EVGA 500 watt with fan twitch
  • everell
    • Jan 2009
    • 1514
    This is an EVGA 500 watt Model 100-W1-0500. On power up only has a small fan twitch. Usually this is just a bad capacitor on one of the output lines. Not this time. I pulled out my storage scope and looked at the output lines during the first 10 msec after power up. 12 volt line was 11.5 volts. 5 volt line was 4.5 volts. But....the 3.3 volt line was also 4.5 volts. Couldn't find a short between the 5 volt line and the 3.3 volt line. So pulled out my multimeter and tried to find a bad component using resistance measurements. Nothing. So I took a guess that the mag-amp transistor might be bad. It uses a tiny SOT transistor marked M7A. The only cross reference I found was a MMBT2907A. So I changed this transistor and the power supply came back to life. The 12 volt line measured 12 volts and the 5 volt line measured 5 volts. But the 3.3 volt line measured 2.36 volts. Looks like the transistor was bad but the replacement must not be the correct one. Help...can anyone find a proper cross reference for a SOT transistor marked M7A.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • R_J
    • Jun 2012
    • 9550
    Re: EVGA 500 watt with fan twitch
    MMBT2907A, device marking is M7A. If the 3.3v supply was getting +5v I suspect something on the 3.3 volts line got damaged ie a zener diode used for protection.
    • everell
      • Jan 2009
      • 1514
      My replacement MMBT2907A is marked 2F. I have checked the data sheet of several manufacturers and they all agree that the marking is 2F. Perhaps not all MMBT2907A transistors are equal???
      • everell
        • Jan 2009
        • 1514
        I finally found MMBT2907A with M7A marking. It is made by Panjit. On Digikey and Mouser it is the cheapest MMBT2907A you can buy. Price is 8 cents apiece. What do you expect from a power supply made in China!
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Ummmmmmmm high volume Delta power supplies are made in Dongguan, China. Probably the same with Lite On, Acbel, Fortron/Sparkle, and [u]Your Favorite Brand[/o] power supplies. The key factors are design quality, component selection, and employee retention (= keeping well trained people).
          PeteS in CA
          • RukyCon
            A Fake Rubycon
            • Jan 2017
            • 816
            If i remember right, most EVGA PSUs are made by HEC (or at least the lower end ones are), and i'm pretty sure this particular model of PSU is part of EVGA's lowest end power supply series. I think i have this exact model floating around somewhere, and when i compared it to a mid-range Corsair 400w PSU (also made by HEC) the Corsair was somewhat beefier than the EVGA, despite the lower power rating. I should probably post pics of the two to the power supply build pictorial someday.
            I'm not a expert, I'm just doing my best.
              • Jul 2011
              • 6040
              What does this switching power supply look like inside under the hood
              Just curious about this
              • everell
                • Jan 2009
                • 1514
                I installed a Panjit transistor marked M7A. End result was the same....2.4 volts on the 3.3 volt line. I replaced the 431 regulator chip. No change. I removed the two output caps and tested for esr. Both OK. Totally frustrated, I finally changed the tester I was using. Now everything measures ok. So it looks like I was chasing a ghost!
                Conclusions: EVGA 500 watt power supply had a bad mag amp smt transistor. The transistors marked M7A and 2F are apparently interchangeable. The power supply is now in my garage powering an old KT7A motherboard and working fine. And finally, I hope I am not the only one who ocasionally goes chasing a ghost!
                • everell
                  • Jan 2009
                  • 1514
                  Found another EVGA 500 watt power supply with same symptoms. Replaced the 3.3 volt mag amp smt transistor. Original was marked M7A. Replaced it with a 2F. Power supply now works OK. Not sure if this is a design problem or just OEM using a POS M7A smt transistor.
                  • ChaosLegionnaire
                    HC Overclocker
                    • Jul 2012
                    • 3264
                    • Singapore
                    u mean u are using a power supply tester? those are notoriously unreliable for testing and checking a power supply. good ol' multimeter works best. its what i use for checking a psu's voltage levels. i never use those power supply testers.
                    • everell
                      • Jan 2009
                      • 1514
                      I was using a home made tester which had LEDs and there was a load resistor on the 3.3 volt line...which was obviously not correct. The cheap power supply testers you are referring to did a much better job than the one I was using. The real test is a dynamic test using a real mother board as a load. Both power supplies work ok using a real mother board. So the problem in both cases was a defective mag amp smt transistor marked M7A.
                      • MisterAIL
                        PS5 digital / No Power / No Beep / Good power supply
                        by MisterAIL
                        Brought a non functionnal PS5. Apparently only a bad PSU...
                        No beep, nothing.
                        After some tests i found this :
                        - PSU is fine (12 volts stable)
                        - 12 volts line is shorted
                        - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                        - By the way, nothing change. No signal, no power, no beep.
                        Mesuring all rails with my workbench psu (12 volts input)
                        - 0.00 amp drawing
                        - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                        03-12-2024, 03:24 PM
                      • Mcfeetroy
                        Fishing bite alarm drains battery
                        by Mcfeetroy
                        Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                        08-01-2025, 03:52 AM
                      • EazyBone
                        XR-85X93L Sony Mini LED No Power
                        by EazyBone
                        Been a while since I posted but I got this TV for free luckily only about a year old. I plan on gifting it to my dad.
                        Plug in the TV no power no indicator late nothing.
                        I checked the 12 volts on the power supply with nothing plugged in and it doesn't give any voltage. Check standby voltage 3.3 volts. Check PS on 0 volts. i jump PS on and standby voltage and still no 12 volts. The main caps give 178 volts. Looks like they are working.
                        Appears something is wrong on the 12 volt line. Both fuses on the board are good. I'm trying to follow the 12 volt line down if that's...
                        12-22-2024, 09:52 PM
                        12 volt switching power supply modification to 14.5 volts before blocking diode add
                        I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
                        I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
                        One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
                        04-11-2021, 11:01 AM
                      • EasyGoing1
                        Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
                        by EasyGoing1
                        I don't know the first thing about where to even start looking for the result I'm looking for ... but what I want, is a circuit ... or maybe a certain transistor ... that will remain "closed" when the voltage at the base is 5 volts, but when that voltage gets to 4 volts or less, I need that transistor to turn on - preferably with maximum saturation. I would prefer that it also does not even turn on a little as the voltage approaches 4 volts, but remains closed until that voltage hits 4 volts.
                        Now, it would be OK if it had some kind of marginal transition from zero saturation...
                        01-08-2020, 06:06 PM
