Delta DPS-286AP (RDENCA336WJQZ) Troubleshooting
  • bznhvx
    • Mar 2020
    • 41
    Re: Delta DPS-286AP (RDENCA336WJQZ) Troubleshooting
    D7910 (cathode) = 14.44VDC
    D7904 (cathode) = 14.96 VDC
    D7919 (cathode) (should be 18v) = 12.18VDC
    J7801 (should be 15v) = Cannot locate this Jumper... do you have another component that is on this node?
    • R_J
      • 9609
      I made a typo, That should have been, J7081, it is Q7902 emitter. it is the VCC-on voltage that turns on the relay plus various other transistors. It must be supplying some voltage because the relay is switching.
      Thes two votages seem low, they should be at least 20v, I would replace C7918 and C7915 and see if that makes a difference to the voltages.
      • bznhvx
        • Mar 2020
        • 41
        J7081 = 13.56 vdc
        • bznhvx
          • Mar 2020
          • 41
          Thes two voltages seem low, they should be at least 20v, I would replace C7918 and C7915 and see if that makes a difference to the voltages.
          I just replaced both caps and the voltages stayed the same.
          • bznhvx
            • Mar 2020
            • 41
            It's a shame to throw in the towel on this TV as I'm pretty sure the issue with it is something minor, but without a schematic, it may take more time than it is worth to figure it out. I guess I could part-out the remaining good parts on eBay.
            • R_J
              • 9609
              If you have around 12 volts on IC7801 pin 8, that should be high enough for the pFC circuit to operate. But if the ic is damaged and not outputing a drive signal to the two fets, you won't get the boosted voltage. You might also want to check the voltage on pin #3 or mabe easier/safer, check the voltage on J7022, and then on both sides of R7812, this voltage should be around 2~4 voltsdc
              If you don't have the equipment (scope etc.) to check the circuit, the only choice you have is to replace the ic. and see if it makes a difference.
              • bznhvx
                • Mar 2020
                • 41
                I have a scope. Will check for gate drive signals. Do the Overvoltage protection circuits shut down the PFC circuits? Just wondering if it would make sense to disable them to see if maybe a problem there could be in play.
                • R_J
                  • 9609
                  Do you have an ISOLATION TRANSFORMER? you will need one if you are working in the primary circuit.
                  • bznhvx
                    • Mar 2020
                    • 41
                    Yes, my scope is connected through an isolation transformer. I also have a high voltage probe if needed.
                    • bznhvx
                      • Mar 2020
                      • 41
                      IC7801
                      pin 8 = 13.5vdc
                      pin 3 = 0.84vdc
                      J7022 = 4.11vdc
                      R7812 = 0.83vdc and 4.11vdc
                      J7022 has a clean looking sinusoidal signal.
                      • R_J
                        • 9609
                        Did you check if you have gate drive output from the ic?
                        • bznhvx
                          • Mar 2020
                          • 41
                          There are gate drive pulses coming from pin 7 to the pre-driver transistors. This is a very low duty cycle. The pre-drive transistors all pass the static PN junction tests. The output feedback is only at 1V, so the duty cycle should be higher to bring the voltage up.
                          • R_J
                            • 9609
                            This ic should be operating at around 70khz. I suspect it is bad.
                            • bznhvx
                              • Mar 2020
                              • 41
                              I have checked all the components around the L6562D and don't see any reason for it not to be working, so I am going to order a replacement. The shipping charges are crazy for such a cheap small part, so I want to order a few other spare parts just in case I need them to finish this job. What would you suggest?
                              • R_J
                                • 9609
                                Where are you ordering it from?
                                • bznhvx
                                  • Mar 2020
                                  • 41
                                  Digikey - they ship USPS so usually lowest cost shipping
                                  Thought I would go ahead and get the parts for the standby 5v since those seem to fail from what I hear. TNY264, some PC123 equivalents, a few of the pre-driver transistors PBSS5140T, and a few diodes since I don't have any surface mount parts in my repair stock.
                                  • R_J
                                    • 9609
                                    I get parts shipped from digikey for $8.00, and they ususally arrive next day.
                                    • bznhvx
                                      • Mar 2020
                                      • 41
                                      Anything else that I may need that you can think of?
                                      • bznhvx
                                        • Mar 2020
                                        • 41
                                        Code:
                                        Index	Quantity	Part Number	Manufacturer Part Number	Description	Customer Reference	Available
                                        1	2	497-8928-1-ND	L6562ATDTR	IC PFC CTRLR TRANSITION 8SO		2
                                        2	10	516-1585-5-ND	HCPL-817-000E	OPTOISOLATOR 5KV TRANSISTOR 4DIP
                                        3	10	493-5378-1-ND	UPS2A010MDD1TD	CAP ALUM 1UF 20% 100V RADIAL
                                        4	2	596-1255-5-ND	TNY264PG	IC OFFLINE SWIT OTP OCP HV 8DIP		2
                                        5	5	1727-3906-1-ND	PBSS5140T,215	TRANS PNP 40V 1A SOT23		5
                                        6	10	1727-6174-1-ND	BAS316,135	DIODE GEN PURP 100V 250MA SOD323
                                        7	10	TZMB20-GS08GICT-ND	TZMB20-GS08	DIODE ZENER 20V 500MW SOD80
                                        8	2	P6KE120ACT-ND	P6KE120A	TVS DIODE 102V 165V DO204AC		2
                                        9	10	BC3678CT-ND	MBB02070C2208FCT00	RES 2.2 OHM 0.6W 1% AXIAL
                                        Last edited by Per Hansson; 03-29-2020, 08:09 AM. Reason: Added CODE tags for readability
                                        • CapLeaker
                                          Leaking Member
                                          • 8342
                                          I guess they like you better than me! It takes 3 or 4 days to get here if I am ordering @ Digi-Key . I guess I am living in the sticks!
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Hakuu
                                            by Hakuu
                                            Hi There,
                                            More Details
                                            TV Model - LG OLED77G1PUA
                                            07-12-2023, 02:37 PM
                                          • jb_Bak
                                            by jb_Bak
                                            CN6401
                                            Pin 01 NC
                                            Pin 02 NC
                                            Pin 03 "BL_ON": 0V
                                            Pin 04 "N/C"
                                            Pin 05 "STBY 3.3V": 3.5V
                                            Pin 06 "GND": N/C
                                            Pin 07 "AC_OFF"...
                                            09-27-2021, 04:52 PM
