Help Please with recapped Acbell in Imac G5
  • x33
    • Jan 2010
    • 37
    Hello everyone and A Happy New Year!
    Boy I am happy I've found this forum, but although using the "search" button offered me hours of delightful..lool...reading, I still can't find a solution for my recapped PSU that doesn't work.
    Here's the short story:
    Imac G5 20" no iSight, no light sensor.
    PSU is Acbel 661-3350
    Recapped the bad Nichicons (bulged with some brown residue, but not exploded) in the secondary.
    I got 5Vsb and 20.1V unjumpered, and all correct voltages when jumpered ON.
    Installed it back in the imac, all I got is the LED1 lit solid green.
    Pulled it out, same thing as above.Works ok. Didn't try it under external load since I was getting ready for the holidays.
    Came back from the holiday trip, re-installed the PSU in the imac, without doing anything else to it. Pushed the internal button on mobo and LO and Behold ! Scared the cr@p out of me because the fans started spinning and a loud beep told me theat the imac is alive(LED 1 and 2 lit green)!!! Did I mention it was 5:30 in the morning???
    Anyway, I realized I left the RAM out, so I had to shutdown to insert the ram.
    Did it and is back to its previous state: LED1 solid green ...Nothing else.
    Removed the PSU to check the voltages again: 5Vsb and 20.1V present, but when jumpered ON the other voltages DO NOT show up at all anymore.
    Opened the PSU and after a while I found diode D10 opened. It seems that the only other person with this type of fault was Jim Warholic as per his website. Anyway, the diode is marked T2D and then 48 with two lines above. Someone responded to Jim saying that any fast recovery rectifier would do the trick as long as it's 100v/1A.
    I have tried one fast recovery rectifier rated 400v/1.5A, but that KILLS ALL the voltages. No more 5Vsb, no more 20.1V. Nothing!!! Just 45mV here and there..
    I pulled it out and the 5V and 20.1V came back! What the heck is going on?
    Is the TOP244Y switcher bad? There's no way I can determine this, but is definitely not showing any shorts. Checked the outputs for 3.3, 5, and 12 and no shorts...
    Can someone please give me a hint, what am I missing here???
    Thanks and sorry for the long post
  • x33
    • Jan 2010
    • 37
    Re: Help Please with recapped Acbell in Imac G5
    Anybody??
    Please, I am getting desperate here.
    Toasty, I've seen that you have the exact same power supply. Can you please point me to the right direction with this issue (and D10 rectifier)?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      hang on, toasty is the expert on these... he should read this...
      sigpic
      (Insert witty quote here)
      • Toasty
        • Jul 2007
        • 4171
        If 5vsb & 20v are there, TOP is okay and so is diode. Put it back. You can't check (forward-bias) that diode unless you have a 200v current limited supply. It's an ultra fast diode capable of 100kHz+.
        Go back to where you had no RAM. Push button again and see if it fires up. Then put RAM back in and push button again.
        >>Recapped the bad Nichicons <<
        Just the bad (visible) ones?
        Did you have the mobo out? Another thread concluded with a pinched wire causing the problem.
        veritas odium parit
        • x33
          • Jan 2010
          • 37
          Oh thank you guys for chiming in!
          Toasty, I am troubleshooting the PSU now. I've recapped all the Nichicons I've found, bulged or not.
          And then I've found this diode which shows nothing when I put the dmm on it (for diode reading).
          So Toasty, you're saying this is normal? I'll put it back then, but I still can't find out why the PSU refuses to turn on anymore (out of the imac, just jumpering ON).
          • Toasty
            • Jul 2007
            • 4171
            You pulled the diode and measured? Or was it in circuit?
            The 5vsb & 20v are now gone when you just plug it in and NOT jumpered on?
            veritas odium parit
            • x33
              • Jan 2010
              • 37
              You've got me really confused with your answer about the diode, since I've never heard of a diode that doesn't indicate anything on the dmm.
              Of course I pulled it out to measure it. It shows open both ways. Nothing, dead..
              I am getting 20v and 5Vsb with this diode installed (psu jumpered or not) that's all.
              I tried to replace it with another fast recovery diode from a good PSU and that kills all the voltages. I have checked the polarity on the diode and it was correct.
              So, what kind of diode is this D2T (D10 on the board)???
              • Toasty
                • Jul 2007
                • 4171
                Ultra fast. < 75ns recovery
                What brand/series caps did you use for recapping?
                veritas odium parit
                • x33
                  • Jan 2010
                  • 37
                  so something like UF4003 would do it?
                  I have used Nichicons HZ series from mouser.com
                  • x33
                    • Jan 2010
                    • 37
                    Toasty, just for the fun of it, I have left the psu WITHOUT the diode and it does exactly as it does with the original diode: 20v and 5Vsb and nothing else (jumpered on or not).
                    This re-confirms the original D10 diode is dead.
                    I will try getting an ultrafast replacement for it to see what happens.
                    • Toasty
                      • Jul 2007
                      • 4171
                      I think that a cause of recapping failures in these units, is using caps of too low ESR, like the HZ's. It seems odd, but I've seen people with working units with blown caps, not work after recapping with excellent replacements. I don't know if it's a particular trait of the AcBel's or not.
                      I've 2 of these somewhere in the pile. Let me grab them and see if either work. I can give you some voltages to check later. I can't guarantee that it will be tonight or tomorrow.
