How do you bench test this type of USFF Desktop Power Supply
    • Jul 2011
    • 6039
    I have a computer that has this type of power supply
    I think of making a small bench power supply out of one of them
    I can get them from eBay used very inexpensive and it does have as many wires to it and it is easier to recap
    The highest wattage one I have seen so far is 200 watts
    Dose anyone have experience with this type of switching power supply that can tell how to turn on the power supply on the bench
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How do you bench test this type of USFF Desktop Power Supply
    Like an ATX power supply, green wire to ground.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Hmm...where (and what) is the standby power output...
        • 31028
        you apply 5v to the green wire to turn it on i think.
        unfortunatly it does not supply 5v so you need a voltage regulator or a battery!
        i know it alternates between 5v and 0v but not sure which way is to turn on.
        i have a similar supply in bits here - they are a pain!
        • jinu_j
          • Feb 2016
          • 90
          • India
          The paperclip trick should work i.e connect/short the green wire to the black wire. But some PSU dont power on till you connect a load to the supply even after shorting the green to the black. So connect a load to the power supply and then see.
          Here are some links that should help
          1. Pinout of 8pin DELL PSU connector
          2. Using a 8pin to 24pin converter to get standard power connector
          3. DIscussion on powering on a DELL powersupply without Motherboard
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Hmm...well. I guess the said PSU has not been acquired and it would be difficult to see the board to make guesses at how to power it up. Then again, my most recent PSU attack was a server PSU power up -- I could NOT figure out how to turn it on from the edge connector. I found the 5VSB however but shorting each of the pins to GND did not power up the supply.
            I had to backtrace the PSU and found a few hacks to the control board to force the supply to turn on. I suspect the PSU needed I2C control to turn it on.
            I doubt this is the case with this PSU in the OP, but some things are uglier than others...
              • Jul 2011
              • 6039
              I did finally figure out how to use this switching power supply with out the mother board it just and atx power supply just use the power on wire to ground and it powers ON
              • Nicktronic
                Bench Test Samsung BN44-00621C Power Supply Board
                by Nicktronic
                Hey!
                I've got this power supply board that's had some components replaced and I'd like to confirm all the voltages before I install it.
                This is what I have when I plug in the board on the bench;
                1 - N.C. - 0 VDC
                2 - PWM_DIM4 - 0 VDC
                3 - N.C. - 0 VDC
                4 - PWM_DIM3 - 0 VDC
                5 - GND - 0 VDC
                6 - PWM_DIM2 - 0 VDC
                7 - B13V - 0 VDC
                8 - PWM_DIM1 - 0 VDC
                9 - B13V - 0 VDC
                10 - ECO_ON/OFF - 0 VDC
                11 - Vamp - 0 VDC
                12 - BLU_ON/OFF - 0VDC
                13 - Vamp - 0 VDC
                14 - GND - 0 VDC...
                07-11-2023, 12:32 PM
              • rabsonnjala
                LENOVO IDEAPAD 100 works only on bench power supply
                by rabsonnjala
                Hie I have a Lenovo laptop
                Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                below are my readings
                with the original charger only
                JBATT1
                PIN1 0.22V
                PIN2 0.22V
                PIN3 0.45V
                PIN4 0.45V
                PIN5 O.43V
                PIN6 0V
                PIN7 GND
                PIN8...
                11-20-2021, 08:32 AM
              • Eniaro
                Bench test a series X
                by Eniaro
                How do you bench test a series X? I was planning to find a defective PSU to use its connector, but before I go about doing this, I was wondering if there's any bench PSU to the series X connector adapter available
                06-17-2025, 01:46 PM
                HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                09-12-2024, 03:28 PM
