thermaltake w0009 420w - teapo SEK substitute?
  • timarlop
    • Apr 2009
    • 40
    • Portugal dos Pequenitos
    Finally I've cut through this "beautifully" designed psu to identify all the caps.
    See my old What the heck is this? thread for pics
    yellow: Jenpo ce-le 2200uF 16v (replaced with NCC KZE)
    red: two Teapo 3300uF 10v
    oranje: two Jenpo ce-le 3300uF 6.3v
    blue: Teapo sek 470uF 16v
    purple: Teapo sek 470uF 16v
    What caps should I use to replace the 2 teapos ?
    NCC PW or low esr KZJ Series
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: thermaltake w0009 420w - teapo SEK substitute?
    Nichicon PW or low esr KZJ Series
    Fixed that, but you should probably use the Nichicon PW series as they are more towards the same ESR as the original caps. Using the LESR caps in there will actually cause more ripple.
    • timarlop
      • Apr 2009
      • 40
      Thanks for the reply
      Any thoughts on these caps, for the teapo replacements ?
      http://cgi.ebay.ie/10-x-470UF-16V-10...item1e59ed954b
      http://cgi.ebay.ie/470UF-16V-105-DEG...item518c8a20bd
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Unknown brand and very low value. For a 420W I would recommend at least 2200uf caps for each rail.
        • timarlop
          • Apr 2009
          • 40
          These http://cgi.ebay.ie/470UF-16V-105-DEG...item518c8a20bd
          are Elna!
          Don't know what series... I'll contact the sealer.
          I need extra space to fit that!
          Would it be safe to increase that much?
          • timarlop
            • Apr 2009
            • 40
            Discovered Nichicon PW Series 16V 680UF, are they suitable ??
            • iMic
              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
              by iMic
              Hi folks,
              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
              11-29-2023, 06:44 AM
            • learnmore
              How to choose a substitute mainboard
              by learnmore
              Hello again Community
              Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
              I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails....
              03-23-2024, 02:55 AM
            • Grasshopper2Ant
              ACF Remover G-450 Substitute in Canada
              by Grasshopper2Ant
              Hi All,
              Need help sourcing a substitute for ACT remover G-450 in Canada.
              Removing glue from Flex Cable on LED TV that I dislodged so I can resolder with ACF tape.
              Can someone confirm if acetone will work?
              They will not ship to Canada.
              Thanks for any help....
              08-15-2023, 02:00 PM
            • matyka
              CSRS545 Diode Substitute? Help
              by matyka
              Hello, I have a power supply and I found a shorter diode CSRS545 , any substitute to buy?
              03-04-2023, 11:56 AM
            • bilux
              uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
              by bilux
              I want to find a replacement for uP0109 8pins, and i found this parts:
              uP0109 is "2A Ultra Low Dropout Linear Regulator"
              RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
              FP6137C is "2A BUS TERMINATION REGULATOR"
              can replace uP0109​ by RT9199 or FP6137C ?
              11-01-2024, 12:00 PM
