Power supply & air switch on sewing machine
  • pintglass
    • Jul 2019
    • 79
    • United Kingdom
    Hi
    I'm trying to repair my mothers 30+ years old sewing machine which she's got quite used to over the years.
    At the moment I've only done some basic tests as i think there could be numerous faults.
    Model is a Elna Stella electronic air.
    The machine is controlled via an air foot peddle which as can be seen in the image is connected to an air switch, sorry don't know the correct term for this device. One of the contacts on this is a bit loose which i will try to fix back down somehow although I'm not sure how I'll achieve this at the moment. But when i tested this i do get varying resistance from the device when operating the foot peddle.
    I have about 150 ohms resistance across the motor so assume this is OK for now.
    I have tested all the resistors and all but one seem ok, apart from the 3k9 which can be seen in the schematic, this was obtained from the following website.
    http://www.diceyhome.free-online.co....lla_refurb.htm
    My main question for now is am I Ok to connect my multimeter to the motor spring terminals on the pcb to test or will this be an issue without the motor being connected?
  • redwire
    • 3910
    Re: Power supply & air switch on sewing machine
    That other site's Elna Stella TSP Air Electronic schematic has many errors. If I had a pic of the backside I can draw a correct schematic. The 3k9 snubber resistor is OK in your pic, not burned.
    I would first find out why the other resistor burnt up. Some Stella have a pcb air-flow cutout for more cooling for that resistor. I think it's for current-sense feature for constant-torque to keep up speed level with changing load.
    It has a brown stripe so value starts with "1", and "2" in that other website's pics. We'd have to figure out where in the circuit it is.
    It looks like a progressive (air pressure) switch that engages more contacts with pressure against the spring. It could be (decimal) 4-levels, or 32-levels (binary). Just pull off the brown terminal and measure ohms across the terminals (brown) should have about 220k steps, starting with 270k perhaps.
      • 31061
      that burned resistor probably indicates the 0.1uf capacitor is short circuit.
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        wouldn't harm to test the diodes
        • redwire
          • 3910
          OP if you can look for numbers or a pic of the two small diodes next to the blue cap at the board edge. I think it's a zener diode, not 1N4007. Just need pic of the traces around the blue cap and can finish the schematic.
          You can use a light-bulb in place of the motor for testing. The other two pins go to a switch or something.
          I found a pic with the original resistor, wow these boards are rare.
          • pintglass
            • Jul 2019
            • 79
            • United Kingdom
            Thanks for all the info
            There's a trace layout on the website that i linked to, if your not happy with using that for a reference I can remove the pcb and take photo's.
            I will take a look at the board in more detail after work.
            • redwire
              • 3910
              It's an action photo with his cutters and soldering iron blocking traces
              I couldn't make it out. The right side of the blue cap, no pics on that diode.
              • pintglass
                • Jul 2019
                • 79
                • United Kingdom
                This image was a bit further down his web site.
                • redwire
                  • 3910
                  That helps alot. He mixed up the triac MT1, MT2 and not sure how there are 7 switches in the air control. Two are redundant for safety perhaps. It's a sophisticated speed controller.
                  The burnt resistor is in series with the motor and triac, and does torque limiting.
                  If the machine jams and you are heavy on the throttle, it would burn up.
                  I would say it is a 1k part (use 3W) because I saw that at http://blog.bambersew.com/sewing-mac...machine-repair and you have a brown stripe intact. It is 2k7 in the other website but it must be a different model Elna.
                  Any other shorted parts (triac, cap, diodes, etc) would just leave the motor stuck running all the time I believe. I'd change the four film caps due to age. The one diode next to the blue cap is a zener I think.
                  • pintglass
                    • Jul 2019
                    • 79
                    • United Kingdom
                    Could you tell me what caps to get as replacements?
                    • pintglass
                      • Jul 2019
                      • 79
                      • United Kingdom
                      Could i use a 2w resistor as the 3w resistors are quite long, I only have 15mm between the pads.
                      • redwire
                        • 3910
                        For the capacitors, three are across the line (mains), there is no fuse, so they should be X1 safety rated. I don't know all the dimensions but took a guess. New ones are thick maybe.
                        0.1uF/100nF 275VAC X1, LS=20mm?
                        The old part lead spacing looks like around 20mm, but the standard is 22.5mm so they will need a little bend.
