Troubleshoot swtichmode power supply with DC Bench Power
  • clearchris
    • Dec 2013
    • 687
    I can't seem to find any reference to this anywhere, but I vaguely remember that you can troubleshoot a SMPS by hooking the inputs up to DC power. The bench power supply provides isolation, and a much lower voltage, so there's much less opportunity to juice yourself.
    Does anyone have any experience with this method?
    Right now I'm trying to troubleshoot the power supply to an Element 605 LED TV. No signs of life on the TV at all, no power on any of the outputs, even with a 12v auto bulb hooked up to the 5v line. The fuse is fine, zero signs of bad caps, burns, anything, the board looks pristine. The caps are "Chang" and the TV is six years old (2014 manufacture date) so I'm leaning towards bad caps on this one.
  • clearchris
    • Dec 2013
    • 687
    Re: Troubleshoot swtichmode power supply with DC Bench Power
    I did more testing. I have nothing on the 5VSB line. So the supply either has something wrong with the 5v bus or something on the high side. I think I'm going to pull the transformer, test the diodes on the cold side. I don't see any rectifiers or linear power regulators on the cold side, so one fewer thing to fail. If the diodes test good, I'll check the caps, regardless, they are getting replaced probably with panasonics. If I don't find anything wrong there, it's probably time to turn my attention to the hot side.
    Thoughts?
    Pics of hot attached. I can't attach the cold side pic for some reason, it is below the acceptable file size.
    Full pics and pic of full board at: https://drive.google.com/open?id=1M4...6sGJvOdtPRCDyd
    • R_J
      • Jun 2012
      • 9535
      The chances of the transformer being bad is rare, What is the voltage across the main (large) capacitor in the primary?
      Just a note, but shopjimmy has the board for $49.00
      • clearchris
        • Dec 2013
        • 687
        Yeah, I know, all three boards together are only $75. But I'd rather rebuild it with better caps than get another one with bad caps.
        I don't think the transformer is fried, it looks great. But if you pull the transformer you can test other items on the board without lifting a leg for each of them.
        The voltage across the main capacitor is 168v. It's plugged into a 120v outlet.
        • clearchris
          • Dec 2013
          • 687
          On my bench, I'm now getting 5v from 5VSB line. In the 5v section, I pulled the diodes and caps. The diodes tested good, caps tested within 10% of label uf. ESR of caps was below 0.07 for all. Vloss was around 2%. I did notice a ticking, about once a second. When I measured between 5VSB and GND, the ticking stopped.
          Can I jump 5VSB and PS-ON (maybe with a resistor?) and see if it fires up?
          • R_J
            • Jun 2012
            • 9535
            Yes you can do that
            • clearchris
              • Dec 2013
              • 687
              It's now the seemingly standard scenario that I wish I could fix. Pulsing outputs. So there's probably a short somewhere. The 24v led inverter section has to be turned on via a pin, so I'm pretty sure I can rule that out. So there remains the 5v section and the 12v section. I think I'm going to disable the 12v output at the transformer and see if the 5v section still pulses.
              I checked the rest of caps, they were all nearly exactly 10% lower than the label. ESR was fine and vloss was fine. One was a bit over 10% low, it registered at 192uf for a 220uf cap. It was a 35v cap, I temporarily replaced it with a 25v cap.
              I will say, this board is an absolute joy to work on. When I desolder components, they just fall right out, no messing around. They must have oversized the holes just a bit.
              • SoporteHR
                • Sep 2018
                • 80
                • Venezuela
                Hi
                On the HOT side, what voltages do you have?
                You checked that the Mosfets are not short
                • clearchris
                  • Dec 2013
                  • 687
                  The voltage across the main capacitor is 168v. It's plugged into a 120v outlet. What else should I check on the high side.
                  I desoldered the mosfets on the hot side, they all tested good with my LCR-4.
                  • R_J
                    • Jun 2012
                    • 9535
                    Pulsing does'nt always mean there is a short, It could mean the ic is not coming out of standby, IE low vcc, When you force the power supply on, what is the voltage across the main cap? is it still 160v or does it come up.
                    This is an always on power supply (no seperate standby) so if you are getting +5 volts in standby, most of the components are ok.
                    It would help to know the ic numbers.
                    I would replace those two small caps in the primary (next to the large heatsink), They are likely the vcc filter caps for the ic's in the primary
                      • 31012
                      check the startup cap - as usual.
                      • clearchris
                        • Dec 2013
                        • 687
                        It lives! I replaced the small caps near the heat sink per instructions and it worked. Surprisingly, nothing was very far out of spec, but it worked anyway. Then I went through and replaced all the other caps that I had on hand. I need to put an order in for the rest of the caps, but I have a question.
                        I normally order panasonics FM series, or some other low ESR capacitor, but for the big cap, all I can find for 83uf 450v is "general purpose" caps. Is this ok, or should I keep looking?
                        Thanks!
                        Now I have to figure out where to put this monster tv.
                        • R_J
                          • Jun 2012
                          • 9535
                          The large 83µf/450v is likely ok and will last a long time, but general purpose will be fine, digikey lists most caps as G.P.
                          • clearchris
                            • Dec 2013
                            • 687
                            Ok, I'll skip it then. Thanks!
                            I figured I'd do them all because this beast is cumbersome to work on.
                            I do have to say, I'm surprised at the high build quality though, I thought this was a cheaper tv. The back is all metal and the plastic cover that hides the boards is really thick plastic.
                              master hoarder
                              • May 2008
                              • 12170
                              If the PSU has an APFC circuit, I suggest to be careful, as cheap cap brands tend to not stand the abuse of APFC too long (especially CapXon.) Also, if there is an APFC circuit, I suggest minimum 420V caps, and 450V as the norm.
                              The fact that this PSU does have a 450V main cap will probably help it a bit. But if the cap isn't too expensive, I'd replace it with a known good Japanese brand 105C cap.
                              • clearchris
                                • Dec 2013
                                • 687
                                I'll get that cap on order just to have it, but tv has been completely recapped, including all boards except for that one. Fired it up, works great, now I just need to mount it. It's a heavy beast, the back is all metal.
                                  03-31-2024, 02:12 PM
                                • shamsudeen
                                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                  by shamsudeen
                                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                  07-19-2025, 07:14 AM
                                • rabsonnjala
                                  LENOVO IDEAPAD 100 works only on bench power supply
                                  by rabsonnjala
                                  Hie I have a Lenovo laptop
                                  Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                  it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                  below are my readings
                                  with the original charger only
                                  JBATT1
                                  PIN1 0.22V
                                  PIN2 0.22V
                                  PIN3 0.45V
                                  PIN4 0.45V
                                  PIN5 O.43V
                                  PIN6 0V
                                  PIN7 GND
                                  PIN8...
                                  11-20-2021, 08:32 AM
                                  07-01-2024, 06:34 AM
                                • JimBanville
                                  Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                  by JimBanville
                                  The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                  I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                  09-13-2023, 07:21 AM
