Manson NP-9613
  • bianchi77
    • Jun 2016
    • 1121
    Re: Manson NP-9613
    some photos :
    • bianchi77
      • Jun 2016
      • 1121
      Re: Manson NP-9613
      Originally posted by bianchi77
      some photos :
      it can not go beyond 19V, everytime it hits 20V up, the relay is sounding and voltage drops....
      • bianchi77
        • Jun 2016
        • 1121
        Re: Manson NP-9613
        Is it possible that my TIP 41 transistor faulty, since it's working only 67% of the maximum ability ?
        • R_J
          • 9553
          Re: Manson NP-9613
          Does this power supply use two relays?
          Check the transformer secondary windings, and the relay contacts, The transformer has 2 secondaries that supply the main voltage, for lower voltages (1~19) it uses one winding, then as the voltage is increased (19~30), the relay switches to the other set of windings. It looks like it uses 2 relays for that operation, one on each set of windings. You replaced one burnt zener diode, did you check the other zener?
          You do look at your pictures before you post them correct?
          Where is this transistor? what does it do?
          • redwire
            • 3910
            Re: Manson NP-9613
            If the output goes to zero when the high-tap relay clicks, then I would check the transformer winding and bad solder joints there and the relay contacts too. It's common the relay contacts arc and go bad.
            Schematic for Manson NP-9603, NP-9613, NP-9605, NP-9615 power supply family, I found this, attached.
            There is no TIP41 just a 2N3055 and TIP31C for a driver transistor.
            To troubleshoot your previous work, note output (-) is control circuit common so puit your multimter (-) there when taking measurements. Check the rails -5.6V, +12V at ZD1 and ZD2, +15V at 78L15.
            These Manson power supplies are pretty cheap and not tough at all. They blow up if you just look at them.
            • bianchi77
              • Jun 2016
              • 1121
              Re: Manson NP-9613
              My bad, it's TIP 31C, I was thinking it's the relay, because it looks burn on the bottom,
              but there are two 2N3055 on my manson and no LM339 as far as I can see on the board...
              Thanks for the suggestion, let me check the voltage,
              I check at the relay1 output =1V and relay output2 = 2, when the output voltage hit 20V and going down....
              • bianchi77
                • Jun 2016
                • 1121
                Re: Manson NP-9613
                can I replace the relay with this :
                https://www.ebay.com/itm/20-pieces-M...75.c100623.m-1
                I can not find exact match with the one on the board....
                • bianchi77
                  • Jun 2016
                  • 1121
                  Re: Manson NP-9613
                  Here are some observation I had done :
                  Output = 12V
                  ZD1 = 24V
                  ZD2= 12V
                  Output = 3.8V
                  ZD1 = 16.48V
                  ZD2= 3.8V
                  Output = 17.18V
                  ZD1 = 29.74V
                  ZD2= 17.17V
                  Output = 17.46V
                  ZD1 = 30.06V
                  ZD2= 17.47V
                  Beyond 17.46V, it will stay awhile then voltage drop, relay click and return to the voltage desired...
                  • R_J
                    • 9553
                    Re: Manson NP-9613
                    You are not using the correct ground to measure these voltages, You need to use the POSITVE OUTPUT TERMINAL
                    ZD1 is a 12 volt zener, If you measure 24 volts across it, you used the ground and not common, or it is defective. Same for ZD2, it is a 5.6 volt zener, With its cathode to common it is the negative 5.6v supply for U1.
                    These voltage are constant and WILL NOT CHANGE with the Variable output voltage
                    Another thing to check is the AC across C1 (or the ~~ pins of BR1). Check this AC voltage, then when the relay clicks, see what happens to this AC voltage
                    • redwire
                      • 3910
                      Re: Manson NP-9613
                      oops my bad PSU output (+) is the common for the op-amps and control power, typed it wrong.
                      Either way, the voltage difference across ZD2 5.6V seems to be zero, for the op-amp's -ve rail. I would say there's a problem there, maybe it is shorted or the 4558 is. But you say the PSU works fine on the low voltage tap.
                      The LM339 is only for temperature control of the fan and an overheat shutdown, maybe the 5A version got it.
                      • bianchi77
                        • Jun 2016
                        • 1121
                        Re: Manson NP-9613
                        Ok, I will check,
                        I used common on the output, which ground should I use ? thanks
                        • R_J
                          • 9553
                          Re: Manson NP-9613
                          You can use the POSITIVE terminal of the power supplies (0~30v) output. So put your meter ground on the Positive terminal, then you can check the voltages on the zeners etc.
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Re: Manson NP-9613
                            I got 12.41V and 5.6V on the zener, so could it be the issue with relays ?
                            • R_J
                              • 9553
                              Re: Manson NP-9613
                              I told you how to check the voltage going to the relays (this also checks the relays) here is a picture of what to do. This should be easier then removing them and testing them.
                              I will only guess there are two relays and I they may switch at different times based on the output voltage.
                              If the relay contacts are bad you should measure the AC likeI pointed out when the DC output is low (less than 19v) then as you increase the control to increase the voltage and the relay clicks, If the AC voltage drops, one of the relays contacts are bad. (ore the transformer winding is open) or bad connection from transformer to relay somwhere.
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Re: Manson NP-9613
                                Ok, let me check and get back to you, thanks
                                • bianchi77
                                  • Jun 2016
                                  • 1121
                                  Re: Manson NP-9613
                                  It could have been the transformer, since I rotated until 20V and no more voltage increasing on the point you gave me, and the pot was maximum...
                                  if the transformer winding is opened....difficult..
                                  • R_J
                                    • 9553
                                    Re: Manson NP-9613
                                    When you say "no more voltage increasing" That AC voltage will be constant untill the relay clicks? OR did the voltage drop to 0? It can't just stay the same if the relay clicks, if it does then the relays are not switching at all.
                                    What is the AC voltage on those points on the transformer? I will guess what they are and you can check them. (you don't need to adjust the dc output pot)
                                    Provide pictures of the transformer and the relays and how they are connected
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Re: Manson NP-9613
                                      I got
                                      13V 23V and 33V on the transformer voltage...
                                      • bianchi77
                                        • Jun 2016
                                        • 1121
                                        Re: Manson NP-9613
                                        is it possible that 4700uF caps going bad ? making the output drop ?
                                        • R_J
                                          • 9553
                                          Re: Manson NP-9613
                                          I got
                                          How do you measure 3 different voltages on 2 points? Or is that voltage measured across C1 as you turn up the voltage control? You need to explain what your doing.
                                          One thing I wonder is when you advance the voltage control between 0 and 19 volts, during that variation, do you ever here one of the relays click?
                                          There is nothing wrong with the 4700µf. even if its value droped to 1000µf, the voltage would not drop because you are not drawing any real current from the power supply at the moment.
                                          • DodgyTech
                                            60" LG 60PB690V relay clicking issue
                                            by DodgyTech
                                            I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                                            I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                                            I would like to try and identify...
                                            07-07-2023, 10:30 AM
                                          • CuriousJohn
                                            Burco boiler power problem
                                            by CuriousJohn
                                            Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                            Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                            This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                            12-22-2024, 10:25 AM
                                          • rounin
                                            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                            by rounin
                                            🛠 Original Issue
                                            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                            04-19-2025, 01:18 AM
                                          • ugamazing
                                            by ugamazing
                                            12-17-2024, 07:05 PM
                                          • ahmarzo
                                            Acer laptop battery draining issue
                                            by ahmarzo
                                            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                            08-02-2025, 06:39 AM
