APC BackUPS LS-500 Schematics?
Re: APC BackUPS LS-500 Schematics?
I may need some help in identifying if the board has a regulator. Would that be one of the IC chips that I listed in an earlier post? Or is it something else on the board? I have pictures of the board in an earlier post.Comment
I would definitely recommend doing the ones right next to these chip but ones you get working correctly I would highly recommend that you recap the hole board
As far as the regulator ic chip you would have to look up each part to what kind a chip it isLast edited by sam_sam_sam; 07-05-2020, 05:47 PM.Comment
I finally replaced all ten of the various aluminum radial electrolytic capacitors on the board. The only ones that seemed out of spec. were the smallest ones - 22uF 16V ones, which were blue and made by JiangHai. There are 6 of these on the board. Some of them had very high ESR values. I have been running it for a few days now with the new caps and it is no longer beeping. So I am thinking that they were the cause of the intermittent beeping I experienced. Thank you to everyone who helped me with this fix.Comment
I am glad you got it back up and running
On this voltage regulator what was on the next line was it a 5 or was it 12 this tell you what what voltage is
Now if it not have anything then it adjustable typeLast edited by sam_sam_sam; 09-05-2020, 04:40 PM.Comment
Assuming...7 Photos -
by mrautom8Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
While relay is on, all voltage rails are present and steady (scoped) on main board.
I love a good logic puzzle but getting lost without any schematics.
No shorts on ANY capacitor main board.
Thermal camera shows 3.3V inductor getting warm instantly but...-
Channel: Schematics and Boardviews
10-19-2025, 06:32 PM -
by RezendesHello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...-
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
