Re: $20 "500W" PSU From MicroCenter, how bad can it be?
I just bought one for myself the other day and had some time to (test ) play with it and it seems work pretty good on a switching power supply that I had modified to work with out being hooked to a computer
I had posted the story about earlier a new twist on a switching power supply
Yeah, a lot of our PSU experts/fellas are gone now, or at least not on BCN anymore is what I mean.
c_hegge, 370forlife, Pentium 4, and probably a few more. I haven't heard from Everell either. Hope everyone is alright, but perhaps not here simply because they're busy with their lives.Leave a comment:
Can you upgrade capacitors (from 1000uF to at least 2200uF) on the secondary to check how much ripple goes down? 250mV is absurdly high, too much even for quick tests.
Also 220uF on the primary means that, if used on 220V, we would have ~110uF. Way too low even for a 200W power supply.Leave a comment:
Wow, I wonder if they used human hair or cat whiskers when doing clearance checks?
More seriously the soldering looks really good, the problem is the PCB routing/layout!
It is also so bizarre because it has high voltage cutout slots.
But then these clearance mistakes that makes you wonder if they thought they were designing for a 24VAC supply, not 240VAC!Leave a comment:
(The arrows point to the legs of the NTC Thermistor).Leave a comment:
That Rubycon looks original to me, manufactured week 43 2013.
I think the theory holds that it is a scavenged cap, how else would it be so dirty?
Did you check if the thermistor was in circuit or it is bypassed by the crap PCB/soldering?
Nice info about the DC load
Oh and I'm glad you didn't kill it with 240v with the switch set to 115v, that would be cheatingLeave a comment:
Note: if anyone is interested, I posted a separate review of the electronic load here: https://www.badcaps.net/forum/showthread.php?t=86168 (and this time I used a PC Power & Cooling Silencer 750W with a 60A 12V rail to give it a real test).Leave a comment:
One note if you think are fake replace if feasible and not too hard to get two
Thanks for your feedbackLast edited by sam_sam_sam; 07-18-2020, 05:33 PM.Leave a comment:
So how do you like your new toy
How accurate is it and do you have any complaints about the quality of this product or use of this product
I might be interested in buying one for myself
I do have a question for you about the cv setting what does that function really do does it load it to keep it at a certain voltage
The quality seems decent enough for a $145 piece of test equipment. You can definitely tell it isn't "high end", the case fitment isn't the greatest, and the buttons feel a little cheap, but it seems to work well enough.
Accuracy and internal construction appears to be pretty good considering the price point:
Of course since UPS just dropped it off this morning I can't comment on long term durability.
Ebay, here's the link to the listing I bought it from: https://www.ebay.com/itm/30A-Dual-Ch...53.m2749.l2649, but these are all over Ebay, Amazon, etc.
Cool, will you put in some new diodes and see if you can get another component failure?
(Or, as you're in 115v land just two are in use... Heck, the PCB even has provision for a FOOL BRIDGE RECTIFIER)
Also would be cool to know if that NTC is doing anything or if it is shorted out by the PCB as it looks.
And also if those primary Rubycon caps are real or not
I do have 240V in my garage/shop in addition to the normal 120V outlets, if the PSU didn't fail on its own the plan was to leave it set to 115V and hook it up to the 240V but that didn't end up being necessary.
I think the "Rubycon" primary caps from that SolidGear PSU are fakes, the coloring/font seems "off".
They do appear to actually be 220uf though testing at 212uf:
Did you buy the DC load on Aliexpress? It looks quite nice!Last edited by Per Hansson; 07-18-2020, 03:35 PM.Leave a comment:
I do have a question for you about the cv setting what does that function really do does it load it to keep it at a certain voltageLast edited by sam_sam_sam; 07-18-2020, 03:37 PM.Leave a comment:
My new toy showed up early:
Sadly there were no fireworks this Solid gear PSU failed with a whimper rather than a bang.
Here is right before the failure, there is 18.7A of load on the 12V rail and 10A each on the 3.3 and 5V rail for a ~307W load. As you can see the 12V rail is around 10.4V, you can't see them in the pic (since the 2 smaller electronic loads are sitting flat on the bench) but the 5V was also below 4V and 3.3V below 2V, so way out of spec. A few seconds after this it shut down never to power up again.
Analyzing the failure there are no burn marks and no blown up components. It looks like the failure point was the 4 diodes for the bridge rectifier with 2 showing completely open and one showing 2M ohms (so basically open).
I've seen such a fuse in an A-Line crap PSU.
Strange seeing them so gutless, usually most of my units were either some stupidly designed Deer (spots for PI coils but the traces didn't go anywhere) or mid-end Yuelin units (and KME, usually for their compact size PSUs),not some absolute no-name garbage.
