the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • c_hegge
    • Sep 2009
    • 5219
    Re: the gutless, bloated, and fried power supply hall of shame
    I actually thought that iMicro PSU looked a bit like a Sun pro. I had a "550W" Sun pro once which even had similar heat discolouration to that. I don't know for sure, though. Sun pro don't often use ChengX caps.
    The model number does seem a lot like a Sirfa/High Power, but it looks nothing like any Sirfa PSU I've ever seen before.
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      #642
      Originally posted by shovenose
      What do you mean??
      How much does that hardware equal in continuous and repetitive peak watts (approximately, obviously). I'm pretty much a computer user, not a technoid life form who gets up to his elbows in computer hardware.
      PeteS in CA
      • Behemot
        • 4845
        • CZ
        #643
        That very much depends on used CPU *and* voltage. But as for graphics, you may want to have a look at this usefull page: http://en.wikipedia.org/wiki/Compari...ocessing_units States 9800 GX2's TDP for 197 W.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Ah... I think the PSU could sustain 150-250W
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            It does look like a Sun Pro...Here's the one I posted a while back
            https://www.badcaps.net/forum/showpo...&postcount=422
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              This PSU seems to be designed by a bunch of monkies (thanks Topower ) They used genuine Sanyo TT2194 12A (20A pulse mode) switchers on the primary, with a Fairchild standby transistor, 8A bridge rectifier, 20A for the 12V and 3.3V, 30A for the 5V (all made by ST)....but WHY would they plague it not just with Fuhjyyu, but General Purpose Fuhjyyu caps?! (Those primary Fhy capacitors are actually 330uF too) It runs nice and cool with those dual fans, I think the secondary heatsink would overheat with just one fan. I think I will recap it for a low power build, I really wish it had PI coils though.
              That PWM controller that you can't read by the pics is a UTC TL494L
              One question though, that Fuhjyyu cap next to that standby (?) diode (in the last pic) is 470uF 25V. Seems like a strange value for that area but should I be able to replace it with a 16V cap?
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                Here ya' go!
                http://www.psudatabase.com/epower-ep...-power-supply/
                • PeteS in CA
                  • Aug 2005
                  • 3578
                  #648
                  Wimpy heatsinks, smallish main transformer ... Should be OK for 200W, maybe 250W, depending on that transformer. Standard 1KV (I think) DC caps instead of real Y caps = NOT GOOD!
                  PeteS in CA
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    ^ the transformer is size 33. It is short but pretty fat, I think it'd be good for at least 250W because the cooling is good. Definitely going to get rid of those "Y caps" they supplied, there is another one by the input caps labeled CY3, does that have to match the specs of CY1 and CY2? Putting real ones there and a filter coil won't be a good input filter but at least it's something!
                    • jamesbo
                      • Aug 2011
                      • 36
                      ePower is the retail line for Topower, but they stopped manufacturing their own power supplies. They are manufactured by Powsun, which is the the new name for Leadman. The name itself is the union of PowMax and SunPro, if I remember correctly. Check out the Power Supply Model Nuymbers and Pictures, they are Leadman.
                      http://www.itxpower.net/en_products.htm#a
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Such a shame that Topower started using Leadman....I hope their reputation goes down the toilet for using them.
                        Here is a Coolmax made by Sirtec. Bulging Teapo caps, what a surprise! Every single cap in this thing is a Teapo. Rather weak 2SC2625 switchers, don't know why they didn't use the 2SC3320's.
                        Looks to have two 12V rails...until you see it only has one 12V rectifier, and there isn't a slot for a second one. I will have to remove the heatsink to see the specs of them. You can't see them really in the pictures but there are two HUGE PI filter coils under the wires. They're each 10x20mm and shrink wrapped.
                        That daughter-board is housing a SG6105DZ PWM controller and an LM339N comparator. The crappy T&T fan is going to be replaced, nothing but trouble with that brand, and it's LOUD even on the lowest speed setting
                        • mariushm
                          • May 2011
                          • 3799
                          #652
                          It's a HPC-460-N12s ... lying on the label.
                          http://www.highpowersupply.com/hpc430n12s.html
                          hpc-430-n12s says 14A and 16A for 12v rails, 300w total. And 150w on 3.3v and 5v.
                          The 460w wouldn't ever be 380w on 12v, probably 320-340w max.
                          Yet coolmax advertises it as a 500w psu with 180/380 wattage.
                          Considering how many cables are there it doesn't surprise me than the teapo leaked .. who knows in what system this psu was in the first place and how dusty/hot it was.
                          Looks good for a 2006 power supply.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            It does look good for a 2006 PSU. And the heatsinks look really nice. It has a two PCI-E connectors (6 & 6+2) so you're probably right, they probably had a nice video card hooked up to it. So you think it's really a 400W PSU or not even? It'd probably need beefier switchers
                            • mariushm
                              • May 2011
                              • 3799
                              #654
                              It's a 460w honest psu, labeled as 500w by coolmax, with i would say 520-550w numbers on the label.
                              It says on the label in the corner, hpc-460-n12s so you can estimate what it was rated for by going with the 430w model listed on the sirtec site, the one i linked to. I couldn't find a 460w model, probably because it wasn't sold under high power brand.
                              2006 is written on the pcb, but it could be a 2005 design fabricated in 2006, or it could be a 2007 psu using pcb from 2006, you get the idea.
                              It's still good psu for that time, that's all i'm saying.
                              • Pentium4
                                CapXon Be Gone
                                • Sep 2011
                                • 3741
                                Thanks for the link. Judging by the label it was made in the 31st week of 2006. I think I will keep it
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  I refuse to put any Leadman unit in the build quality pictoral so I'm putting it here Although it isn't as bad as some...It has what I think are fake 1000uF NCC KMG input caps. It only has one part on the primary heatsink and it is an ST W12NK90Z MOSFET rated at 11A 900V, how many watts would this thing be good for? The secondary has a 40A schottky for 12V and 30A for 3.3V and 5V. On the 12V filtering it only has a 1500uF 25V cap
                                  Is this a two transistor forward design? Would this thing have ridiculous ripple?
                                  I was looking back on this one....Any particular reason they used a 25V capacitor on the 12V rail? Maybe just to get a higher ripple rating, or for some reason is 16V too low there?
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #657
                                    Yeah mostly it seem they have higher ripple with voltage. Seems like Samxon RS is the exception here
                                    Or they just had 10000 pcs left?
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Because no logic actually goes behind designing a Leadman PSU right?
                                      • Rulycat
                                        • Apr 2010
                                        • 724
                                        #659
                                        I'm pretty sure there are only two guys in charge of the company - A guy who knows how the PSU works, and a purchasing guy. The purchaser just asks the engineer "Would this part work?" "Nope" "This part work?" "Close enough" as they flick through a catalogue of the cheapest components.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          This cracked me up
                                          I think maybe they might have had a reason for a 1500uF 25V cap there. I replaced it with a 3300uF 16V KY cap, and removed the minimum load resistor, fired it up and the 12V read 12.59V....in spec but very high. I put the minimum load resistor back in and it didn't change the results at all, so I'm thinking the cap might have something to do with it? the yellow wires on the 24 pin connector sit around 12.52V but the other yellow wires read sometimes up to 12.61V, although after letting it warm up, it goes down a little bit to 12.57V. It's powering a P4, 9800GT, and 3 hard drives so there is plenty load on the 12V line
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