                      The diode is fine, BTW. These always show as open on a DMM or VOM. As I said before, you need to be able to present ~200v to forward bias it. I am beginning to think they may be avalanche types used as a "snubber" or clamp for overvoltage spikes. If you look at the circuit, you'll see it's across the primary of the 5vsb transformer from the TOP output (drain - pin 6).
                      veritas odium parit
                        • 31183
                        that makes sense,
                        i'v seen similar things with too much capacitance on stuff that's been home-designed.
                        the inrush as the caps charge is tripping the over-current circuit.
                        • x33
                          • Jan 2010
                          • 37
                          Ok Toasty.
                          I've put the original D10 back in the psu and I'll wait for some info from you.
                          I'll just try replacing the small caps in the primary (Teapo's) rated at 50v and one@25v to see if it makes any difference..
                          Isn't it weird though that the psu gives the 20v and 5vsb WITH OR WITHOUT D10 installed???
                          • x33
                            • Jan 2010
                            • 37
                            Toasty, here's what I've managed to measure:
                            387 Vdc across drain and source on TOP switch !
                            5.78 V across the SCR1 thyristor.
                            Any other ideas what to check?
                            • x33
                              • Jan 2010
                              • 37
                              Toasty ?
                              I hope you haven't totally forgotten about me
                              • x33
                                • Jan 2010
                                • 37
                                err...Santa?
                                • x33
                                  • Jan 2010
                                  • 37
                                  Well, since I haven't got too many suggestions on this psu issue, and being too tired of wasting my time on it, I guess I'll do myself and everybody else a favor and turn this iMac cr@p into mush and throw it in garbage...
                                  After all, that's where Apple products belong anyway!
                                  Good weekend all!
                                  • x33
                                    • Jan 2010
                                    • 37
                                    Well, after a good night sleep, I decided to give this piece of junk another chance... so after reading multiple posts here and across the net, I have managed to start it with a modded CoolerMaster ATX plus a laptop psu (for backlight 24V).
                                    The modding was fun, but I'd like to clarify that this Imac's backlight doesn't work without the 24V.
                                    I am still trying to fix the damn psu, since there's no way in hell I'll be paying 100+ bucks for such a lame psu..
                                    So Toasty, I've sent you a PM with some new things I've discovered on the psu (trafo T1 has a lead in the primary that should be connected to negative from main rectifier bridge?? I can't measure anything on the lead..)
                                    Anyone knowledgeable in these psu's is welcome to pitch in an idea.
                                    Cheers!
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      I have no news to report at this time. I have not been on the bench in over a week. I have been reading and following yours and others responses. Answering has not been forefront as I have no info to report. I do have the other units out, but I have not checked them.
                                      I ask that PM's be limited to exactly that. Technical information and questions should always be posted on the forums. Info supplied or requested in a PM may very well trigger a response from others that are following the involved thread.
                                      From your PM of several days ago:
                                      "...but you're the only member that can still help me with this insane psu."
                                      That is not true. There are many others here who are much more knowledgeable than I. They have most likely chosen to steer clear of Apple products and discussions as they are not the everyday repair. They see 1,000 regular PSU's to 1 Apple.
                                      When it comes right down to issues with these PSU's, if a recap doesn't work, replacement is the best option. Mainstream shops have given up working on them once a recap doesn't work. They are a PITA to work on as you can see and tracing a signal can be a royal pain after it's made it 4th switch from top to bottom via through-holes under a transformer.
                                      "...as a last resort I pulled out T1 trafo. It turns out that its primary has 3 leads. Two are going into the q12 and q13 fet's and the third one goes to the ground. Well measuring with the ohmeter, I get nothing from the 3rd one! I can see the wire going inside the trafo, yet I can't measure anything from it. Could it be burned inside???"
                                      No. It appears to be a noise suppression winding. In this iteration, there is only 1 end showing that wraps the trafo post. In others, it's 2 ends of the winding. In all cases, it goes to common.
                                      As a start, are the SMD transistors around the 3845 chip -all- okay?
                                      Does it in any way look as though the board has been overheated around the 3845?
                                      It's a very inexpensive part, < $1, and as much as I hate guessing and playing 'swapsies' with parts, it might be a best choice to replace it.
                                      I would choose the TL2845, as it has a higher temperature rating (85°C) than the TL3845 (70°C). That is the only difference I see between them. Mouser has them in stock.
                                      veritas odium parit
                                      • x33
                                        • Jan 2010
                                        • 37
                                        Welcome back Toasty!
                                        When I said "...but you're the only member that can still help me with this insane psu." I seriously meant : you're the only member I've read about having the exact same psu as I have. I obviously didn't mean in any way to be disrespectful to the other members and their knowledge.
                                        Just wanted to clarify that.
                                        I have just found out late last night about the noise supression winding on T1, and you just confirmed it. Thank you.
                                        The bizarre part is that absolutely nothing on this psu shows signs of overheating... Checked everything with my trusty magnifying glasses.
                                        I am afraid I'll have to play "swapsies" after all, since everything checks out ok...
                                        I'll post back as soon as I get any new findings.
                                        Thank you!!
                                        • ryogadan78
                                          iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                          by ryogadan78
                                          Hi guys, I need your help again.
                                          I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                          When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                          06-10-2025, 03:49 AM
                                        • Stephen
                                          iMac M1 DFU restore issue
                                          by Stephen
                                          iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                          this is the message it gives me with the error
                                          Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                          Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                          03-07-2025, 12:19 PM
                                        • Stephen
                                          iMac 27” 2020 Boot issue
                                          by Stephen
                                          Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                          08-16-2024, 09:32 AM
                                        • tommy97
                                          iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                          by tommy97
                                          we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                          Any ideas what might've...
                                          04-20-2024, 04:48 AM
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
