the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: ZUMAX Technology ZU400W (X1)
    I may actually try putting slightly beefier parts on the secondary and put this PSU into some junker PC that I plan on throwing together out of spare parts (just so I have something at my workbench for looking stuff up while working), and then I can see how many years, or (realistically speaking) months or weeks this thing lasts before giving up the ghost. Though, I won't be wasting any of my 'good' parts on this.
    Originally posted by momaka
    What? WHAT? ... WHYYYY?!
    Yeah, that was more or less my exact reaction when I saw that they used a 30A part for a rail that is rated for 2.5A max, but as you mentioned, the part could be a QC reject that Leadman desperately wanted to reuse. I do plan on trying to test the side that had its leg cut off, to see if that side really is defective.
    No, they (Powmax / Leadman) actually got that part right... as if by a miracle.
    I guess that's my PSU design lesson of the day.
    But seriously, I do appreciate you going out of your way to explain that to me, as i'm pretty much fully self-taught when it comes to electronics like this, so this kind of info is the type of stuff i may normally not find online, at least not easily, so thank you.
    It WAS worth it - you saved someone else $8 from buying this POS... plus who know how much headaches for them, if they aren't as well-versed in electronics/PSUs/computers as you are. For all you know, you could have saved someone's really important data or only computer from blowing up / burning out when this PSU goes out. It may seem strange to think of it this way... but that's what it is, really.
    I hadn't thought about it that way, but now that you mention it, it makes sense, as if i didn't grab it, someone else would have, which is what i think happened to the Rhino SP-450Y PSU i found in the trash back in 2018, since it had a Savers price tag on the bottom of the unit, which says that it was sold at a Savers thrift store, only to be bought, and do who knows what to someone PC (hopefully nothing, but it's hard to know for sure).
    Speaking of Savers, I actually picked up a couple PC PSUs from a local Savers recently, one of them needs a bit of work though (a full recap of the secondary).
    Oh, and I also got a good chuckle or two out of the design of this PSU, which makes it slightly more worth it to me.
    (Yes, don't try using this PSU at all is probably what should be meant.)
    Fixed that for ya.
    Do any of the cables have a valid UL number or other certificate number? If not, I'd consider the ratings on them at least somewhat questionable - particularly the voltage one.
    Actually, none of them do, even the "18AWG" ones lake any safety markings, also, i double-checked the "18AWG" wires again, and found that they're slightly closer to being 19AWG, since they're still thicker than some true 20AWG wire i have, but not quite thick enough to be 18AWG.
    At least with this unit you didn't get the cheapest crap heatsinks, though, unlike this Sun Pro KY-480ATX.
    I actually came across that post not too long ago, and i remembered that a (now defunct) electronics surplus store in my area had a box full of bare PC PSU boards, all of which looked more or less exactly like that Sun Pro PSU, all the way down to the paper thin heat sinks. How did they get so many, and without the cases, i don't know. I may have taken a few photos of them, but i'll have to see where those photos ended up.
    I'm not a expert, I'm just doing my best.
    • dmill89
      • Dec 2011
      • 2531
      Re: ZUMAX Technology ZU4000W (X1)
      4th... and I have to concur with Dan81 here: I don't think this PSU was made or designed by Topower. The label is indeed likely a BIG lie. The "LP" markings on the transformers and the PCB suggest Leadman Power - a.k.a. Powmax / Sun Pro. This is hands-down my least favorite PSU manufacturer... or most favorite worst manufacturer, I don't know anymore. If it was a Topower unit, those usually have "top..." or "ever-power" text on the transformers.
      I guess "Marketed by Topower" doesn't have the same ring to it. Zumax was Topower's "budget" line, but it looks like at least with this unit they just farmed the whole thing out and Topower's involvement was likely limited to slapping a label on it and putting it in a box.
      • Dan81
        SNES-powered
        • Oct 2013
        • 1865
        #1723
        Re: the gutless, bloated, and fried power supply hall of shame
        I doubt Topower had anything to do with the label, if at all.
