iso p500-spp 400 watt power supply cpu issue
  • Boyxba
    mr
    • Jul 2016
    • 25
    • Greece
    i have a power supply with issue in -12v rail. after 15seconds of power the diagnostic begins beep and shows LL ON -12V which means undelvoltage .. i have replaced the most of the capacitors due to missing capacitance (checked with capacitometer)..but i have stil the same problem . can anyone help me to find the solution to fix it....the diodes are ok...i have checked..
    • 31304
    Re: iso p500-spp 400 watt power supply cpu issue
    maybe the diode.
    diodes can look o.k. on a meter and then fail as they warm up in circuit.
    only 2 ways to detect that.
    1: blast it with compressed air or freezer spray while running to see if it fixes the problem.
    2: meter both the ac input and the dc output to see if the input drops when the output does.
    • Boyxba
      mr
      • Jul 2016
      • 25
      • Greece
      Originally posted by stj
      maybe the diode.
      why does it on -12v rail all the other voltages are ok
        • 31304
        negative rail has it's own transformer tap and diode
          master hoarder
          • May 2008
          • 12175
          Are you using one of those ATX PSU "testers" that just plugs into the ATX connector and turns on the PSU? If yes, ditch that thing where no one will find it. I've seen those "testers" mis-report a lot of power supplies as being bad. The problem is they don't put a significant load on the output of the PSU. Therefore, the -12V rail will almost always show low voltage. On group-regulated PSUs, other rails may appear low too. For more accurate results, add a load to the PSU - preferably at least 1-2 Amps of current draw from the 3.3V, 5V, and 12V rails each. That should bring the -12V rail to a more normal value.
          So for the above, I suggest connecting the PSU to a crappy motherboard (something like an old useless Pentium 4 or similar board), turn on the motherboard, and then measure the voltages with a multimeter at the ATX connector. I bet you the -12V will be OK then.
          Also, since you mention this is an "ISO" -branded power supply, you may want to post some pictures here. Some of them are built well and worth recapping, like this one:
          https://www.badcaps.net/forum/showthread.php?t=46636
          But some cheap variants of the ISO line can be total crap and very gutless. Here's is a gutless one that probably will need a ton of modifying if meant to be used with a PC again:
          https://www.badcaps.net/forum/showthread.php?t=39370
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
