Delta TDPS-138AF Avaya no output repair
This topic has been answered.
    • Jul 2011
    • 6069
    Re: Delta TDPS-138AF Avaya no output repair
    I had this type of issue with those type of capacitors on one of my Desoldering station controller board before I found it I started touching different components on the board and found a spot that was real warm and took my ESR meter and check it had 14 ohms of resistance on the power supply rail
    It was not correctly controlling the temperature is why I was troubleshooting it in the first place
    Plus every one in while it would just cycle the power supply
    If I have this kind-a problem where it cycling a power supply I will try your little trick
    “ Using this 91% IPA and feeding power trick, never gets old.”
    I have one request can go into a bit of details of how you do this with out messing up the board
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8328
      O.k. Sam...,
      This trick is pretty much my last ditch effort to repair something, when I don't know where the short exactly is. However I do have to know what trace is shorted, for this trick to work. So troubleshooting is key. Also at this point the repair is an automatic 50/50 chance for me, although I do have a very high success rate that suggests other wise using this trick. After all I have to take stuff off the board, making sure nothing got damaged in the process.
      Chasing a short, I take stuff off, one by one, trying to eliminate suspected problems on the shorted trace, 43 Ohms in my case. I try to be careful with the IC's and voltage regulators and take them off, but the rest not so much. Once I removed certain things and the short didn't go away, I look at the components, determent where to feed positive and negative and adjust between 5 to 12V, 0.5A to 1.5A from my CV & CC PSU, douse the board with IPA, wait anywhere between 30 seconds and 2 minutes and look for the bubbles or feel for the heat.
      Now in this case there were no bubbles, because it was on the back side of the PSU and there were 4 caps in parallel, so the heat would spread over the surrounding caps. But it still got hot enough for me after 2 mins to tell with my finger that this was the place to remove all 4 smd caps even with my fingers on the other side of the circuit board. A quick check with the DMM revealed 43 Ohms there as well, so.... well the rest you know.
      Feeding power to a SMD short is o.k, just don't feed too much power, rater wait for a minute or 2. Trust me, the shorted part will get hot as it has to dissipate all the power and create heat.
      I also used this trick here on my arbitrary function generator: https://www.badcaps.net/forum/showth...ighlight=kuman
        • Jul 2011
        • 6069
        I remember reading this post before and I even made a comment about your repair
        Thanks for sharing them
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8328
          yes and thanks sam.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8328
            Got another one of these funky PSU’s today on my bench. Same complaint, not working.
            Guess what?! Yep, same darn problem. This time I went straight to those 4 SMD caps in parallel on the back side of the PSU. Measured like 80 Ohms across them. Sure enough the second one in was the problem. Replaced SMD cap, PSU fixed. Took 5 mins, lol. Seems like they have a weak spot there.
              • Jul 2011
              • 6069
              This is interesting that you had another power supply with the same exact issue again wow
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8328
                Yes, exact same failure to the dot. There are four 10uF caps in parallel, which provide about 15VDC to the PWM's. The weird thing is that these caps aren't failing in a total short, rather fail in the 80 to 100 Ohm range. It does seem that this PSU model has a higher failure rate due to this. But it is easily fixed.
                • gsan33
                  • Feb 2023
                  • 8
                  • Russia
                  #48
                  Just successfully repaired Avaya IP 500v TDPS 138. I was extremely lucky, the reason was easy to find: the fuse burned out, and checking the AC input resistance showed an asymmetric value depending on the polarity of the tester. Comparison with a working module also confirmed that faulty part is somewhere in the input circuit. Suspicion fell on the diode bridge, and indeed, when I soldered out the GBU8K chip, one of its diodes was in a short circuit. Replacing of the diode bridge restored the operation of the unit.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8328
                    Well that was a easy lucky fix. I haven’t seen your problem on these PSU’s over here, but there must have been quite the voltage spike for the bridge rectifier to go short. Another one kept out of the land fill!
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8328
                      Got the original PSU back. Blown again. Same place same part. One of the 4 chip capacitors in parallel failed.The one I put in is still good. This time I had a 345 Ohm short across the capacitors.
                      NOW: I recommend to replace all 4 chip caps at the same time!
                        • Jul 2011
                        • 6069
                        I was wondering about weather or not a good idea to replace all four of them at the same time is it unusual for this type of capacitor to go bad like that
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8328
                          My reasoning for this measure is because:
                          The PSU came back to me the second time with the same failure on the exact same spot.
                          I did measure all 4 caps out of circuit capacitance and resistance. While the capacitance was bang on through the remaining capacitors, the resistance was not.
                          One cap was my replacement, 3 where originals which one of them failed. The failed cap had 345 Ohm resistance and no capacitance on the DMM. My replacement cap had rated capacitance, the resistance was like 50 something MegOhms. I almost measured the same on an original cap, so that was good. However the last original cap while it had capacitance same as the others, the resistance was like 3MegOhm. So I figure this is the next one to go. So I just replaced them all 4 caps with new 50V 10uF.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8328
                            Well... I got another one of these power supplies in. Yeeep... exact same thing again! Replaced all 4 parallel MLCC's with 50V 10uF XR7's in bank C912x on the back side and she is working once more. Easiest Avaya PSU repair ever. Remember to replace all 4 of them, other than that it will come back again!
                              MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                              This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 03:40 AM
                            • FrancescoV
                              Onkyo HT-R390 no sound output, video output ok
                              by FrancescoV
                              Good morning everyone,
                              I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                              The firmware reported is the following:
                              M:1.00/11107BLP
                              D:?.??/????????
                              O:1.00/11107AL
                              The DSP firmware given the question marks seems corrupt.
                              On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                              05-11-2025, 02:59 AM
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                              Surface Mount Fuses Fundamentals Datasheet
                              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                              10-07-2024, 06:07 AM
                            • Junkrepair
                              Calculating ESR from tan delta -- tan delta's dependence on capacitance
                              by Junkrepair
                              I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                              I found this nice little description of the conversion:
                              Calculating capacitor ESR from Tan(delta)
                              https://forum.digikey.com/t/calculat...-from-tan/2633
                              It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                              06-12-2023, 02:45 PM
