Generic power supply, how leathal is it?
  • Warbo
    • Aug 2009
    Hey I am trying to build a gaming PC on an extremely tight budget and to cut down the price alot I am thinking about getting a case and psu bundle, I would not be using the generic psu for long, around two months and I want to know the real risk of this thing exploding from playing some games like counter strike source and unreal tournament 3. This is the case I am considering, http://cgi.ebay.co.uk/COOLERMASTER-E...d=p3286.c0.m14
    The specs of the comp i am wanting to build are.....
    2.5ghz Core 2 Duo Intel Processor (maybe a slight overclock, please tell me if this is advisable)
    4gb DDR2 Ram
    N7AD-SLi MoBO
    320gb Generic Hard Drive
    XFX 9600gt 512mb Graphics
    DVD-RW Drive
    Windows XP
    Then I would also be adding another 120mm to the front of the case for extra ventilation, all this should come to around £320. Please tell me if you think I should change anything to make a better budget gaming pc thanks.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Generic power supply, how leathal is it?
    dont do bundles. usually have crap parts
    sigpic
    (Insert witty quote here)
    • Krankshaft
      • Jan 2007
      • 2328
      Beware those Chinamart bundles as previosly suggested probably crappy Chinatown parts. The fact that they use a generic HDD says it all about the quality.
      Build it yourself when you have the cash with brand name components it may cost a bit more but I will last much longer.
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        http://www.ecrater.com/product.php?pid=2865530
        Winpower 850W looks suspiciously like a solytech, like this one. Look at the last picture where it shows the bottom and rear fan.
        http://www.newegg.com/Product/Produc...82E16811119115
        They are $40 without a psu, or about £25, so its not like that psu is free with it, if it was I would have bought it and rebuild the psu to test with.
        • yanz
          • Nov 2004
          • 910
          generic psu with tiny capacitance and incomplete rail filtering, plus fake amperage rating, is the common cause of the questions from my friends, "yanz, my monitor went blinking/pc restarting/where's my C:\ ?"
          if u really have to use that generic psu (like i do, sometime), fix the rail filtering, at least. and pray something weird doesnt strike when there are minimum protection from your PSU...
          my 2 cent.
          • Newbie2
            • Sep 2005
            • 885
            4gb DDR2 Ram
            N7AD-SLi MoBO
            DVD-RW Drive
            Windows XP
            I know that you're on a tight budget for a computer, but if a generic power supply blows and kills all of your components, then you'll be spending a whole lot of money again on another computer. Generic power supplies can also cause weird instability problems when they are underpowered for a computer.
            Buy a good power supply, you probably would have to spend a little more money but it will be worth it in the long run.
            With a computer like that you're planning to build, I wouldn't risk all of that to a generic power supply that the seller bundled with the case.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Save money for as long as it takes you to get a decent PSU
              With a system like that it's just plain stupid to use a POS PSU
              Especially when you know about the problem!
              • Warbo
                • Aug 2009
                OK thanks guys, i guess ill just have to wait for a better psu. O wells
                • Phaihn
                  • Jan 2009
                  • 842
                  Or you could forgo winxp for abit and use that money for the PSU.
                  My Computer.
                  AMD APU A4-3300 2.5ghz 1mb cache
                  Motherboard GigaByte GA-A75M-S2V
                  Kingston HyperX Blue DDR3 8GB (2x4GB)
                  SB Audigy 2 ZS [B800] Sound Card
                  500GB WD Caviar® Blue™
                  1 Terabyte WD Caviar® Black™
                  2 Terabyte WD Caviar® Black™
                  • Warbo
                    • Aug 2009
                    Hey I think I can afford this one, this will be reliable right? http://www.scan.co.uk/Products/400W-...-year-warranty
                    • Phaihn
                      • Jan 2009
                      • 842
                      looks good to me but you may wait for what the others say ive seen ram by this brand ive never seen a psu made by them.
                      My Computer.
                        master hoarder
                        • May 2008
                        • 12164
                        Corsair power supplies are excellent. I don't think you'll go wrong if you get that one.
                        Also, a lot of members here have been recommending this one (but if you want to buy it and you live outside the US, make sure to contact the seller first). The only problem you might have with it is that it has an 8-pin power connector vs the standard 4-pin (hence you might need to modify it a bit or get an adapter). There's no PCI-E connector either. Other than that I've heard only good things about it.
                        • Newbie2
                          • Sep 2005
                          • 885
                          Besides what momaka stated, the Corsair power supply is very good.
                          My gaming PC:
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            yeah, corsairs are good. better than a generic s***box.
                            sigpic
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              looking at the ebay pics, the psu has thin wire. look at the pic of the atx connector. thin and crappy
                              sigpic
                              • Warbo
                                • Aug 2009
                                Thanks guys, last thing, will a 400w good power supply be enough for a XFX 9600gt 2 way SLi array with all the specs I listed at the top? or do I need to upgrade and if so to what
                                thank you all so much for your help
                                • Newbie2
                                  • Sep 2005
                                  • 885
                                  A good 400W power supply can probably power two GeForce 9600GT video cards in SLI, along with the specifications you listed. In my opinion though, I'd get at least a good 450W power supply just in case of upgrades in the future that will need more power.
                                  The eXtreme Power Supply Calculator Lite v2.5 online at extreme.outervision.com/psucalculatorlite.jsp can give you a basic idea of how many watts that you're going to need to power your computer.
                                  If you get the case on eBay UK with that generic power supply, I would suggest you keep the generic power supply for just in case you need a power supply for a lower-end computer that doesn't need as much power.
                                  My gaming PC:
                                  • i4004
                                    • Oct 2006
                                    • 2029
                                    chances of new (up to few months old) crappy psu destroying board are slim to none.
                                    chances go up after a year or so, but even then they remain fairly low, even with crappy psus(ie overall number of cases when psu kills mobo are pretty rare).
                                    offcourse, slim chances don't mean much to those that very "lucky" enough for it to happen.
                                    but i don't understand: you can't get the case and decent psu for 50 pounds(ie the price of this ebay offer)?
                                    how come?
                                    how expensive can the case be?
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      You could get lucky and have a generic power supply last for some time on the hardware that Warbo is planning on getting, but I consider that nice hardware (especially if he's going to do an SLI setup of the video cards) and in my opinion having a good power supply is good piece of mind to ensure that those nice components won't get killed by the power supply.
                                      My gaming PC:
                                      • Newbie2
                                        • Sep 2005
                                        • 885
                                        how come?
                                        It was mentioned before that the case was 25 pounds in the US, it's not a very expensive case, so with an inexpensive generic power supply I think 50 pounds total sounds right.
                                        However, it is good to do a little research on the eBay seller if possible.
                                        My gaming PC:
                                          03-31-2024, 02:12 PM
                                        • Snownomow
                                          Shock when touching power supply case (ACBel API1PC36 from PowerMac G4 MDD)
                                          by Snownomow
                                          Hello!
                                          I recently successfully repaired two Apple PowerMac G4 MDD power supplies by swapping out bad caps, per excellent info found in various threads on this forum - yay!
                                          I was doing testing on one of them, the ACBel API1PC36, with it's case open and had it setup outside of the PowerMac resting on the table with it's power connected to the system (power was also connected to a couple SCSI HDD drives, for a bit extra load). It was working fine, I shut down the system but did not unplug the PS from the power strip (and power strip was left on) so power was going into...
                                          07-30-2020, 02:20 PM
                                          07-01-2024, 06:34 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