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          Moretek MPS-200/150 Power Supply
          So here is a power supply that i found in the trash, the PSU appears to be rather old judging by the external switch and minimal output leads.
          Label:
          Looking at the label, we don't really get much info about the PSU, other than its a 230w unit, and that i shouldn't be taking it apart in five different languages, but that ain't gunna stop me cuz i can't read most of them.
          Anyway, here is the forbidden insides (AKA, the board overview):
          Well, there isn't a lot to see in here, and TBH, i was kind of suprised when i saw how empty it was inside, mainly because this PSU had a bit of weight to it, but as it would turn out, most of that was in the (suprisingly decent) case this board was placed in. Also, we finally find a proper name and model to go to this unit, Moretec. Now i couldn't find much about them, but the few things i did find were supringly decent, so it's a shame that they stooped so low for this unit, but maybe it could be salvaged.
          Primary side:
          So in terms of input filtering, it has no input filtering, not even the usual fake Y-class capacitors, we do however, have an NTC themistor and a fuse, a rather cheap looking fuse, but a fuse none the less. The bride rectifier is made up of 4 1n4007 diodes, i want you to look at how tiny and under-rated they are, i mean, they're 1 amp parts, and if this is a 240w PSU, then they would possibly be seeing up to twice their rated current under full load (at 120V, assuming 100% PSU effenicy, which is highly unlikely to be the case), and even at something like 75% load, they'd still be getting overloaded. Now the main capacitors are a pair of Rubycon YKs, rated 220uf, 200v, in which they test at 215uf and 225uf respectivly. They appear to be real Rubycons, which would probably make them some of the best quality parts in this PSU. The main switchers are a pair of (2S)C2810s in a standard dual-foward configeration. The main transformer is 33mm wide by about 29mm tall.
          Secondary side:
          The filtering for each rail is a follows:
          12v: 2x PR3002 (100v, 3A) fast recovery diodes (mounted in a classic diode bracket configeration), Pi Coil (16~18 AWG, 20 turns, 5mm core), Luxon SM 1000uf, 16v capacitor.
          5V: S10C40C (10A 40V) schottky rectifier, PI coil (12 AWG, 8 turns, 5mm core), 2x Capxon KM 1000uf 10v capacitors locaded on either side of the coil.
          -12V: 3x PR152? (obstructed part number)(1.5A) fast recovery diodes, Capxon KM 470uf 16v capacitor
          -5V: 2x PR152? fast recovery diodes, Capxon KM 470uf 16v.
          The controller chip is a (TL)494CN, beyond that there,s not much else to note.
          The Fan:
          Just an older Yate Loon fan, still spins really well.
          I'm not really sure what to do with this thing, maybe it might be worth beefing up a tad bit for projects and such, but i don't know.
          • Dan81
            SNES-powered
            • Oct 2013
            • 1865
            #1725
            I would beef it up a bit and keep it should you ever find the desire to build an retro AT machine.
            Maybe a personal preference but I would rather put 2-4 hours of work in beefing up an AT unit (which I did to an Essun 200W AT PSU) than having to fiddle with an adapter and an ATX PSU.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
            • PeteS in CA
              • Aug 2005
              • 3578
              • USA, Unsure of Planet
              #1726
              The model number suggests it's a 200W/150W power supply (or maybe the PCB is used for 150W and 200W models). Anyway, the 220uF input caps are about right for 150W. Based on possible clues in the S/N and numbers on the magnetics, I'm going to guess the power supply is 1996 vintage.
              PeteS in CA
              • RukyCon
                A Fake Rubycon
                • Jan 2017
                • 816
                Side-by-side of a ThermalTake TR2-600NL2NC 600W PSU (left) and a ISO ISO-450 350W PSU (right). Notice any similarities?
                If people are interested, I'll do a full pictorial of both of them, otherwise, I'm probably going to scrap both of them (since I have far better PSUs).
                The ISO seems okayish, the ThermalTake seems mostly undersized.
