Skyhawk Eagletech Pantherpower
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Friend has one of these. About the only good skyhawk power supply made. Has problems where his computer will shut off after a while.
    I am not sure if these units have overtemp protection. Doubt it. He is only running a 7800gt with a amd athlon 64 something or other, maybe a dual core, but not much. JG did a test of this power supply, and he ran it up to about 450W, and it kept under 30mv the entire time. But it had tocon caps in it.
    I have two questions, would the shutting off be caused by bad caps, or something else?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Skyhawk Eagletech Pantherpower
    if the caps are overheating and it has thermal shutoff, then yes. if not, then it could be something else in the power supply or the ripple is killing the mobo/cpu.
    i swear that skyhawk makes the world's worst "wannabe" power supplies. cmon, skyhawk sounds cool, but their crap sure aint.
    sigpic
    (Insert witty quote here)
    • gdement
      • Jan 2007
      • 690
      Wow... that's a mouthful.
      I wonder if there's any other "cool" animal names they can work in there.
      • Toasty
        • Jul 2007
        • 4171
        LOL!
        You mean the Zoopower?
        "Nope, sorry Eagle Tech Skyhawk Panther Elk Jackalope Moose Deer Giraffe Elephant Wallabe Power, no recommended award for you." - jonnyGURU
        veritas odium parit
        • Krankshaft
          • Jan 2007
          • 2328
          Haha that would go great with my Thunder Cougar Falconbird supply .
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have one of those myself.
            its not very portable though.
            stays bolted to a big chunk of cast iron.
            • Wizard
              • Mar 2008
              • 2296
              There is no such as overheating caps and shutting down, total bunk. They die really short life if running hot, and not all SMPSes have thermal sensing and is poor, and some don't use it for that, it is merely for the fan speed.
              I have not seen a SMPS that you can buy over the counter with thermal shutdown till you get to 70 and above dollars range and that's not common. Yes sure in 600W plus and that retail for about 80 and above, but not all do have it by default, just for fan speed.
              The serious SMPS used in rack stuff will have it but that is serious penny in around 100 to 150, even 200 dollars range.
              Cheers, Wizard
              • 370forlife
                Large Marge
                • Aug 2008
                • 3112
                Cheers, Wizard
                Well, actually, it has overtemp protection. OW did the review of it, and he says that it is over sensitive. His shuts down powering a couple of fans, so I might just rewire the fan to run constantly on 12v.
                • Krankshaft
                  • Jan 2007
                  • 2328
                  If it's oversensitive change the value of the thermisistor it's screwed to the heatsink.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    at least its not under-sensitive. then, there would be flames shooting out the back of the computer... and this time you couldnt't blame the p4 cpu or crappy cpu cooler.
                    sigpic
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Good think I decided to take a few out of some old bestecs and all those proprietary deltas. How can I tell the value?
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        damn data base error double post...
                        • etnietering
                          • Apr 2009
                          • 379
                          It might be easier to take an assortment of fixed value resistors (or a pot, if you have one) and put that in series/parallel with the thermistor. Then you wouldn't have to worry about goofing up the thermal contact between the thermistor and the heatsink. And you wouldn't have to worry about figuring out if it's a PTC or an NTC and getting the appropriate value. You could rip apart old power supplies for resistors, or you can usually find assortments pretty cheap on ebay.
                          • Junior††
                            dell inspiron 14 7445 2-in-1 [ Amd Ryzen 7 8840hs Cpu MT90K] power cycling
                            by Junior††
                            hey so i have this dell inspiron 14 7445 2-in-1 [ Amd Ryzen 7 8840hs Cpu MT90K] mobo
                            MOBO P/N: 4910US10A002
                            replaced both pd controllers as they were both bad and so now she's boot looping,
                            all voltages are present although they dip about 30mv each after about 5 seconds and it cycles (my amp meter doesn't turn off, stays at 20v), please see image attached for how much the board is taking; fluctuates from low of 270-400ma at 20v.
                            seems like everything turns on (gets warm) then turns off, indicator light is turns on, turns off after it wants to...
                            06-28-2025, 06:39 PM
                          • x_orange90_x
                            Samsung UN55KU6300F no standby voltage
                            by x_orange90_x
                            I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                            Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                            05-21-2025, 09:59 PM
                            by momaka
                            03-15-2023, 10:17 PM
                          • heathloder
                            Sony XBR-65X850E - has standby 3.3V, but won't power on - no status lights
                            by heathloder
                            I have a Sony XBR-65X850E that won't power on, and has no status lights.
                            Immediately upon plugging in the TV, it tries to power up (before pressing anything). I can tell because after plugging the TV in, the main transformer on the power board begins buzzing, 2 seconds on, 2 seconds off, and it does this exactly 7 times before the TV goes back to an “OFF” state. If I press the power button on the TV, the same cycle repeats. I can confirm that no ‘status' LED's are lighting up when this happens. The backlights also do not turn on, but I can confirm that they at least “light...
                            04-04-2020, 07:36 PM
                          • rmacintosh
                            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                            by rmacintosh
                            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                            The symptoms of the tv ar as follows:
                            • Plug AC in to back of TV
                            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                            • The 3 blink code is given by the power LED
                            • If the TV is unplugged and then
                            03-14-2020, 12:24 AM
