Logisys 575W
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Logisys 575W
    Well, remember that thread a long time back that I started asking about the quality of this power supply? Well, I finally got a hold of one, a brand new one too. Boy, logisys and keerda (the OEM) must have been watching that thread, because it is MUCH different than the one I saw back then. I was meaning to get pictures about a week ago, but the crappy camera I was using crapped out and couldn't take pictures. Sheesh. Anyways, I've done some upgrades since then, so these aren't completely original pictures. I'll point out my upgrades though.
    Lets start with a label shot:
    How well did the secondary schottky's agree with these? Well, it had a 30A, 45V schottky on both the 5v and 3.3v, so no go on those. But, the 12v had a 30A, 200v schottky on it, so yes there.
    Now a overview of the entire unit:
    It's actually not that bad looking of a unit. I like the sleeving on all the cables, but it doesn't go all the way up all of them. The cables are good. On the 24pin connector, they are all 18 gauge except for the negative voltage wires. The cpu connector is 18 gauge, too. The pci-e connectors are more disappointing, being 20 gauge, same with all the disk drive connectors and two, yes only two, sata connectors.
    Now with the cover off. You can see the transient filter over there, came with a nice coil and two 2000pf Y caps. The original X cap was a small .1uf one, replaced with a .47uf one. The bridge rectifier is a 600v, 6A part, I added that heatsink. The main caps are 200v, 820uf. What brand? This is the shocking part, I will cover that.
    Don't know if you can see it, but those are Nippon Chemi-con's. Yes, I did not add those.
    Primary switchers, two D209L's, 400V, 12A units. You can also see the two transistors for the 5vsb.
    Secondary schottky's. This unit is definitely designed to be more modern, as it does not have spacing for two schottky's on the 5v, but on the 12v instead. I took advantage of that by adding two 60A, 45v parts there. Yup, 120A of capacity on there. A 70A, 30v part regulates the 5v, and a 60A, 45v regulates the 3.3v. No, I don't overbuild my units
    Secondary caps. I replaced the two caps for the 3.3v with nichicon PW. The rest are unchanged. Anyways, heres a short list:
    3.3V - 2x 10v, 1000uf BH 105C LESR
    5v - 2x 10v, 2200uf BH 105C
    12v - 1 16v, 2200uf BH 105C and 1 16v, 680uf BH 105C
    The small caps are some BH, and others are Nicon. I haven't heard of them, but they have the same series names as UCC. KME. Probably just imitation.
    Now, keerda makes some OK units, this one is a ATX-300A. The OPP set for this is a about 300W, and this is how keerda/logisys got past it. They removed a resistor that controls the OPP. I want to find the value of the non-ripped off one and fix that.
    The fans are BanDiKai brand. Nope, never heard of them either.
    Overall not that bad of a unit if it weren't for the secondary caps and the ripped off OPP resistor. Though, you can't take all the blame off logisys because keerda did it for them and added two pci-e connectors to it.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Logisys 575W
    still not safe, but its a start. nice job re-building it!
    sigpic
    (Insert witty quote here)
    • etnietering
      • Apr 2009
      • 379
      Re: Logisys 575W
      I noticed that my logisys has a resistor that's been cut out - I thought it was absolutely mental! Now I know why!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        Re: Logisys 575W
        anyone notice the logisys site?
        pot leaves and dragonflies?
          by momaka
          03-12-2025, 03:42 PM
        • flibidy
          Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
          by flibidy
          I have here a Magnum IA.100 which belongs to my parents.
          The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
          Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
          What Ive done........
          01-01-2025, 01:26 PM
          Copy DMI info easily with Hex editing software and Macro script
          by SMDFlea
          Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
          Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
          02-28-2023, 02:14 PM
        • ZixuTech
          Dell XPS 15 9570 - LA-G341P - Power cycling after liquid damage and blown ISL88738
          by ZixuTech
          I am dealing with this LA-G341P, which had heavy liquid damage around the Audio board, Battery charging circuit. I went and cleaned liquid areas and left the audio board disconnected.
          It had blown PQ1900/02/3 as well as a trace on PU1900. I replaced all 4, and now it turns on and switches off. With a connected battery, it turns on and stays on for a while, even loading the system, then cuts off suddenly.
          Charger only - without a battery, the PQ201/PD200 area gets hot. I can see the chipset and CPU also warm up for a second trying to pull up to 2A, then cust off....
          10-22-2022, 10:33 PM
        • b0n3v
          [Help]Reading EC - T14 G1 AMD with RT809h
          by b0n3v
          Hello everyone!
          I try to read the EC ITE/IT8300FN where the bios password is stored.
          The laptop is Lenovo T14 G1 AMD Ryzen 4650U, the MB is NM-C801.
          I can't read the chip with RT809H with ITE board and PFC cable. Might be I need to do something more to enable programing mode(SPI Enable?).
          I saw the post in another forum for T14s AMD (different MB but same EC configuration and pinouts) and one user successfully read and write the the same chip with SVOD3.
          Some details what i did:
          Battery and CMOS battery is unplugged.
          I click Read and then...
          05-15-2023, 04:02 AM