That, and newer 2012-made Delux PSUs use a similar type of glass fuse, but in a different package. Those are at least mostly reedeemable 250W units, if you're finding soldering quite a few components in there fun (3x PI coils, common mode choke, Y cap, a X cap and that's mostly it.), whereas A-Line is best avoided, unless they're older Yuelin units (as those are semi-decent)Leave a comment:
Yah, MicroCenter hasn't really made its way to PA yet (with the exception of one location in the Philadelphia area) so for me it means a trip to Northern MD. (which is closer to me than Philly).Leave a comment:
Ahh ok, I did see there was something there, but could not imagine it was a fuse so small!
Anyway it does not really matter: it is on the wrong location of the PCB.
So even if it blows the arc will probably not be interrupted and the house will burn down.
See attached photo for why, clearance, what is that for?
(The yellow rectangle is the location of the fuse, and the blue rectangle is where it should have been).
Good catch!
And OUCH, that is seriously bad cost-cutting idiocy there.
Fortunately, I don't think this can make the house wiring burn down. Look at the wires going to the voltage selector switch and also to the IEC plug - they look like AWG 22 at best. Most likely they would smoke and glow for a few seconds in the event of the fuse not working properly, but could eventually act as a secondary "fuse".
Mmmm. The smell of freshly burned PCB.
Incidentally the only thing that looks decent in that PSU is the ground wire from the IEC receptacle.
That is good for when the mains wires burns off the PCB due to the fuse fuckup:
When the wire then falls against the chassis the house fuse can do its job, or much better GFCI if present
Incidentally that ground cable looks so good that I wonder if the children scavenged not only the Rubycon primary caps but also that ground cable from a decent unit at the city dump.
EDIT: Since the fuse is in the wrong location the 115/230 voltage selector switch is unfused:
https://www.badcaps.net/forum/attach...1&d=1593987874
https://www.badcaps.net/forum/attach...1&d=1593987874Last edited by Per Hansson; 07-16-2020, 05:11 AM.Leave a comment:
But hey! On the other hand, at least you had the right idea: grabbing a crappy gutless PSU on the 4th of July. If it only was a PowMax, you might have even stolen the fireworks show, had you plugged it in.
Currently... though not fully finished yet (and may never be)... I'm using a 3000 Watt Nichrome -based heater coil from a dryer as a load for testing my power supplies. Last few to test were several 15V, 7 Amp open-frame PSUs from TDK Lambda. I was able to load each to 6.85 Amps with my setup. None of them gave any issues, as expected.
On the off chance it lights up I do have a 10 lb. fire extinguisher about 5 feet from my bench, and between the fact that this is a GFCI (RCD for those of you in Europe) protected circuit (since it is a garage) which will trip itself if any current goes to ground or can also be tripped manually by hitting the test button on the outlet and the electrical panels (plural) are right above the bench killing power is a fairly quick/easy affair.
What I'd be more worried about is eye safety, though. Definitely wear protective eye glasses when testing electronics like that. A fuse or silicon device shattering/exploding can send small piece of shrapnel quite far. Even with the PSU cover on, I think it's still a good idea to wear safety glasses in case something happens to go through the vents.Last edited by momaka; 07-15-2020, 11:20 PM.Leave a comment:
Good catch!
Also as long as the house wiring is up to code the circuit breaker (15A on a 14 AWG circuit or 20A on a 12AWG circuit) will trip to protect the wiring, so the only potential of fire should be inside of the unit itself.
Actually, if you do that, you should also try to return the PSU to MicroCenter afterwards and say it went bad in your system. Depending on the MC near you, most will take it back and return your money, no questions asked - kind of like Home Depot returns, really. Besides, I don't see a warranty sticker anywhere. Or was there one that needed cutting/removing? If yes, that might complicate the return (or not, if you did a stealthy enough job.) Not that I'm implying anyone should commit fraud, as this could be considered as so... but this PSU is already committing fraud, given how terrible it is.
As for overloading it, I recently ordered a bigger electronic load (300W) so I may do that once it shows up (right now the ETA is July 29).
On the off chance it lights up I do have a 10 lb. fire extinguisher about 5 feet from my bench, and between the fact that this is a GFCI (RCD for those of you in Europe) protected circuit (since it is a garage) which will trip itself if any current goes to ground or can also be tripped manually by hitting the test button on the outlet and the electrical panels (plural) are right above the bench killing power is a fairly quick/easy affair.Last edited by dmill89; 07-15-2020, 10:52 PM.Leave a comment:
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by flibidyI have here a Magnum IA.100 which belongs to my parents.
The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
What Ive done........8 Photos-
01-01-2025, 01:26 PM -
by SMDFleaCopying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....-
Channel: BIOS Requests ONLY!
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
- Loading...
