the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: the gutless, bloated, and fried power supply hall of shame
    Originally posted by jazzie366
    Out of curiosity, can you crack open that transformer? It looks half decent for an overall shit power supply.
    Ok, here is what i found.
    The feedback coil (i think that's what it's called) consist of 7 windings with 2 layers of tape isolating it from the secondary. (that plus the wire insulation of course)
    The secondary coil consist of 2 wires with 18 windings each, both wires are connected in parallel.
    The primary coil consist of 121 windings with 2 layers of tape isolating it from the secondary.
    And that's it for that transformer, it seems to be a bit unsafe by the way it's built.
    I may keep the core for future use.
    I'm not a expert, I'm just doing my best.
    • jazzie366
      • May 2016
      • 304
      >2 layers of tape between primary and secondary
      That tape is 600V insulation rated (from decent brands at least). That means it's got 1000v of isolation. That would fail EU standards so fast due to the fact that 3000v is required. There are better ways of doing this nowadays. I've seen newer transformers from SMPSs like this that would put a plastic/glass isolator on the core of the transformer, tape over that, wind onto that, tape, isolator, tape again, and then the secondary. Feedback windings usually will be left to be insulated by tape as they are on the primary and do not need to be isolated at a high voltage for safety standards.
      I haven't seen this type of isolation much, but I found it in a SMPS sample I ordered from an Alibaba seller. It was the best one I've ever seen come from china, but they were so expensive that profit wouldn't be attainable unless they were sold en mass.
      However, here's some things it had for those curious:
      1" isolation between primary and secondary on the circuit board. The transformer was extended to stretch over the gap.
      Transformer windings were double insulated, with another layer of insulation on top of the double insulation. This gave the wire enough insulation to exceed the insulation that the transformer you've listed above had without any tape or insulators.
      As for filtering caps, the PSU was rated 12v 30A. So 360W. It made every bit of that power. Primary were 2x 100uF 400V Samxon caps in parallel. I don't remember what series. As for the output, they were also Samxon, they were all 25v caps, 1000uF. There were a lot of them, my guess is somewhere between 6-8, I can't remember as this was a long time ago when I was first entrepreneuring into the online world of selling things.
      The PSU was rated for 75k hours at max load. It was also fan cooled, and not like the shit ones you see on eBay. The case was molded so on the side walls of the interior of the PSU, there were heatsink fins sticking out. There was a fan on the inside in the rear pulling air through.
      IMO I wish I could've sold those power supplies, but hell 10 of them would've been 700$ before shipping, tarrifs, customs broker fees, etc. So in the end, I'd have to sell them for a minimal profit probably 150$ each. Unless I ordered a bunch of them, the price didn't go down, and they were very firm on the price, I tried to haggle with them for a week and they wouldn't budge. They knew damn well the product they were making was worth the money.
      Popcorn.
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        #1383
        For your eyes only:
        4 "Powertech" power supplies
        Worst quality psus available here in Greece. They cost 15-20€. Really bad!
        Let's start.
        Powertech ATX-420W
        -No PFC
        -No input filtering. Just 2 Y caps and thermistor
        -330uF main caps
        -group regulation output toroid coil with size of the 3.3V toroid coil!
        -tiny 3.3V toroid coil
        -output filters: just 1 cap per rail
        -HQ caps, some bulging
        -1x 16A rectifier for main output voltages
        -WAM fan
        -paper thin heatsinks
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #1384
          Powertech ATX-450W
          -No PFC
          -No input filtering. Just one thermistor
          -330uF Canicon (no, you can't!) main caps
          -group regulation output toroid coil smaller than a 3.3V toroid coil from a semi-decent psu
          -output filters: just 1 cap per rail, 1 bulging
          -serious heat damage in secondary section near 12V rectifier and diodes
          -HQ caps
          -16A rectifier for main output voltages
          -WAM fan
          -no fan controller
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            #1385
            Powertech ATX-530W
            -No PFC
            -470uF main caps
            -group regulation toroid coil small
            -output filters: 2 caps per rail, no coil
            -HQ, Cheng and Asia X caps
            - S1645CT @ 3.3V
            MBR2045CT @ 5V
            F16C20CT @ 12V
            -WAM / Legend fan
            I got 2 "530W" units, one made at 2012 and another at 2013.
            The first has its fuse blown along with some resistors and diode that are part of the 5vsb circuit.
            Pics attached:
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              #1386
              And pics of the 2013 unit. It works but the PG cable needs re-soldering to PCB.
              I wouldn't use it in any computer though.
              • goodpsusearch
                • Oct 2009
                • 2850
                • Greece
                #1387
                Wait! I found another one!
                This is sold under a different brand name, aqprox! and the model is app500PSBULK. Slightly better than Powertech versions, still catastrophically failed
                I think that some not trimmed leads touched the metal case. The metal case of these units is thin like aluminium foil and there is no insulation sheet.
                Nothing different than the 530W Powertech versions, except the better heatsinks and the nearly complete AC mains filter (no MOVs)
                Not worth repairing. It will be used for parts
                  master hoarder
                  • May 2008
                  • 12175
                  #1388
                  Originally posted by goodpsusearch
                  For your eyes only:
                  Ouch! That's quite pricey for such crap.
                  Then again, even in the US, $15-25 will only get you crap as well (at least brand new anyways). Now if you are willing to spend $30-35, you can get decent respectable PSUs like the Antec Basic series or ThermalTake TR2 (sometimes even with a $10 rebate). Neither of these PSUs is great, but they are loads better than Diablotek, Solid Gear, and Logisys.
