I'm an amateur at repairing electronics. I have fixed obvious issues on electronics before, but I could use some help on this fix. I picked up a Pioneer CLD-D504 laserdisc player that won't power on. There is no standby light. I was told it may have gotten wet but I see no obvious water damage. It had a blown fuse. I've downloaded the service manual. Nothing, including the fuse itself, says wether it's fast or slow blow, but I'm guessing it's slow, seeing as its right at the point where the AC power goes to the PS. I'm guessing it's the standby power that's "bad". I put in another fuse and it blew as soon as I plugged the player into the wall. I completely removed the PS from the chassis so it was not connected to anything. I replaced the fuse. As soon as I plugged it into the wall, that fuse blew. I've started measuring components on the primary part of the PS while still "in circuit". I haven't removed anything. The first thing I noticed was that R2 measures 2M ohms. I believe it should be 22.5 ohms. Could that be the "problem"? What should I measure next? I've ordered a pack of new fuses that should be here in a couple of days. Thanks!!!!!!
Need help with PS blowing fuses.
Tags: None
Re: Need help with PS blowing fuses.
Here you go...
http://manuals.lddb.com/LD_Players/P.../CLD/CLD-D504/
Arcade related? Did I post this in the wrong forum? SorryComment
Thanks. I'm measuring all this with the PS unplugged. Does that R2 impedance reading of 2M ohms sound right? Does still being in-circuit affect that reading?Comment
2meg is about right.
to blow a fuse you need a short - so probably a diode or transistor near the fuse.
the fuse should be a "T" or time-delay aka slowblow type - preferanbly ceramic.Comment
The old fuse didn't look ceramic. Not sure if it was original or someone tried to repair this before I got it.
I measured Q1 on the heat sink in diode mode. It's marked ground drain source. When I measured it with + on the S, I get .41v on D and .57v on G. When I reverse leads and measure with - on S, I get 1.9v on D but it drops to 0v within a second. I get 0v on G. When I touch the G D S in continuity mode, I might get a quick tone, but I'm not getting a continuous short.Last edited by JimBanville; 03-11-2021, 08:20 AM.Comment
When I put the leads on D6 in both directions, I get a continuous tone/"short" across it in both diode mode and in continuity mode. I assume that means it "bad"? Again, I'm measuring it in-circuit.Comment
When I measure the 4 leads on D1 (bridge recitifier??) I only get a constant tone/"short" if I touch the two center leads in either direction (+ and -) marked with the ~ symbols. If I touch the other leads I'll either get around .5v or 0v.Comment
When I measure across the big cap (C11) in the primary part of the PS, while still connected in-circuit, I get 1M ohms.Comment
Thanks! I'll do that this evening. At work now. So I take it the two center pins on the rectifier should not be showing continuity between themselves? They are the two pins with the ~ symbols as viewed from the bottom of the board. I hope it's just that diode! Seems like a cheap fix.Comment
So..Good news...I hope!! I had also posted this question over at the laserdisc archive. Turns out that D6 part is basically a surge/arc suppressor and considered underrated by people over there. Some replace it (the right thing to do IMO) and some just clip it out and use an outboard surge suppressor. I'm going to run by Home Depot tonight and grab a pack of 2A fuses and try clipping that part to see if the unit will power on. Wish me luck!! Haha.Comment
Haven't made it home yet but couldn't wait to grab a pair of scissors and clip that D6 part. The continuity between the two center pins of that rectifier is gone! I think we may have fixed it. Thanks!!!!!Comment
good.
btw, the reason for a ceramic fuse is simply that when you have a mains-short like here, it can actually break a glass fuse and create a big mess.
most originals are glass unfortunatly - to save a few penny's
Gotcha. Never knew that. Makes sense (cents!). LolComment
I would highly recommend that you use a 100 watt incandescent light bulb instead of the fuse just in case you have issues and blow the fuse again
When doing this the light bulb with glow bright for a couple of seconds and dim down to maybe nothing or very dim depending on how much current you are drawing from the switching power supply
If for some reason the light bulb is bright and does not dim down then there are issues with this power supply
What are the devices that are mount to the heat sinks part numbersLast edited by sam_sam_sam; 03-11-2021, 07:47 PM.Comment
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
TF-FUSE Thin Film Surface Mount Fuses
FF Series (Very Fast Acting), 0603 Size
Features
● Very fast acting at 200% overload current levels
● Low DCR
● High inrush current withstanding capability
● Fiberglass enforced epoxy fuse body
● Copper termination with nickel and tin plating
● Halogen free, RoHS compliance and lead-free
Applications
● Notebook computers and tablets
● Digital cameras
● Memory cards
● Toys
● Bluetooth earphones
● Portable electronic devices...-
10-07-2024, 05:50 AM -
by sam_sam_samI was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not... -
Hello everyone !
I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
Feel free to share your experience if you ran into other issues.
DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
CD tray would not come out of the player
I could hear a motor spinning inside the player but the CD tray would not come out.
Turned out that the issue was the CD tray belt that aged poorly and began to...-
11-05-2025, 03:11 AM -
by TipsLooking for some assistance please.
Trying to repair a PD27AOQ samsung power board.
Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
Testing it the fuse blows immediately power is turned on.
diodes dm852 and dm853 test as shorted when in the board but fine when removed.
any assistance, guidance would be appreciated. - Loading...
