Macintosh 6100 Power Supply
  • tarzan0815
    • Dec 2020
    • 6
    • Austria
    Hello folks!
    I am currently working on a Macintosh 6100 Power Supply and I really need a capacitor list! Maybe someone has such a computer and can open it to tell me which capacitors belong where.
    Apple Part Number: 614-0022
    Thanks in advance!
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Macintosh 6100 Power Supply
    Looks like that's an Astec AA16990. Is there a reason you are assuming the problem is a capacitor?
    Here is an older thread about this PSU model, https://www.badcaps.net/forum/showth...hlight=AA16990 .
    PeteS in CA
    • tarzan0815
      • Dec 2020
      • 6
      • Austria
      Thanks for the reply!
      I have already seen this post and this is not the PSU I have.
      My problem is that I have a PSU without capacitors and therefore I need this list I talked about.
      • PeteS in CA
        • Aug 2005
        • 3581
        Missing capacitors would definitely be a problem. I'm not even familiar with the PSU brand, but my wild guess would be that the smaller output capacitors are 1000uF and the larger 1500uF. I don't think a guess would be good enough to go with, though.
        Since that was built in 1985, most currently available low impedance capacitors are much lower impedance that what was originally installed. When you settle on values I'd suggest Nichicon PS or PM series. Or possibly PJ series.
        PeteS in CA
          • 31048
          adrian black on youtube may help, he recently rebuilt a 6100 on a video i think.
          • tarzan0815
            • Dec 2020
            • 6
            • Austria
            Thanks for the help, I am going to contact him.
            • ghost180sx
              • Jun 2021
              • 12
              I'm new here but have recapped a 660AV that this power supply powers. I've also fixed a bunch of other things kicking around the house with bad caps.
              I know it's a year ago that you posted this but I have this exact power supply! The Dyna-comp DCF 803, not the ASTEC!
              I need to recap it, I believe, to fix a very noisy video output on the system. I don't know if it will fix my noisy/fuzzy video, but I might as well give it a shot! My SGI Indy has the same problem - but that one has obviously bulging caps and so no wonder the system from the audio output to the video display is so noisy! I've taken it out of service since.
              Do you still need values for all the caps?
                • 31048
                the sgi box probably has leaking panasonic FC's in it.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Power Macintosh 6100, it looks like, based on both the date code on that PSU's PCB and a hit on DuckDuckGo.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • ghost180sx
                    • Jun 2021
                    • 12
                    Several machines share the exact same chassis and power supply. There is more than one power supply model design that share the same Apple part number.
                    Unlike other threads on Badcaps here, where these machines contain an ASTEC power supply, mine has this Dyna Comp Inc. unit instead.
                    Instead of it being multiple boards like the ASTEC, mine looks exactly like the single PCB power supply as pictured above, except I have all the original caps on mine and it is working.
                    • ghost180sx
                      • Jun 2021
                      • 12
                      I pulled all the caps off the board last night. It was quite tricky, because they decided to manufacture it by bending the cap's leads quite far over and leave big tails, and solder them all down. It took a lot of heat to get a mini-screwdriver under each lead and bend it up straight, clip it off and remove the caps.
                      My board did not have any errors regarding the polarity of the Electrolytic caps. The silkscreen shows a +, and before soldering, they clearly had someone mark the (-) lead with a dashed line using a sharpie. If you use isopropyl alcohol to clean the board, you might lose these marks.
                      Code:
                      Apple Quadra 660AV power supply
                      Manuf: Dyna Comp Inc.
                      Made In: India
                      Model Number: DCF 803
                      Serial No: DA33238ZDP31
                      C16		33uF		35V		85C
                      C10		33uF		35V		85C
                      C36		10uF		35V		85C
                      C30		82uF		35V		85C
                      C24		330uF		35V		105C
                      C25		330uF		35V		105C
                      C26		220uF		35V		105C
                      C29		220uF		35V		105C
                      C31		22uF		35V		105C
                      C17		2200uF		10V		105C
                      C18		2200uF		10V		105C
                      C19		2200uF		10V		105C
                      C20		2200uF		10V		105C
                      C21		2200uF		10V		105C
                      BOM:
                      Electrolytic 35V @ 85C
                      (2) 33uF
                      (1)	10uF
                      (1) 82uF
                      Electrolytic 35V @ 105C
                      (2) 220uF
                      (1) 22uF
                      (2) 330uF
                      Electrolytic 10V @ 105C
                      (5) 2200uF
                        • 31048
                        your caplist is missing among other important stuff, the diameter and height of each cap.
                        • ghost180sx
                          • Jun 2021
                          • 12
                          That's right, I didn't bother doing that yet. It was late last night. I'll try and get back here soon and post it.
                          The original caps did not seem to be very notable, but I'm semi new at identifying them. The larger brown ones that were rated 105 degrees C were marked with KME and were otherwise plain. It seems these are UCC KME series based on a google image search. Since I'll be ordering new parts from mouser.ca, I'll likely order the same ones as they at first glace appear to be still available.
                            • 31048
                            KME - replaced by KMG.
                            not a perticularly special cap.
                            • ghost180sx
                              • Jun 2021
                              • 12
                              Thanks Monkey King!
                              It seems that most of the caps on digikey.ca are non in stock. Typical! I'll have to get creative with the ordering and will work on it tonight.
                                • 31048
                                i used a cloud before it was a thing!
                                • ghost180sx
                                  • Jun 2021
                                  • 12
                                  I always thought clouds were vapourware. When's the release date again?
                                  Here is an update with sizing and the original cap's type/series. Also a correction: the 82uF is a 105C rated.
                                  Now the part where I have absolutely no experience about: What precisely to buy to replace these. I guess off to digikey.ca and the reference here on what caps are nice!
                                  Code:
                                  All dims in mm:			Hgt.	Dia.	Ld.
                                  Electrolytic 35V @ 85C				Sp.
                                  (2) 33uF	(SME)		11	5	3
                                  (1) 10uF	(SME)		11	5	2
                                  (2) 220uF	(LXF)		19	8	4
                                  (1) 22uF	(KMF)		11	5	2
                                  (2) 330uF	(LXF)		19	10	5
                                  (1) 82uF	(LXF)		14	7	3
                                  (5) 2200uF	(LXF)		24	13	5
                                  • ghost180sx
                                    • Jun 2021
                                    • 12
                                    I just wanted to say that I successfully recapped my power supply with all the above values, using all Nichicon caps available at digikey.ca, and the computer never worked better. The built in video is crisp as the day the system shipped, and the system runs perfectly in every way. I didn't have to replace any of the high side input filter electrolytic or RIFA caps. I can't be happier - as I feel my "ultimate" 68k pizza box project is now complete! Total cost was $22 CAD, with one extra cap each as a spare in case I messed up my resoldering job.
