Hi, everybody!
This is my first post in this forum, so I'd like to start saluting all of you guys who provide this great help to us who suffer from the capacitor plague.
I happen to have a iMac G5 17" ALS that was dead when I bought it. I had to replace the mobo, once the recapping was not enough to bring it back to life.
It's PSU was also damaged, but I managed to make it work by changing the caps and one of the transistors close to the PWM IC (3845).
Some weeks ago, a power surge killed the PSU again. When I tested it I could only find the 24V and 5V tensions that I now know (by reading this forum) come from the section thats driven by the TOP245 IC.
When i was testing the transistors close to the PWM, those voltages have also stoped working and I started to search for some problem close to the TOP245. Finally, I found an open resistor connected from the primary voltage (in my case, nearly 300V) to the transformer thats driven by the TOP245. As I didn't have at hand a resistor with exactly the same value (5,1 ohms) I replaced it with another one with a higher value (10 ohms) just for testing purposes. When I connected the mains, both the resistor and the TOP245 exploded leaving behind just ashes and debris...
I could not find a TOP245 to replace the blown one in my city (Brasília, DF, Brazil), so I tried to find it on the net. Even though I could not find it in any of the sellers I know in Brazil, I managed to find the TOP247 that the datasheet points as equivalent and capable to drive higher power.
I replaced the remains of the TOP245 with the brand new TOP247 and put also a new resistor where the old one once was. When i connected the mains this time (very carefully and from a long distance!) nothing exploded, but the voltages that should be coming out from the PSU are reduced. Where there should be 24V, I found 10V and where it was supposed to be 5V, it was 2V.
This is the point where I'm stuck right now. I'd really like to hear some thoughts about this situation. Are TOP245 and TOP 247 really equivalent? Don't you find strange that the voltage was reduced to a integer value in both cases? Is it a coincidence?
Any ideas at all will be very, very, very welcome!
Thanks again
Emerson
Thanks again
Emerson
