1300W PSU - Help with replacement mosfet
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    Hey guys,
    had this 1300W gigabit PSU with a blown fuse ( i actually have two with the same problem.)
    I found a shorted power mosfet and diode and some low Ohm resistors that measure 0Ohm.
    I cant find the data sheet on this mosfet at all. need help finding replacement.
    any help would be great.
    I was able to find this on the mosfet but thats all
    https://www.aliexpress.com/i/32967081176.html
  • R_J
    • Jun 2012
    • 9535
    Re: 1300W PSU - Help with replacement mosfet
    Here is the datasheet
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      Thank you so much. hopefully replacing them with the other things brings these back to life. Got em for free and theyre fully modular so would be sweet.
      • R_J
        • Jun 2012
        • 9535
        Remember to check the gate drive circuit, when fets short they can damage the gate drive circuit and ic's
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          Thank you for saying that.
          I found a 10k smd off the gate measuring 4k and also a smd transistor labeled "2F" testing unlike the 2F on the other FET.
          Only one FET blew i compared it to the other side. getting 10k ohm on the other smd Transistor. and voltage drop of .64V and .6V.
          On the faulty one im getting .615V one way and 1.4V
          also found another smd transistor Labeled "1P" that doesnt match the one on the other side
          Im a little confused though, theres also a 47ohm smd on the gate that tests fine though, how is the 10K off but the 47 alright?
            • Jul 2011
            • 6039
            Do not forget to test with an incandescent light bulb instead of the fuse until you make sure that you do have any other issues
            • R_J
              • Jun 2012
              • 9535
              I suspect the 47Ω is in series between the gate and the driver, The 10kΩ is likely from the gate drive to ground and something else that is across it is causing the lower resistance. either bad transistor or drive ic output is damaged
              the 2F could be a MMBT2907A
              the 1P could be a MMBT2222L
              • sdinelli
                Sdinelli
                • Aug 2014
                • 152
                ok ill have to look that up. not sure how to do that. solder some wires to the bulb and solder them where the fuse goes?
                what does this do? limit the current?
                • R_J
                  • Jun 2012
                  • 9535
                  It is for limiting the current, You can install the rated fuse in its holder and then you can build a test jig like this to plug the unit into instead.
                  • sdinelli
                    Sdinelli
                    • Aug 2014
                    • 152
                    Ive attached an image of pcb.
                    red are bad componants.(so far)
                    green is the good FET circuit
                    yellow is a questionable power transistor labeled GP4S60S. Cant fine a datasheet on that.
                    The reason why i question them is because there only 20ohms between the 1st and 3rd leads but also a 10K smd resistor between them as well.... Is it right to suspect them to be bad?
                    I didnt remove them because they're hard to get to.
                    • sdinelli
                      Sdinelli
                      • Aug 2014
                      • 152
                      Thats awesome thanks!
                      • R_J
                        • Jun 2012
                        • 9535
                        Are you sure about that GP4S60S number?
                        • sdinelli
                          Sdinelli
                          • Aug 2014
                          • 152
                          Im sorry its GP47S60X
                          https://hobbydocbox.com/Radio/757171...ransistor.html
                          Closest thing i could find
                          • R_J
                            • Jun 2012
                            • 9535
                            Is this it:
                            • sdinelli
                              Sdinelli
                              • Aug 2014
                              • 152
                              Is this it:
                              Thanks again
                                master hoarder
                                • May 2008
                                • 12170
                                Check the primary input electrolytic caps too. Usually blown APFC components is a result of the primary caps going either short-circuit or open-circuit / low capacitance. Not uncommon for these to go bad either. You will need an ESR + capacitance meter to test them, though (i.e. can't do it with just a regular multimeter.) The cheap GM328 component testers online will do this... or just spend the $8-12 on new input (and quality Japanese 105C too) caps, whichever you prefer. If buying new, make sure the caps are rated for at least 420V... or better yet 450V. APFC does not last long with 400V caps from what I've been seeing so far.
                                • sdinelli
                                  Sdinelli
                                  • Aug 2014
                                  • 152
                                  I do have both an ESR meter and a capacitance meter.