                  Anyways, I doubt any of the PSUs you posted would do even half of their labeled power in spec. All look pretty terrible. The burned 5VSB sections are likely due to the output caps on the 5VSB failing and thus causing all sorts of problems with regulation and overloading on the primary. At least they have 16 Amp rectifiers for the 12V rail, so that makes them semi-capable of something.... or maybe not, given those small output toroid inductors.
                  Meh, why am I even wasting my breath (or rather HDD space) saying all this - these PSUs are only good for parts (and not that many great ones, either). The 120 mm fan is probably the best one. And that's probably only after you lubricate it properly.
                  Yeah, that's quite possible. I posted a crappy L&C a long while back that had a blown fuse. Nothing else seemed wrong with it, and indeed it looked like something had arced to the metal case (due to no insulation sheet). I never bothered trying to fix it, but I wouldn't be surprised if that's the case.
                  Shame about that aqprox, though. Doesn't look that bad of a unit. If it had output PI coils and bigger output inductors (and maybe a bigger main traffo), it would have made a passable 200-250 Watt unit. It's got pretty decent heatsinks, actually.
                  • kevin!
                    recapping PCB.
                    • Jul 2013
                    • 195
                    • España
                    #1389
                    I repaired an equal equal, belongs to a friend, is equal to yours from the photos but 650w, literally blow the 5vbs capacitor, but after doing 30,000h, change all the capacitors of the HQ brand and for now works well , but I have recommended a thousand times to change it for a good quality Seasonic ... And to top it off, I was wearing a fake PFC ...
                    Approx buys PSU from China and they are misleading sources.
                    Apart from my friend, years ago I had an approx of 500w and I corrupted the HDD partitions and the HDD accumulated pending sectors, the PSU just crushed to the ground. And since then I learned the lesson, to buy good quality PSU.
                    Gaming pc:
                    nVidia RTX 3080 TI, Corsair RM750I.
                    Workshop PC:
                    Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                    Server:
                    • PeteS in CA
                      • Aug 2005
                      • 3580
                      • USA, Unsure of Planet
                      #1390
                      Blech! I wouldn't use the 4X0 watt PSUs for more than 200W continuous, and the 5X0W PSUs might do 250W, depending on the input rectifier ratings. Those are really atrocious!
                      PeteS in CA
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1865
                        #1391
                        With nothing in spec. No PI coils and no spaces to add them.
                        Main rig:
                        Gigabyte B75M-D3H
                        Core i5-3470 3.60GHz
                        16GB DDR3-1600
                        Samsung SH-224AB DVD-RW
                        Delux MG760 case
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #1392
                          I got 13 Deer/L&C/Allied/Solytech power supplies for free, but most of them are badly burnt due to fan getting seized.
                          I am going to post some pics without many comments. Τhere isn't much to talk about anyway, because there are hardly any parts inside these power supplies
                          Premier DR-8400BTX (MAX 400W)
                          Have you ever seen a power supply so badly burnt?
                          The fan that seized is a "Muhua Fan-Tech".
                          What I like here is that the PCB was evenly burnt in most of its surface! The output caps are all bulging, the cables have burnt too!
                          The primary transistors 2x D4206 are rated for 7A continuous, worse than 130007 rated for 8A.
                          12V gets 2 DIODES on a bracket, there is not a single pi coil on that psu!
                          Edit: 5vsb survived! The rest is dead.
                          Last edited by goodpsusearch; 01-09-2018, 06:11 PM. Reason: Added info about working state of power supply
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            #1393
                            Same unit, same failure: Fan seized (80mm sleeve bearing Globe fan), heat did the rest.
                            The toroid coil is done
                            But it still works!
                            3.3V: 3.13V
                            5V: 5.08V
                            12V: 12.5V
                            -12V: -12.02V
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              #1394
                              Another Premier DR-8400BTX (MAX 400W) dead from stuck fan:
                              This one is dead, 5vsb ok.
                              • goodpsusearch
                                • Oct 2009
                                • 2850
                                • Greece
                                #1395
                                Premier DR-8460BTX (MAX 450W)
                                Better quality with improved parts:
                                2X P13007 switching transistors
                                SB3045ST for 5V rail
                                SB1060CT for 12V rail
                                Still it's a PoS. Still, the fan seized
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  #1396
                                  Force DR-8460BTX (MAX 450W)
                                  This is not an APFC unit, but both the 2 x Anodia 470uF 200V main caps are bulging and their capacitance is ~5uF and the esr ~60ohm.
                                  Why?
                                  • RukyCon
                                    A Fake Rubycon
                                    • Jan 2017
                                    • 816
                                    Why?
                                    Maybe someone set it to the 110v mode. (If it has one)
                                    • goodpsusearch
                                      • Oct 2009
                                      • 2850
                                      • Greece
                                      #1398
                                      It doesn't have a voltage input selector. I just replaced the bulging main caps and the psu works
                                      • RukyCon
                                        A Fake Rubycon
                                        • Jan 2017
                                        • 816
                                        The only other things i can think of is either there was a voltage spike which killed the capacitors or the capacitors are not really rated for 200v.
                                        • goodpsusearch
                                          • Oct 2009
                                          • 2850
                                          • Greece
                                          #1400
                                          Force SL-8600EPS (MAX 600W)
                                          The PWM/supervisor combo is the chip of the year "2012".
                                          -Nice 120mm fan and black color
                                          -SBD20C100T for 12V, good enough
                                          -2x KSH13007A and ERL-33 size transformer limit this unit to 250W max output, but it probably wouldn't be able to deliver anything without ripple being out of spec with that terrible 1 cap per pair solution.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
