110 Volt Line Conditioner ( 12 volt regulator cap failure repair once before)
    • Jul 2011
    • 6040
    About 5 years ( or ) more ago I had recap this line conditioner because it would rapidly relay clicking so that was the reason for having to recap the board
    The other thing it was doing every time the air conditioner would turn ON it would click this started about 2 weeks ago
    We have a lot of voltage dipping where I live ( 110 to 126 volts ac ) so I was not surprised that it was doing this but I have two more of units that were not doing this all time but i I did not give it much thought but maybe I should have but it is a pain in the butt to work on this unit
    Now today it did the same exact thing again so this same cap is bad again
    So I put a new cap in again and it stopped it again from relay chattering
    As you can see in the picture the of the cap that I had used before ( PW )
    The new cap ESR reading was 0.06 about twice the amount of a new cap ( LXV ) automotive grade capacitor
    It also has another capacitor on this board but it was not bad 220uf@50 volts ( KZE )
    One note about this line conditioner it about 25 years old now
    • 31067
    Re: 110 Volt Line Conditioner ( 12 volt regulator cap failure repair once before)
    solder wires across the cap and see what voltage it see's
    maybe there is a failing zener diode or drop-transistor causing overvoltage
      • Jul 2011
      • 6040
      This voltage is coming from the transformer secondary step down windings then it goes to 4 diodes then the capacitor and then goes to the voltage regulator which supply power to the two ic chips ( I will keep this in mind what you have pointed out thanks )
      The capacitor is on the input side of the voltage regulator ic chip there dose not seem to be a electrolytic capacitor on the output side which I found strange but there might be a reason for this
      Traces on this board are not very good they coming loose from the board so I do not want to do much more shit to it unless I have to ( one note there are no markings on this board for any part that are on this board )
      I will do this if it fails again in a short time again ( or - I am going to part it out and get another used one and recap it ) [ I have a project that I have in mind for this auto transformer ]
      Keep one thing in mind that it is running 24 hours a day 7 days a week and 12 month a year and over 5 years
      This is about 43800 hours and capacitors have an hour rating and how many hours is this ?
      I have had this line conditioner plug in now over night and it seems to work correctly again so we will see if it stays working
        • 31067
        maybe bump up the cap voltage.
          • Jul 2011
          • 6040
          I was thinking the same thing if it fails again real soon
            • Jul 2011
            • 6040
            Well an update
            It has been running for 23 hours now and everything seems to be working correctly
            So far so good I going to call it a successful repair
              • 31067
              i was thinking, maybe line-spikes are killing the cap
              if you get a 200v spike, the transformer will convert it down and you get an 80% increase across the cap
              does this thing have MOV's?
                It has MOV's.
                It looks like AC Line conditioner and AC Voltage regulator.
                What is the model number of this TRIPP LITE?
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  by sam_sam_sam
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                • everell
                  EVGA 500 watt with fan twitch
                  by everell
                  This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It...
                  09-15-2022, 05:50 PM
                • cubytus
                  Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                  by cubytus
                  Hi to all,
                  I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                  I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                  Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                  01-10-2024, 01:26 AM
                • disorder
                  HP 2311 display, 3.3v regulator fried, need help to replace
                  by disorder
                  hello,
                  i have a hp display 2311 to repair, totaly dead
                  on the board, il have 2 capacitor 470µf that are dead and the 3.3v regulator : ax6630-33
                  i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                  thank you
                  07-27-2025, 04:34 AM
                • TrueSword88
                  Kogan - KALED65XU9220STB - Blue Vertical Line
                  by TrueSword88
                  Hi all.
                  I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                  The line just happens to coincide with the end of COF and start of the next COF (attached).
                  The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                  Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                  Hoping to fix...
                  05-05-2023, 04:28 PM