                                  the two big caps ( i think these are what youre referring two)
                                  are rated 470uf 400V CapXon
                                  1st: 427uf .167 ESR
                                  2nd: 422uf .177 ESR
                                  both measure OL in resistence mode
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    1st: 427uf .167 ESR
                                    2nd: 422uf .177 ESR
                                    That's good that both caps measure good. Otherwise, replacing these tends to add a fair amount to the cost of repairing these PSUs.
                                    Since the caps aren't back, I went back and re-read the results you gave in post #5 and #10, along with the picture you posted with tested parts, to which I will be referring to on my comments below.
                                    So referring to the abovementioned picture, I think that 4k resistance you're getting may be normal.
                                    If you look at the left-most APFC TO-247 power MOSFETr spot (that you circled in red), notice there are holes/a spot on the PCB for another of the same MOSFET right directly behind it, but that MOSFET wasn't installed from the factory. Nonetheless, you can see that they did however install the small Gate pull-down resistor in spot R5b, along with the 47-Ohm Gate series resistor for that MOSFET. Therefore, when you measure the resistance across the 10k resistor in spot R5a, there could also be a parallel path through the other 47-Ohm resistor for the non-installed MOSFET and its 10k resistor (R5b). Thus, two parallel 10k resistors will read about 5 kOhms. The 4k resistance you got is lower... but maybe double-check that. Or maybe there are other shorted parts still.
                                    I'm also not sure why they would install the Gate-driving transistors for the MOSFET that wasn't installed... but bad comes to worse, those should still technically be good... so maybe you can use them to replace the ones for the blown FET without having to buy new parts?
                                    Next, look all the way to the right at the blown power resistor you circled in red - this one is likely the current sense resistor for the main switching PS. If this is bad, there's a good chance one or both power transistors next to it (circled in yellow) could also be bad. As such, you may have to remove them to check them (or at least one of them), along with their Gate driver circuits. On that note, I'm not able to determine yet if this PSU uses double-forward or resonant LLC topology, based on the pictures you provided. Thus, I can't really comment how the Gate drive components for those MOSFETs you circled in yellow should measure.
                                    • sdinelli
                                      Sdinelli
                                      • Aug 2014
                                      • 152
                                      Thank you for your thoughts on this.
                                      I may as well just remove the 10K resistor and just test it out of circuit.
                                      yeah i was thinking the same thing about the transistors in yellow.
                                      only thing is they will be a PITA to remove due to space restrictions of the long heatsinks.
                                      any tricks on getting the screws out in tight spaces? i imagine a right angle Philips would work but dont have one .
                                      ill report back when im able to tear into it some more
                                      Those power fets are pretty pricey @ $8 a piece.
                                      i did get these PSU's for free though
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        If you have the space (I doubt it, but anyways), will a philips add-on bit (like those short ones that come with boxes of new screws) fit in there?
                                        If no, what about "extended" nose pliars - similar to needle-nose pliars, but a little ticker / more heavy-duty? I've used those to just turn the screws, despite the head being round. If the metal grip part on the pliers is not worn out, in some cases that will be enough to engage and grab the screw to turn it. I've generally had good success with this method.
                                        Ouch!
                                        Well, you can always try smaller/cheaper MOSFETs (same voltage ratings, but lower rated current), just to see if you can get the PSU working again. After that, once up and running, substitute the proper parts. I've done this more times than I care to remember, especially with rectifiers and fuses. BJTs too, on a few occasions.
                                        You can also do just multiple smaller FETs rather than a few big ones. Just connecting them would be more cumbersome, of course.
                                        • DoOm86
                                          Dual mosfet replacement help
                                          by DoOm86
                                          Hello.
                                          I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                                          It seems to be a 30V dual asymmetric N-channel AlphaMos.
                                          Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                                          And here is where I need help!
                                          It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                                          I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                                          Thanks!...
                                          10-31-2023, 12:03 PM
                                        • jm942
                                          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                          by jm942
                                          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                          I did voltage injection on the cpu with 0.7V and i have a current...
                                          07-11-2024, 05:11 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • String2016
                                          SMD MOSFET REPLACEMENT
                                          by String2016
                                          Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                                          01-23-2025, 06:35 PM
                                        • String2016
                                          by String2016
                                          i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                                          12-15-2024, 05:31 AM
