Dual output power supply 5 and 12 volts (no output)
  • R_J
    replied
    Re: Dual output power supply 5 and 12 volts (no output)
    In your pictures there is a missing VCC capacitor in the primary. Did you replace it? There should be a resistor connected between the source of the mosfet and hot ground, then there should also be a resistor betwwen the source to the CS pin of the ic, check if it is open. You could also have a damaged optocoupler
  • Dual output power supply 5 and 12 volts (no output)
    Hello everyone
    I have a problem with this dual output power supply, I have nothing at the output, I did the classic tests and replaced some components such as the mosfet that was shorted, a couple of resistors burnt following the short of the mosfet, the integrated td3843 which in turn it gave me a short between the ground and the output (the IC is under the big capacitor) I replaced the capacitors on the secondary for safety, the big capacitor looks good by testing it, when I power the big capacitor I have 320 volts , I got stuck because I can't understand what the problem is, a hand would be appreciated thanks