                        Do not use paper caps like Rifa/Kemet PME271 series or Wima MP3-X2, MPX21 (clear epoxy) they are known to fail and burn.
                        Suggest Kemet R49 R49AN31004001K CAP PP FILM 0.1uF ±10% 1000VDC/310VAC X1 RAD, LS=22.5mm, long leads
                        Kemet R47 R474N310050A1K CAP PP FILM 0.1uF ±10% 1000VDC/440VAC X1 RAD, LS=22.5mm, long leads
                        0.047uF/47nF 275VAC X1, LS=15mm
                        Suggest Kemet R46 R474I247050A2K CAP PP FILM 0.047uF ±10% 1000VDC/440VAC X1 RAD, LS=15mm, long leads
                        0.033uF/33nF 63VDC ±5% LS=10mm? (7.5mm and 5mm are more common) timing cap for speed control
                        Suggest EPCOS B32621A4333J000 CAP PP FILM 0.033uF ±5% 200VDC RAD
                        Wima FKP3 FKP3C023303D00KSSD CAP PP FILM 0.033uF ±10% 63VDC RAD
                        Many other Kemet/Wima/EPCOS parts would be fine.
                        1k ohm 1/2W carbon, LS=15mm, it should be flameproof safety rated.
                        Suggest Panasonic ERG-2W
                        ERG-2SJ102V 1kOhm ±5% 2W 12mm Through Hole Resistor Axial Flame Proof, Safety Metal Oxide Film
                        Let me know if the outside diode next to the blue cap is a zener, I think it is.
                        • pintglass
                          • Jul 2019
                          • 79
                          • United Kingdom
                          Will these be ok
                          https://uk.farnell.com/kemet/r463i24...ial/dp/2446240
                          https://uk.farnell.com/neohm-te-conn...ide/dp/1738638
                          • redwire
                            • 3910
                            Yes, X2 (2500V) can be used instead of X1 (4000V). They have a smaller size with lower transient overvoltage rating like what you'd could see in a home. I'm used to spec'ing industrial parts.
                            The 2W resistor is a bit long at 16mm+bend, but should fit. It's almost 10x higher power than the original part.
                            • pintglass
                              • Jul 2019
                              • 79
                              • United Kingdom
                              Is the diode that i have highlighted in the image the one your asking about, if so its a 1N4148.
                              • redwire
                                • 3910
                                Thanks for the pic, hmmm hard to tell it's covered in belt dust. Needs a wipe with q-tip and IPA. 1N4148 is usually reddish/pink body and a zener is orange.
                                • pintglass
                                  • Jul 2019
                                  • 79
                                  • United Kingdom
                                  I've cleaned the board now, the image was taken before, 1n4148 is whats printed on it, its a yellow colour. I can take a new photo if you like.
                                  • redwire
                                    • 3910
                                    ok, 1N4148 it is. I thought I saw an orange one (zener) on another board which made more sense as the circuit looks at motor back EMF to keep speed constant.
                                    • pintglass
                                      • Jul 2019
                                      • 79
                                      • United Kingdom
                                      All fixed now so thanks for all the help again.
                                      Did you say that the schematic that I linked to is wrong, did you think the triac was in the wrong place, I may try to redraw this during the holidays.
                                      • CG2
                                        Janome DC3050 Sewing Machine Pedal Resistance
                                        by CG2
                                        OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                        Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                        04-14-2023, 07:53 AM
                                      • wolf1976
                                        I'm looking for a selective TIG-MMA switch on welding machine
                                        by wolf1976
                                        hi
                                        on the bellow pictures i have include the upper and the bottom area of this switch
                                        the machine had fallen and this switch is break can you suggest me a suitable switch to change it ?
                                        i dont know if this switch is the only problem because the welding is open normal the green led is light but it welds with interruptions
                                        and when i turn it on i measure the voltage and its only 6 volt i dont know if this is right
                                        thanks on advance...
                                        07-08-2024, 01:49 AM
                                        Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                        This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                        09-06-2024, 05:30 AM
                                      • Natob82
                                        Micro Momentary Push Switch?
                                        by Natob82
                                        Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                        12-21-2022, 05:22 AM
                                      • grimacelord
                                        NEC TurboExpress On/Off Power Switch Replacement Help
                                        by grimacelord
                                        I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                        I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                        I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                        11-09-2023, 09:49 AM
