ThermalTake PurePower 520W recap
  • etnietering
    • Apr 2009
    • 379
    This PSU has been powering my main system for more than 4 years now. It powered my old P4 system, my Pentium D system, and now my core i7 system. I've run the pentium D and core i7 systems 24/7 under full load for months on end, so I've run this guy pretty hard over the years. Anyway, earlier this week my computer started having very odd errors (USB system not responding, LAN shutting down, unable to open programs, sound not working, etc) so I began troubleshooting. It seemed odd to me that so many different systems would be messing up all at about the same time, especially when most of the system is only 4 months old. And so I thought to myself, well! it could be the power supply! I had cracked it open this summer, out of curiosity, and saw it full of Teapo, but it all looked good, and so I put it back together. I was planning on doing a preventative recapping on this when I was hope over Christmas, as well as the PSU in my server (Rosewill green 420W or something).
    So I pop it open today, and find that one of the Teapos is bulging! So to make a long story short, I recapped it
    Here's the label - the 2 12v rails do have separate OCP protection. I couldn't read the part numbers, but each rail has 2 TO-247 package schottky packs, so I trust that the ratings are good.
    Here's a sort of overall before shot. The input filter is crazy! Total (including this and on the AC receptacle) there are 3 X1 series caps, 4 Y2 series caps, 3 MOVs, 2 line filters, fuse, current inrush limiter, and bleeder resistor. The big cap is a Teapo 330uF, the top was flat so I'm not worried about it. That giant wrapped coil is for the active PFC.
    Here's the secondary side. The big cap farthest to the left is the one that's bulging (obviously). The 5vsb filter is kind of visible in the lower right. The little crooked cap to the left of the main filter coil was very odd, I'll get to that later.
    Here are the improvements I made to this PSU:
    +5vsb
    1x Teapo SC 1500uF @ 10v 10mm and 1x Teapo SC 1000uF @ 6.3v 8mm -> 1x Panasonic FM 1500uF @ 10v 10mm and 1x Panasonic FC 1200uF @ 6.3v 8mm
    3.3v
    1x Teapo SC 2200uF @ 10v 10mm and 1x Teapo SC 2200uF @ 6.3v 10mm -> 2x Panasonic FC 2700uF @ 6.3v 10mm
    5v
    1x Teapo SC 2200uF @ 10v 10mm and 2x Teapo SC 1000uF @ 10v 8mm -> 1x Rubycon MCZ 2200uF @ 10v 10mm and 1x Panasonic FM 1000uF @ 10v 8mm
    12v
    1x Teapo SC 2200uF @ 16v 10mm (bulging) and 1x L-tec TK 47uF @ 25v 5mm -> 1x Nichicon HE 3900uF @ 16v 12.5mm and 1x Panasonic FM 680uF @ 16v 8mm
    The little L-tec was the one I mentioned in the other picture. I have no idea why they added a 47uF cap to help filter the 12v rail, I doubt it did much of anything. The TK series is just general purpose, 1000h rated. Lame. And since I wasn't able to stuff the giant 12.5mm HE all the way to the board (it's about 3/8 inch above the board), I decided to stuff an FM in there to help with things.
    Here is the 5vsb filter after I got done with it.
    And here we have the output filters. The huge HE was only a few mm shorter than the heatsinks.
    Here's a top down shot of the whole thing. The main transformer is huge, the same height as the heatsinks.
    After I recapped it I plugged it into a couple power resistors, and let it run for a few hours, to make sure nothing was wrong. Then I threw it back in my system, and everything has seemed to be fine since (it's been about an hour). The voltages look good, both the 12v and 5v are right where they were, and the 3.3v is a hair lower. The CPU is also running a few degrees cooler, but that's probably for some other reason.
    What d'ya guys think? It's too early to tell if any similar problems are going to happen. I'll reply back if this didn't solve my problems.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: ThermalTake PurePower 520W recap
    HEC
    I've never seen a TO-247 schottky lower than 30A, so I bet you the label is accurate, most of the older HEC's were actually pretty good units. HEC always does a good job on the input filter, as long as it's not one of those "orion" units.
    • etnietering
      • Apr 2009
      • 379
      Well to update, recapping the PSU did not solve my problems. The system ran for a day and the the USB subsystem locked up again. So upon thinking what I should do, I remembered I had an old maxtor PCI USB 2.0 card from probably 2002 that I got from my brother who got it from me who got it from my dad. So I put that in, and the system ran for about a day again, when the USB subsystem died.
