Help with a non PC PSU
  • silencery
    • Apr 2020
    • 6
    New to this community, but I'm hoping someone can help?
    Long story short, we recently had an extended power outage. For whatever reason, at least 3 dozen households in our area experienced thousands of dollars worth of electrical damage once the power came on. In our case, we lost the water heater, dishwasher, smoke alarms, and dozens of smaller electronics.
    One of the smaller broken appliances I'd like to repair is a floor fan. This model was specially imported from overseas and can't be found here, so it's pretty much irreplaceable.
    The PCB looks good physically, but I'm testing the traces. It looks like I need to at least replace the blown ceramic capacitor (circled in the image) and the square fuse to the left of the capacitor. Can anyone help suggest a way to figure out the size of capacitor?
    Thanks in advance!!
  • R_J
    • 9582
    Re: Help with a non PC PSU
    It's not a capacitor, that looks like a protection mov (V1), carefully clean off the brown glue from the side so you can read the number. It is likely rated at around 130v, also measure the diameter
    The power supply will operate without the mov in place (but without the surge protection) so you should be able to test if it works.
    If it is a 10mm it could be a 10D181k or 10D201k for 120vac input. If this is a universal voltage power supply the mov could be a S10K300 for 85~265vac input
    • silencery
      • Apr 2020
      • 6
      Ah, thanks so much!!!
      I'm looking for my micrometer now, so i'm not sure about the diameter, but yes, eyeballing it, it does seem to be 10mm.
      The label is really burnt, so I can't pull anything legible off it, but I've attached some photos anyway, just in case.
      The specs on the device do state only up to 120VAC input.
      I will try operating the power supply without the mov.
      EDIT: Oh, now with the aid of the blown up image, I do believe I can make out the letter VOE and 745 +
        • 31163
        it's the upper number, i can see a 2
        it probably saved the psu, too bad they didnt put heat-shrink sleeving over it to keep the bang contained.
        • silencery
          • Apr 2020
          • 6
          They did have heat shrink sleeving over this component, and it was glued to the PCB. I just pulled it off to get a better look
          A few more clues and some good news!
          • The component is 8mm in diameter (my eyeball ruler needs calibrating)
          • The PCB is silkscreened with a symbol that looks like a backwards "Z" with a line through it. Haven't seen this one before.
          • Thanks to R_J's guidance, I found the board does indeed work without this component in place. I bypassed the burnt fuse for testing and it's putting out 24VDC perfectly!
          I already have the replacement fuse on order, and I'm very happy to get it running again. I had thought it would be a lost cause. Of course, restoring back to factory spec would still be preferred, so any help would definitely be appreciated
            • 31163
            the bigest mov you can fit!
            • R_J
              • 9582
              I agree, install the a larger diameter one if you can. 10mm
              I suspect the original is made by JOYIN and is likely a JVR07N241K or JVZ07N241K
              • silencery
                • Apr 2020
                • 6
                Man, you guys are amazing. Thanks so much for your help!!!
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  That MOV plus the many damaged appliances in your area mean that the area had a significant electrical surge, either just before power went out, or right after it was restored. The fuse is between the AC input wires so that when the MOV fires, it blows the fuse.
                  If you have any power strips with surge protection that were plugged in when all that happens, their surge protection MOVs are also probably damaged.
                  PeteS in CA
                  • silencery
                    • Apr 2020
                    • 6
                    Yes, really good point. I've been concerned this surge caused a lot of unseen damage. For our neighborhood, many homes are still assessing all the damage (broken outlets, no hot water) many days after the outage.
                    Aside from replacing UPS and surge protectors, any suggestions for precautions to take?
                      • 31163
                      you could fix a ups, they will have mov's in them.
                      • kingiii
                        downloaded bios is smaller than the original bios dump
                        by kingiii
                        Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                        Thank you very much
                        06-07-2025, 04:21 PM
                      • nobbnobb1
                        Cheap Aliexpress Capacitor: Much smaller than original. Safe to use?
                        by nobbnobb1
                        I am trying to get a set of Creative T40 computer speakers to work again of which I believe the problem is bad caps (470uF @ 35V). So I get a generic set off Aliexpress. The brands are meaningless, but if anyone cares it's a "Chongx"
                        When they arrive, to my surprise it's much smaller than the originals. These are 8mm x 15mm whereas the OE is 10mm x 20mm. Unfortunately my meter does not test capacitance but I'm guessing there's no way this meets spec at 80% the size.
                        ​​​​​​Thoughts? Is it still worthwhile or safe to try and install these to see if...
                        04-19-2024, 04:31 PM
                        What is a good brand of a HDMI monitor that is 10” inch or smaller I am interested in purchasing one
                        by sam_sam_sam
                        I was looking for one on EBay but I am not sure what is considered a good brand and what is good price to consider when buying one
                        Feed back wanted and website links are welcome ( I would refer a new one )
                        I have a HP elite 8200/8300 computer that has a separate table top switching power supply ( that I planning on converting into a battery powered computer instead and I would refer a monitor that has an external switching power supply to power it )
                        I plan on making a battery powered battery testing machine on a computer rack system
                        I am not sure if...
                        09-07-2024, 06:51 AM
                      • eccerr0r
                        using exFAT on Android on smaller micro SD cards?
                        by eccerr0r
                        Are there any downsides to reformatting 32GB microSD cards to exFAT provided any other machines that could use this card also can read exFAT? (Mainly for using the card as the default "external storage," not as OTG storage but I suppose it shouldn't matter.)
                        I have this weird thing with my carrier - I can use lots of GB of data but don't nearly have as much allocation if I tether ...
                        So to stick it to them, I'll download with my phone to the microSD or internal storage, and then copy it off the card/internal storage. No difference in the bytes transferred, but...
                        06-07-2022, 12:46 AM
                      • zRedaxz
                        UEFI Tool - reconstructed body size is smaller than original
                        by zRedaxz
                        I have a BIOS dump from my Lenovo T470p. I can open it with UEFI Tool just fine. The dump size is 16384KB which is the expected value.
                        With the UEFI tool I extracted the BIOS region 'as is'. The extracted BIOS region file size is 9216KB.
                        I donwloaded the original BIOS update from Lenovo, from here: https://pcsupport.lenovo.com/us/en/p...loads/ds120707
                        I extracted this BIOS download from Lenovo and the file size of the FL1 is 9197KB. I tried to replace the BIOS...
                        07-07-2019, 08:20 AM
