APC SMT-750 turns off for no reason
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8177
    Well guy's and gal's, after 6 years of flawless service, my APC SMT-750 developed a strange behavior. This UPS hooked up to my PS3, PS4, a media streamer, a network switch and a 40" LCD TV. My kids reported that the TV or the PS3 turns off, wait a few minutes and then one can go at it again and it works for days fine as kind. As it goes Friday night = movie night. And? Riiight, middle in the friggin movie, I heard a "click" and everything turned off that was connected to the UPS. Nothing had any power. My investigation and found out that the UPS itself was still on, but it had all power outlets turned off and there was a warning that there was no batteries inserted. Hmm... so I turned the outlets manually on UPS back on via the front panel. Now the front panel shows that the battery life is over 2hrs, no errors or anything else? So I unplugged it form mains and powered it on through the batteries. Again, no errors, everything is working but the "beep" sound sounded really funky (it does this also when plugged in), but the display is nice and crisp and yet it makes power at the outlets. I yanked out the batteries and had a look. I found two 10v 330uF looking pregnant and puking their guts out. I didn't take anything apart yet, in order too see if there are any other caps that need replacing too. Anyone else with a APC SMT series UPS that has bad caps and behaves strangely and replaced caps? Probably my chances to find a schematic for the early SMT series UPS is like nill.
    • 31040
    Re: APC SMT-750 turns off for no reason
    6years running 24/7?
    total re-cap time.
    6years x365 days x24hours = 52,560 hours.
    no cap is THAT good!
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8177
      So it turned out there are actually 3 caps that are visually bad and measured bad. All other caps were fine. Those 3 bad caps are all made by IC, 25V 330uF, RZMM series caps. They are around that LM317 regulator. You can see them by taking the battery pack out, top left. Replaced those and the "beep" returned back to normal sound. So far so good. Hope that things stay that way. I guess I have to see what happens after running it for a while.
      • Behemot
        • 4845
        • CZ
        I always replaced all the crappy caps even in these new SMT units right on spot. Never trusted that crap. Guess I was right after all
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8177
          A lil update about this APC SMT750 situation of mine. Those 3 caps cured all the problems I had with that unit. Everything is working well again as it should. There are no more glitches, it won't power the outlets off anymore by itself, no more weird error messages that disappear etc. All is good!
          • petehall347
            • Jan 2015
            • 4426
            • United Kingdom
            install a fan .. come back in 12 years . renew batteries before that of course ..p.s you may have given me the fix for one i sold and came back . same symptoms . i thought it might be getting too hot .
            • Behemot
              • 4845
              • CZ
              I kinda doubt somebody wants fanned UPS in a living room. Besides, the whole fan circuitry is usually missing. But if you have the fan circuit schematic, talk no more and give it here
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8177
                The small UPS's don't really need a fan, plus it would be annoying to have one running all the time. My SMT-2200 has a fan running all the time, but I have so much other things running in the office, one almost can't hear it anymore.
                To check these caps if they are pregnant is very easy. Take the battery pack out, turn the unit upside down with the battery slot facing you, then look at the bottom right. Can't miss them they are the biggest ones there.
                • Behemot
                  • 4845
                  • CZ
                  Never actually seen any of the big boys bad in Smart-UPS, always the small ones, usually 10 and 22uF.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8177
                    funny thing is, we have two of them identical to each other. The other one is fine as kind!
                    • Behemot
                      • 4845
                      • CZ
                      If you mean the SMT, those are quite different boards though. I meant the old SU/SUA.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8177
                        these two APC UPS's here in this threat are both early SMT series.
                        • carrzkiss
                          Cyberpower cps1500avr not charging batteries
                          by carrzkiss
                          Hello, all.
                          Cyberpower Battery Backup Unit.
                          I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
                          When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
                          In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
                          Checking the voltage, it was down to 22v.
                          I quickly removed everything...
                          06-15-2024, 02:10 PM
                        • Zilicon
                          AHL50/ ABL52 LA-C701P Rev:1.0 Turns on but turned off after few seconds
                          by Zilicon
                          Hearty greetings to everyone, trust you all are doing excellently well.
                          Please, I have the above problem, the laptop turned on after the switch was activated but it will turns off in less than 2 seconds.
                          The power stables in very rare case. Once it was stabled, everything works fine.
                          Once the power switched is pressed, 5V and 3V were present.
                          The things i have done:
                          1. I have check for shorts on the board, but nothing. The board is short free
                          2. Not a power switch problem, it behaves the same without the switch ...
                          06-10-2024, 05:05 AM
                        • Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                          by Stephen
                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                          03-15-2024, 09:37 AM
                        • howardc64
                          Where do repair shops buy MB replacement batteries?
                          by howardc64
                          Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                          Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                          BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                          07-25-2024, 10:42 AM
                        • www
                          LG L192WS-BN backlight turns off after 1 second
                          by www
                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                          03-24-2024, 05:26 PM
