Nexus NX-3000 power supply
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Bought this PSU two or three years ago when it was listed at silentpcreview.com as the most silent PSU...
    About a year back it has started to give me problems when I turn it on, just will not power on but after a few tries it does, feels to me like it needs to warm up first... Once it is on the voltage rails are within 3% and my PC very rarley gets a BSOD, but I have gotten one or so per month during this year and I think it's due to the PSU...
    Well yesterday I took it apart, the problems lies with 4 bulging Fuhjyyu TNR 105°C caps 2x 3300uF 10v and 2x 1000Uf 10v
    I've already bought Sanyo MV-WX replacement caps (not same physical size though) will report back when I have swapped those caps...
  • yanz
    • Nov 2004
    • 910
    Re: Nexus NX-3000 power supply
    uh oh.. those fuhjyyu are evil.. im a fan of silent system too.. have been of a spcr.com reader for years, their articles and testing methods are (super) great, but like others review site they haven't metion about bad caps plague.. except the xbitlabs.com iirc...
    good luck and post some pics if you can..
    • Chris1992
      • Apr 2005
      • 561
      *shakes head* Shame, using crapcaps in a silent PSU. Those PSUs are quiet because they have worse cooling so they're hotter inside.
      The great capacitor showdown!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Recapped the PSU today with said Sanyo MV-WX caps, PSU works fine now. No problem to start the computer when it's cold...
        It was a tight fit with the cap behind the cable harness though, I had to place the cap about 10mm above the PCB, also the big cap at the very side of the board, 3300uF had to be tilted slightly to not touch the PSU's casing...
        All original caps are 10mm thick
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Just came home from the MotoGP in Sachenring Germany, 21:st place for my Rider Andreas in 250cc ;-)
          Though when I started my comp same problem as before... When I made the order I forgot that one cap was 1000uF and 10v, so I got a 6,3v and hence swapped that one with a used one from a Epox 8KHA mobo (all caps on that mobo look ok)
          Well, of course that cap had spewed electrolyte all over it... So I took a multimeter and checked, 5,20v so I swapped it with a Sanyo MV-WX 1000uF 6,3v cap and now the PSU works fine again, gotta love these cap problems ;-) (the failed cap was a GSC 1200uF 10V 105°C "T10A" cap with no date on it....
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Just as a follow up the PSU exploded a few weeks ago, I'm sure it was not due to my caps though... But man, the bang was so loud I lifted a meter of my chair!
            I have a windowed case and actually saw sparks and flames come out of the underside of the PSU!
            Upon inspection two resisitors where completley blown away, the only thing left was two solder pads on the circuit board and allot of black blow resistor stuff on the close by transformers ;-)
            The thing that amazed me was that the smaller heatsink of the two was over 100°C hot, I could feel the heat so I wet my finger and touched it brefily and there was the nice cooking sound ;-) Put my tempsensor on and it showed 90, 95, 99 and then HHH ;-)
            Mind you this was after I had managed to take the PSU out of the computer and cover off it which took around 5-10 minutes...
            Gotta love them computer parts! Fortunantley nothing bar the PSU got damaged and my computer is up and running totally stable again... Funny thing to note is that it was very stable right up to this explosion of my PSU...
            Now running on a Seasonic S12 430w PSU
            Last edited by Per Hansson; 05-11-2014, 04:11 AM. Reason: Offsite images uploaded due to problems with host
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              bet the mosfets on the primary side caused the flameout.seen many cheap psu where they run too hot and die like that.with near 400v and some big filter caps behind it when the choppers go the cases sometimes explode leaving only the metal mounting tab.
              • Rainbow
                • Aug 2005
                • 1375
                Silent but crap...
                • PeteS in CA
                  • Aug 2005
                  • 3583
                  • USA, Unsure of Planet
                  kc8, I noticed when I looked at the pic last night that the apparent source-point of the frying was right by the corner of the switch device heatsink. OTOH, it looks like the MOSFET or transistor at that end of the heatsink is intact. I was wondering whether an MOV fried due to one of the I/P lytics shorting, but that should blow the fuse. My best guess from the pic is that a MOSFET/transistor failed, causing either a snubber resistor or a gate drive (base drive) resistor to blow up. Electronic "autopsies" can be an interesting mental exercise.
                  PeteS in CA
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Just out of pure curiosity I desoldered the two main caps and saw that the two transistors connected to the heatsink where also burned...
                    A look on the underside of the PCB revealed that their "collector" pin was not soldered to the PCB anymore, probably the root cause of the problem...
                    A look right above this point also revels what was seen in the first pic I posted; the solder joint for R10 has actually melted!
                    So to recap; poor capacitors _and_ poor solder joints, guess I will not be buying Nexus anymore
                    EDIT: Here is a link to a post I made explaining what actually happened... (The fan controller died)
                    https://www.badcaps.net/forum/showpo...7&postcount=39
                    The reason I bought the Seasonic PSU was actually because they manufacture their PCB's themselves, so in other words they are hopefully better built for silent (read:hot) operation... And according to Tom's Hardware review of them they have the least ripple and most stable voltage regulation of most PSU's. On top of that they are listed high on Silent PC Reviews recommended silent PSU's list...
                    And the few weeks I've had the thing it has worked great, it's very silent... I used a crap "350w PSU that weights 200gram" before I got my Seasonic PSU delivered and then my computer crashed about 4 times per day! Since I got the Seasonic PSU my computer has not crashed once!
                    Last edited by Per Hansson; 05-11-2014, 07:03 AM. Reason: Offsite images uploaded due to problems with host
                    • PeteS in CA
                      • Aug 2005
                      • 3583
                      The switch devices are transistors, a variant of a TO-220-package series created by Motorola in the late 70s. It's very likely that the device got so hot that solder at the center lead reflowed and dripped out; the same might have happed with the resistor. Looks like the resistor was the source of the smoke and flames, probably a base drive resistor. I'll bet your PWM chip is zorched.
                      PeteS in CA
                      • Rainbow
                        • Aug 2005
                        • 1375
                        This Nexus seems to be Fortron (FSP Group) OEM according to the PCB...
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Were any transformers blown? In the first photo, a couple of the transformers appeared to have a hole.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
