sound right? Does still being in-circuit affect that reading?
            • 31020
            no, just curious - most laserdisk players where used in arcade equipment - very few were privatly owned because of the lack of discs.
              • 31020
              2meg is about right.
              to blow a fuse you need a short - so probably a diode or transistor near the fuse.
              the fuse should be a "T" or time-delay aka slowblow type - preferanbly ceramic.
              • JimBanville
                • Aug 2020
                • 118
                The old fuse didn't look ceramic. Not sure if it was original or someone tried to repair this before I got it.
                I measured Q1 on the heat sink in diode mode. It's marked ground drain source. When I measured it with + on the S, I get .41v on D and .57v on G. When I reverse leads and measure with - on S, I get 1.9v on D but it drops to 0v within a second. I get 0v on G. When I touch the G D S in continuity mode, I might get a quick tone, but I'm not getting a continuous short.
                • JimBanville
                  • Aug 2020
                  • 118
                  When I put the leads on D6 in both directions, I get a continuous tone/"short" across it in both diode mode and in continuity mode. I assume that means it "bad"? Again, I'm measuring it in-circuit.
                  • JimBanville
                    • Aug 2020
                    • 118
                    When I measure the 4 leads on D1 (bridge recitifier??) I only get a constant tone/"short" if I touch the two center leads in either direction (+ and -) marked with the ~ symbols. If I touch the other leads I'll either get around .5v or 0v.
                    • JimBanville
                      • Aug 2020
                      • 118
                      When I measure across the big cap (C11) in the primary part of the PS, while still connected in-circuit, I get 1M ohms.
                        • 31020
                        desolder d6 and see if the recifier d1 loses the short.
                        d6 sounds fucked.
                        • JimBanville
                          • Aug 2020
                          • 118
                          d6 sounds fucked.
                          Thanks! I'll do that this evening. At work now. So I take it the two center pins on the rectifier should not be showing continuity between themselves? They are the two pins with the ~ symbols as viewed from the bottom of the board. I hope it's just that diode! Seems like a cheap fix.
                            • 31020
                            none of the rectifier pins should be connected to each other,
                            but it is soldered parallel to d6 - so you cant tell which is bad without removing one.
                            • JimBanville
                              • Aug 2020
                              • 118
                              d6 sounds fucked.
                              So..Good news...I hope!! I had also posted this question over at the laserdisc archive. Turns out that D6 part is basically a surge/arc suppressor and considered underrated by people over there. Some replace it (the right thing to do IMO) and some just clip it out and use an outboard surge suppressor. I'm going to run by Home Depot tonight and grab a pack of 2A fuses and try clipping that part to see if the unit will power on. Wish me luck!! Haha.
                              • JimBanville
                                • Aug 2020
                                • 118
                                Haven't made it home yet but couldn't wait to grab a pair of scissors and clip that D6 part. The continuity between the two center pins of that rectifier is gone! I think we may have fixed it. Thanks!!!!!
                                  • 31020
                                  good.
                                  btw, the reason for a ceramic fuse is simply that when you have a mains-short like here, it can actually break a glass fuse and create a big mess.
                                  most originals are glass unfortunatly - to save a few penny's
                                  • JimBanville
                                    • Aug 2020
                                    • 118
                                    good.
                                    Gotcha. Never knew that. Makes sense (cents!). Lol
                                      • Jul 2011
                                      • 6039
                                      I would highly recommend that you use a 100 watt incandescent light bulb instead of the fuse just in case you have issues and blow the fuse again
                                      When doing this the light bulb with glow bright for a couple of seconds and dim down to maybe nothing or very dim depending on how much current you are drawing from the switching power supply
                                      If for some reason the light bulb is bright and does not dim down then there are issues with this power supply
                                      What are the devices that are mount to the heat sinks part numbers
                                        Surface Mount Fuses Fundamentals Datasheet
                                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                        10-07-2024, 06:07 AM
                                        TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                                        FF Series (Very Fast Acting), 0603 Size
                                        Features
                                        ● Very fast acting at 200% overload current levels
                                        ● Low DCR
                                        ● High inrush current withstanding capability
                                        ● Fiberglass enforced epoxy fuse body
                                        ● Copper termination with nickel and tin plating
                                        ● Halogen free, RoHS compliance and lead-free
                                        Applications
                                        ● Notebook computers and tablets
                                        ● Digital cameras
                                        ● Memory cards
                                        ● Toys
                                        ● Bluetooth earphones
                                        ● Portable electronic devices​...
                                        10-07-2024, 05:50 AM
                                        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                        by sam_sam_sam
                                        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                        This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                        12-29-2024, 07:18 AM
                                      • Tips
                                        Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                        by Tips
                                        Looking for some assistance please.
                                        Trying to repair a PD27AOQ samsung power board.
                                        Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                        Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                        Testing it the fuse blows immediately power is turned on.
                                        diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                        any assistance, guidance would be appreciated.
                                        04-11-2024, 11:24 AM
                                      • Rictech
                                        Panasonic SA-MAX770PU SMPSU board fault....
                                        by Rictech
                                        Hello everyone. 😀
                                        As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                        Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                        Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                        This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                        There are no devices that have exploded or otherwise show signs...
                                        08-26-2024, 01:05 AM