                • cubecompmtdx
                  • Oct 2010
                  • 22
                  Both of those units are made by Channel Well Technology (CWT for short). The green transformers are a giveaway. I have a Thermaltake Smart M750W 750W unit from 2013 that's made by Channel Well. CWT is an OEM for I believe a handful of brands. CWT has made PSUs for Thermaltake, Antec, Corsair (I believe), and also have been sold under cheap labels like OKIA, ISO, among other generic brands. The quality of the unit all depends on how the requesting company wants their unit built. Kind of like how the quality of PSUs from OEMs like Bestec, HiPro, and Delta depend on which computer OEM they're installed in - The mobo killer Bestec ATX-250-12E is a good example of this... a unit that was built to a much lower standard for eMachines, compared to the ATX-250-12Z, built for HP to a much better standard.
                  Cube Computer Company - Fulfilling Dreams... One Computer at a Time.
                  Link to CubeComputerChannel on YouTube:
                  http://www.youtube.com/user/CubeComputerChannel
                    master hoarder
                    • May 2008
                    • 12164
                    #1729
                    https://www.badcaps.net/forum/attach...1&d=1674036591
                    I picked up two PSUs in January of last year, and one was a ThermaTake like yours or very similar (not sure if 500W or 600W version... just somewhere along the lines.) Same thing I noticed as well - components not quite big enough to handle what the label stated. But I kept it and will recap it. The power ratings on the label are a lie, but the PSU itself I'd say is good enough for a basic/basic+ build. I'm just going to re-label it.
                    Yes, that ThermalTake definitely won't do 600W. But it's a decent CWT build, as cubecompmtdx noted, and from their ISO line. What I like about the ISO line is that it uses an oldschool half-bridge design and there is no APFC.
                    In the case of your ThermalTake up there, I can see even an IC for the 5VSB, which is always nice for safety of the 5VSB circuit. Also, it has large TO-247 BJTs for the main switchers and 680 uF primary caps. With good caps on the output, it should definitely be capable of 350W. Maybe even 400W for a few moments. Not a bad PSU, IMO. I'd save it over anything with APFC any day.
                    BTW, another tell-tale factor I use for deciding if a PSU is worth keeping: if it's an older design (like the above) and if it has a T130 -size output toroid (1.3 inch / 33 mm diameter), it's probably worth saving. PSUs with T103 -size toroids (about 1" or 25 mm diameter) are a coin toss... though - if it's a T103-52 core (light green colored core with blue on one side), it's good. If it's T103-26 (yellow colored core with white on one side), it's about the same as every other generic 200/250W PSU.
                    BTW x2, looking back some pages, I realized I forgot to reply back to your PM about a scrap 5VSB transformer (though, I'm guessing you probably don't have it anymore?) Anyways, I'll PM you shortly. Sorry about that.
                    • Dan81
                      SNES-powered
                      • Oct 2013
                      • 1865
                      #1730
                      Guess it fits here. Came with a Conroe based Core 2 Duo E4600.
                      Main rig:
                      Gigabyte B75M-D3H
                      16GB DDR3-1600
                      Delux MG760 case
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Looks like a 200W supply, and a crap one at that.
                        EDIT: Where's the fan???
                        Permanently Retired Systems:
                        Kooky and Kool Systems
                        sigpic
                        • Dan81
                          SNES-powered
                          • Oct 2013
                          • 1865
                          #1732
                          Didn't picture it but it should be the 2 pin header that's on the upwards of the image.
                          I didn't keep it open for long, just to dust it off.
                          It's a Huntkey (or at least that's what RealHardTechX claims in one of their PSU tables) and it looks like it has room for improvement. The PI coils are jumpered from what I could tell, but at least they can be installed. Also, ViPER22A for the 5VSB (or at least that's what I think it uses), and real 35 size transformer.
                          With enough tinkering, this might be a fine 350W unit, theoretically. Practically, I have to check whatever sillicon it uses and upgrade it as necessary.
