Hi everyone, I know this may be a long shot, I'm looking for some help with the 24 volt power supply for my marine return water pump. the issue I have is the controller thinks the pump has a blockage so it wont power up the pump, what I'm hoping I can do is fool the power supply into thinking the pump is ready to run, I can't find any info on repairing this controller online, can anyone help?
Jecod DCS3000 marine 24v pump
Re: Jecod DCS3000 marine 24v pump
Jebao/Jecod DCS-3000
Likely the BLDC motor controller has a problem like a failed mosfet or bad capacitors, or the impeller is jammed. Take the controller apart and post pics. I would also check the power supply is working at 24VDC.
From the manual, "The LED will display a flashing error code when a fault is detected. Error code explanation is as below:
Er01: Abnormal Working current - Check if the pump power adapter is functioning correctly or broken.
Er02: Controller overheating - Check if the controller exposed to the direct sunshine or is in a high temperature environment.
Er03: Pump idling - Check if the pump is working dry.
Er04: Impeller stops running - Check if the impellor is dirty or jammed.
Er05: Abnormal Working voltage. Check the input supply voltage.
You're getting Er01 or Er04?Comment
I get an error for impeller jam, it's not jammed, I've had it all apart and cleaned it, I have tested the 390uf caps both come back as 414uf I'll check the input voltage and get some god quality pictures uploaded, I have both caps out for testing got funny results when they were in the boardComment
Mine does not have a display showing Er.. it has LED lights that stay on to signify the issue.Jebao/Jecod DCS-3000
I have checked the input voltage from the power supply is 24.4V I will be replacing the two caps I removed from the board as one started to leak when I was trying to fit it back into the board and it now reads as 512uf so new ones on the way though I don't believe this is the cause of the issue. I have attached pictures of the control board one of which shows the error being given, It's showing the same error with or without the pump connected.Attached Filesif you find these attachements useful please consider making a small donation to the site
The model is DCW or DCS in your thread title?
It's hard to work with a board that is conformal coated, you need needle probes.
Reading IC numbers takes a magnifier and bright light at a sharp angle.
I would test the three motor driver mosfet ICs for shorts, and check the motor does not have water in it. On diode test, go from each motor output wire to GND and +24V and see if you get a diode reading or not.
The motor current-sense seems to be the R100 resistor going to the MCU, not much to go wrong with that.Comment
Hi Eccer0r,
I have had a look at the pump several times now all is there and in tact, is there any way for me to power on the pump to check it works or any resistance checks I can do across the 3 wires of the pump?
With cover on the LEDs that light up match to No.3 'the impeller stops running' code. With the pump out of the water or in the water and powered up it jigs/stutters a few times and then pops the error code, with the pump disconnected from the controller it take a lot longer to pop the code but eventually does.Comment
Hi redwire,The model is DCW or DCS in your thread title?
The model is as in the heading DCS3000 the DCW manual is what was provided to me with the pump
I cleaned of one of the IC's and took a picture, I see 4614B and BA4Y12 do you know what I should be probing and what I should be seeing please?
also I did a quick needle probe on the components next to the ICs got some different results 4 showed 1.4kh and two showed 0.8kh. I've edited a pic to show the results, thanks for your help.Attached Filesif you find these attachements useful please consider making a small donation to the site
The motor power-driver IC's are AO4614B dual P+N ch MOSFETs, arranged in a 3-phase H-bridge.
With the motor disconnected and power off, I would check for shorts between the source and drain of each mosfet, 6 junctions to check. So on one IC, diode-test between S1, D1 (pin 3 - 4/5) and S2, D2 (pin 1 - 8/7)- in both directions - so 12 readings to consider. Or try ohms, you should not get a low reading. The motor output leads go to the source-drain connections of each mosfet, it might be easier to put a probe there than on the IC pins.
Also, between the three IC's, the readings should be similar they are wired the same.
My wild guess is one may have shorted so the motor controller sees motor current flowing - when all mosfets are off. Other things might be wrong, but I usually start here.Last edited by redwire; 07-30-2020, 03:33 PM.Comment
The reason why the LEDs look suspect is that there are 6 "off" LEDs in the manual for code "3" and you have only 4... that's why I'm confused. But anyway assuming the result is correct...
Since this is a BLDC motor, you can't simply connect power to it and expect it to work. However each of the three wires should be connected to a winding, so you should see a low resistance between each of the three wires. If you don't, that's a tip off the motor or wiring is blown.
Then the next thing is measuring the voltage of each of the three outputs as it tries to drive the motor. They will vary as they step through. Each of the voltages should be switching fairly rapidly up until it gives up... if any of them aren't changing then the halfbridge driver for that wire is suspect (or the winding is somehow shorted.)Last edited by eccerr0r; 07-30-2020, 08:08 PM.Comment
There are 10 speed LED's on the board but only 8 visible on the front overlay, it's kinda confusing. The bigger pumps have 10 speed LED's visible, so it must be the same board used across the line up.
Maybe check the obvious, continuity across the motor's three windings.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks redwire
so on Diode test the results I get are below.
S1(Neg) to D1(Pos) (3-7/8) two show 0.5v one shows 0.0v not open ciruit
S1(Pos) to D1(Neg) (3-7/8) two show .0L open circuit and one shows 0.0v
S2(Neg) to D2(Pos) (1-5/6) two show .0L open circuit and the other shows 1.7v
S2(Pos) to D2(Neg) (1-5/6) all 3 show 0.5v
I'll get some ordered up hopefully this will be the extent of the issue, I will report back once I have replaced it and tested thanksComment
Thanks eccerror,The reason why the LEDs look suspect is that there are 6 "off" LEDs in the manual for code "3" and you have only 4... that's why I'm confused. But anyway assuming the result is correct...
I have checked the motor winding and do indeed get a low resistance between each, It changed when I moved the motor impeller though I assume this would be normal as you are changing the magnetic fields when doing so, I have checked the output voltages I can see two of them pulsing and one is not which fits with the diode test results looks like with the help of you guys I may get this puppy working again thanks.Comment
The IC's have arrived, I installed one and it worked for about 15 seconds then stopped and went back to the way it was, I tested the new IC and found one of the circuits shorted, I swapped it out and tried again didn't work at all this time, retesed same issue, thought I might have a bad batch of IC's tested another new one off the board it tested good, went to fit it and damaged the board
looks like I've stuffed this up, thanks for all your help though guys
by master3112I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on... -
by ronnygraciasThe treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...4 Photos
by fauzanmintIs it ok installing a Type-C adapter on a laptop when the charger controller IC is removed? I am repairing a laptop with a burned charger controller IC, and after replacing it with a new IC, it burned again. I want to check the voltage on the ics pin without the Type-C controller IC solderedYesterday, 08:43 PM
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by sam_sam_samI recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
However I would like to know if I could figure what happened to this controller board if possible
Tomorrow I will take some better pictures of both side of both boards
The... - Loading...
