Component ID on TV UHF Amplifier PSU
  • theoregano60
    • Mar 2019
    • 8
    • U.K
    Hi All
    Can anyone help assist on id of this component (or manufacturer)from a TV UHF Amplifier
    Re: Component ID on TV UHF Amplifier PSU
    It is SMPS IC. What is the make and model of the device?
    • theoregano60
      • Mar 2019
      • 8
      • U.K
      Manufacturer: IKUSI (power supply side could be Teldis)
      Model Number: NBS-804
      Its a bit niche as this equipment is used in blocks of flats to distribute UHF TV signals
      • R_J
        • 9551
        The closest I can find, so far is a DP2360, DP2362 based on the pinout
          • 31068
          was the bits still in the device?
          • CapLeaker
            Leaking Member
            • 8199
            probably easier to put another 12/24v dual PSU in there.
            • R_J
              • 9551
              It's a Samwin SW8603
              • theoregano60
                • Mar 2019
                • 8
                • U.K
                Thanks RJ your a star
                Sorry for the lack of replies works been taking up a large chunk of time ,
                next job to try and source once again many thanks too everyone
                • CapLeaker
                  Leaking Member
                  • 8199
                  good find RJ!
                  • MrCommunistGen
                    Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                    by MrCommunistGen
                    My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                    I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                    07-12-2021, 05:11 PM
                  • jinu_j
                    How to test Subwoofer Amplifier with only a multimeter
                    by jinu_j
                    Hi Folks
                    Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                    Problem
                    I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                    Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                    Any advice would be appreciated...
                    08-29-2024, 02:05 AM
                  • UserXP
                    Mackie CR4 amplifier no sound
                    by UserXP
                    Hi, people.
                    I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                    Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                    10-17-2020, 05:06 PM
                  • mikey5791
                    Help on car amplifier only one channel works
                    by mikey5791
                    Hi all forum members,
                    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                    08-06-2025, 10:36 PM
                  • Francesc V.
                    Rotel RSX-1056 amplifier. Troubleshoot a noisy channel
                    by Francesc V.
                    Hi:
                    I've realized that one of the channels of this amplifier has no proper sound.
                    This is the signal at the speakers output.
                    As long as the audio coming in to the amplifier board (blue) looks ok although with some noise due to the wire, I think that there's nothing to look at the preamp section.
                    Now, I could start looking at components to see whether I find the guilty one.......but I would rather prefer to ask for advice. Here there is the amp. schema. Which points would you check with the oscilloscope to gather...
                    07-15-2025, 01:33 AM