      So at this point I decided I could see if there was a newer BIOS available from ASUS, and turns out there had been several BIOS releases since I got my board. I downloaded the newest one, and used the ASUS EZ-Flash software to reflash the BIOS. It booted fine and was running fine (but it had all the other times too), but then I left to come home for Thanksgiving and so I don't know the current state. I'll update again in a week once I get back.
      So the recap didn't solve the problems, but I'm sure it didn't hurt. I knew the PSU was old and I was planning on doing a recap of it around Christmas anyway, and I already had all the parts, so it wasn't a big deal to do it.
      Oh, and the 12v rail distribution is:
      12v1 : 24pin ATX connector, 4 pin P4 connector
      12v2 : everything else (molex, SATA, PCI-E)
      • etnietering
        • Apr 2009
        • 379
        Well I solved the problem - turns out it was Conficker. I got it via USB flash drive from one of my lab partners. So I downloaded and installed Avira and it fixed things real quick. Glad it wasn't a hardware issue!
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          damn conficker... yay linux and comodo free!
          sigpic
          (Insert witty quote here)
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Pry open your rosewill green series yet?
            I want to know if that is a ATNG or a solytech. I think they are ATNG.
            • etnietering
              • Apr 2009
              • 379
              Not yet, that's for when I'm home for christmas break. Probably 2ish weeks...I'll take lots of pictures for ya
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Hmmm, looking at those pictures it looks like it has 2 of those to-247 rectifiers per rail. Assuming they are only 30A each, that's 60A per rail. Assuming a common duty cycle of 30% that would be 42A per rail. Very good.
                Two thermal sensors also indicate OTP
                • etnietering
                  • Apr 2009
                  • 379
                  Sorry to revive such an old thread, but I have an update on this PSU. I replaced it... I got a new videocard for Christmas (GTX 460), which draws a bit more power than my old 8800GTS, and under heavy load the computer would just shut down. I don't know if it was the OCP (I don't know where the levels were set/what was on each rail), or the over temp shutting things down (it would take a few minutes after the load increase for it to shut down, and the air coming out the back was pretty hot).
                  So the update - all the caps I replaced are still doing great. It's been about 16 months, and the computer spent about 12 of them at relatively high load 24/7. The top of the primary cap is still flat, and all the little caps I didn't replace look ok too. I'll probably do the rest of the recap (except the huge primary cap) and then keep it around as a backup.
                  I replaced it with a Kingwin Lazer 550w, after reading this review: http://www.jonnyguru.com/modules.php...Story&reid=219 It's been powering my computer for about 12 hours at the same relatively high load, and the fan has yet to turn on. At an idle desktop (with BOINC running on 4 CPU threads and the videocard), the computer draws 400W with the old PSU and only 320W with the new one. Efficiency rocks!
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5043
                    • US
                    wow a termaltake? I've used several truepower 430's for years and one of them right now is actually running about 480-500w without even getting very hot
                    oh yeah, want to make your flash drive so it can't be a carrier of viruses...
                    make a FOLDER in the root called autorun.inf
                    no viruses that go from flash to flash are programmed to delete a folder with that name
                    • iMic
                      IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                      by iMic
                      Hi folks,
                      I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                      The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                      11-29-2023, 06:44 AM
                    • em132
                      Okay to use 6.3V caps on 3.3V line of PC PSU?
                      by em132
                      I'm currently in the process of re-capping a NOS (new old stock) Sparkle ATX-400PN (from the late-2000s), which was chock-full of Teapos and CapXons . Am looking to put a yummy mix of NCCs, Panos and Rubys in their place.
                      Here's the problem I ran into: The 3.3V rail is filtered by a single 4,700uF/10V Teapo... The problem? This thing is only 10mm wide, and a wider (12mm) cap will not fit! I've searched the "big three" shops (Mouser, Digikey, Newark/Farnell) and all the 4,700uF/10V I found were at least 12mm wide. The closests matches I could...
                      05-30-2023, 03:41 PM
                    • bauto601
                      KDM 480W PSU upgrade succes! (opinions?)
                      by bauto601
                      Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                      A "nice" YoungYear unit? - Badcaps
                      The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                      12-26-2023, 03:05 PM
                      by momaka
                      03-15-2023, 10:17 PM
                    • Topcat
                      4700uF 6.3v and 3300uF 16v in a 10mm Diameter
                      by Topcat
                      Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
                      10-14-2020, 06:35 PM