                          Main rig:
                          Gigabyte B75M-D3H
                          16GB DDR3-1600
                          Delux MG760 case
                          • PeteS in CA
                            • Aug 2005
                            • 3578
                            #1733
                            With those input rectifiers, the TO-220 switch devices, and the output heatsink I'd say the limit is 250W-300W. If the input lytics are 470uF, then 250W: if lower, then lower power; if highers then maybe 300W.
                            PeteS in CA
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1865
                              #1734
                              330uF HEC buggers that I doubt have anywhere near that value. (or evwn close to 200uF alone.)
                              Anyways, here's another classic that defines this thread. Won't power on when green/blsck are shorted, but it does produce 5vsb
                              Interesting that unlike Sun Pro's most designs using the proprietary AT2005B, this one uses an AT2008 PWM chip,aqnd claims to have protections.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • PeteS in CA
                                • Aug 2005
                                • 3578
                                #1735
                                Yeah, 330uF might do for 200W (= decent 50/60Hz ripple, decent low line voltage and hold-up time at nominal line). 220uF or 270uf would be more like 150W. My experience at computer companies is with mini-computers, workstations, and servers, so I may be a bit conservative compared to what is tolerated with some lower-end desktops.
                                But actually running that thing at 400W+? For how many seconds or minutes, and are you wearing ear protection.
                                PeteS in CA
                                • Dan81
                                  SNES-powered
                                  • Oct 2013
                                  • 1865
                                  #1736
                                  I very much doubt it can do more than 100W safely, at least for now. The size of the cans makes me think they're barely 180uF or even less at best. And add a decade of usage on them and you won't even get 100W out of it.
                                  Main rig:
                                  Gigabyte B75M-D3H
                                  16GB DDR3-1600
                                  Delux MG760 case
                                    master hoarder
                                    • May 2008
                                    • 12164
                                    #1737
                                    +1
                                    Also, I'm glad that you mentioned inductor materials and sizes in the past, because I've been paying more attention to this now and often finding that the output inductor tends to heat up quite a bit under load, especially when there is a large cross-load (i.e. too heavy 5V or too heavy 12V load.) In particular, T103-size toroids (1.03" diameter... or 25.5 mm) are usually used in PSUs rated for 300 Watts or less... though the power rating could be stretched a little if the material is type -52 *and* the PSU uses a faster switching frequency (typically single or double-forward designs only, and not half-bridge.)
                                    That said, this PSU looks like it uses T103 size inductor, though I can't tell if it's -52 or -26 material. The material between the windings looks green, so it might be -52, which would be better.
                                    Nevertheless, even with that, I still think this PSU won't be able to do more than 250W reliably long term.
                                    Yeah, those should definitely be installed if you want more than 100 Watts of output without excessive ripple.
                                    LOL.
                                    Yeah, 330 uF on the primary... and that's if they're real capacity... 150-180 Watts tops.
                                    Sounds bout right.
                                    Ironic it doesn't work. This looks like one of the better built Sun Pro PSUs. This is why I would never trust a Sun Pro PSU - they are just poorly designed (copied designs from other PSUs) all around. And I never liked the trace spacing on the primary side on their PCBs.
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1865
                                      #1738
                                      I suspect the Sapcons went dry on the Raidmax. I just got two iMicros and one happens to have been recapped with Samxons - I might pull all of them and swap them into the Raidmax and hope for the best.
                                      If anything, I also suspect the 12v rectifier being dead (or both of them, I dunno yet.) as I found a 2x Molex to 6pin PCI-E adapter on it... not a good sign at all.
                                      I might also have some spares to use for the Huntkey unit, as well as PI coils.
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1865
                                        #1739
                                        Spacer PSU that's sold in Auchan Romania. Claims "250W for 500W Desktop PC"... whatever they wanted to say with that.
                                        I barely doubt it does a single watt in spec without self immolating on power on.
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3578
                                          #1740
                                          Well, the input fuse looks zorched, but ignoring that, those input rectifiers, lightweight heatsinks (wrt heatsinks, heavy metal is pretty much always best), and small main transformer put its realistic power capability in the 150W-175W range. The skimpy output filtering means that thing will be noisy at any non-explosive output power.
                                          PeteS in CA
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
