Seasonic X-560 and Corsair AX650 - fail to power on after a week of use
  • decayed.cell
    • Sep 2018
    • 11
    I have a Seasonic X-Series 560W and a Corsair AX650 here which suffer the same symptoms (they are based off the same platform, so I guess its not surprising).
    They will power on a computer fine for a few days. But after a few days, they refuse to power on unless the switch at the back is flicked off and back on again. Eventually, the power supplies will stop working. However, if left alone for approximately a week or so, they will power on again properly and the cycle begins again.
    What could be the cause of this issue?
  • Thermaltake
    Brain badcap
    • Aug 2015
    • 332
    • D12
    Re: Seasonic X-560 and Corsair AX650 - fail to power on after a week of use
    Have you checked inside of the PSUs if there are any strange burned things or any bulged capacitor/s ?
    • CapLeaker
      Leaking Member
      • 8196
      Check all the caps near a heat sink. They may look good, but still be high esr.
      • Quaddro
        Tukang Kentu
        • Nov 2010
        • 141
        • Indonesia
        i've found a few case like this.
        according my experience, this is can be weak pwm/apfc controller ic.
        Try to heat the ic's in primary and secondary with hot air station.
        One by one.
        • decayed.cell
          • Sep 2018
          • 11
          At a quick glance nothing appears to be burned, and no bulging capacitors
          • decayed.cell
            • Sep 2018
            • 11
            One by one.
            I think I'll just try replacing the ICs instead. ICE2QR4765Z and APW7159A
            • Quaddro
              Tukang Kentu
              • Nov 2010
              • 141
              • Indonesia
              weak ic can be cause of broken smd parts, for example smd tantalum capacitor.
              That's why i suggest to blow the ic with hot air first.
              If it working after hot air, we can make sure tantalum is the culprit..
              Just replace all tantalum in daughter board.
              If the still persist, then the ic is the source of problem.
              • decayed.cell
                • Sep 2018
                • 11
                How many degrees and how long should I heat it for?
                • Quaddro
                  Tukang Kentu
                  • Nov 2010
                  • 141
                  • Indonesia
                  According to my experience, around 300 celcius, 1 minute for each section.
                  While heating the ic and/or smd, try to turn on and off psu (connect/disconect green and black cables) until the psu working.
                  Put some load, like old hdd or anything that can act as load.
                  the section while psu working, is the main focus to reheat, 3 minutes is enough.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    The TV does not turn on, the standby indicator is on. All voltages are present.
                    Emms is dead. Not readable, not detected.
                    Replaced emmc.
                    But with another dump there is no launch
                    Terminal log
                    UART
                    AC_ON
                    RPMB key is not yet programmed
                    HASH1_VERSION=0x00000000 64bit
                    E-B
                    FDE enabled
                    layout pattern onebin by SAR7,0...
                    06-01-2025, 02:11 AM
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
