APC BackUPS LS-500 Schematics?
  • cook
    Quiet observer
    • May 2010
    • 100
    Re: APC BackUPS LS-500 Schematics?
    I know that this schematic I posted above isn't the exact match, but it should be good enough to give an idea what is going on.
    For me, I'd ESR the sh*t out of them caps and replace them. I've had a run in with my small SMT a few years back, it turned itself off all the time.
    https://www.badcaps.net/forum/showthread.php?t=66277
    I'd change the two brown caps, the 2 black caps next to it and C51 and retest.
    Got it, I will be replacing larger brown and black caps. I may do some more trouble shooting on the board first just to see if I can find other bad caps too.
    • CapLeaker
      Leaking Member
      • 8177
      if you see a regulator, change the caps surrounding it too.
      • cook
        Quiet observer
        • May 2010
        • 100
        I may need some help in identifying if the board has a regulator. Would that be one of the IC chips that I listed in an earlier post? Or is it something else on the board? I have pictures of the board in an earlier post.
          • Jul 2011
          • 6039
          I would definitely recommend doing the ones right next to these chip but ones you get working correctly I would highly recommend that you recap the hole board
          As far as the regulator ic chip you would have to look up each part to what kind a chip it is
          • cook
            Quiet observer
            • May 2010
            • 100
            I found a regulator. It is a LM2575T. I will be tracing down the caps that are next to it.
            It may be next week sometime before I have any results, but I will post what I find.
            • cook
              Quiet observer
              • May 2010
              • 100
              I finally replaced all ten of the various aluminum radial electrolytic capacitors on the board. The only ones that seemed out of spec. were the smallest ones - 22uF 16V ones, which were blue and made by JiangHai. There are 6 of these on the board. Some of them had very high ESR values. I have been running it for a few days now with the new caps and it is no longer beeping. So I am thinking that they were the cause of the intermittent beeping I experienced. Thank you to everyone who helped me with this fix.
              • CapLeaker
                Leaking Member
                • 8177
                good to hear that you had success!
                  • Jul 2011
                  • 6039
                  I am glad you got it back up and running
                  On this voltage regulator what was on the next line was it a 5 or was it 12 this tell you what what voltage is
                  Now if it not have anything then it adjustable type
                  • cook
                    Quiet observer
                    • May 2010
                    • 100
                    Sorry Sam_sam_sam,
                    I don't know what was printed on the next line on the regulator. It is all back together now, and I can't see that part. And it is not easy to get it apart.
                    • Rezendes
                      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                      by Rezendes
                      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                      05-10-2024, 02:18 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • WildTechRepairs
                      Chasing schematics & boardview HP laptop model 14s-dq3029TU, board model DAOPAKMB6FO
                      by WildTechRepairs
                      Gidday from Downunder,
                      Chasing the Schematics and also the board view for the HP Laptop board, model according to the board markings that is read sideways against the the side frame to the graphics card or the DDR4 slot it says the following for the Model,
                      “MODEL:OPAK”
                      Then assuming the card was still inserted into the slot, releasing the card and removing it will reveal the full markings printed on the board (not the card),
                      “DAOPAKMB6FO REV:F”
                      Below in smaller print is a small logo of I think a backwards R with the letter U with the left stroke of the...
                      11-11-2022, 07:56 AM
