GQ 3151 w/ Macron model MPT-251 PS
  • tmwalsh
    • Jan 2009
    • 119
    I am not sure where this should go, so please advise.... move as necessary.
    I have two GQ's that are twins, purchased from Fry's. They both have the Macron PS. One box was getting blue screens and lockups. The other appeared normal, but it was not used nearly as much.
    I removed the power supply and immediately noticed a half dozen 2200 uF 10v capacitors that ALL appeared to have bulged tops and a brownish deposit. There were no letters or labels other than weird looking G L. The G has a short extension at the base and the L has a longer extensions. Sort of like this:
    G_L____ with a slight curl up at the very end. Marked 105C
    They also had some white material I assumed was glue to hold them in place for soldering.
    I replaced the caps with 2200uF 16v 105C caps with a H sitting on a circle or oval, which I had ordered from Acme Enterprises in FL.
    From the short life, Nov 2006 to Jan 2009, I assume the caps are not very high quality. I emphasize that the second machine, not used very much at all, probably less than 20 hours, had the same appearance as the machine use in daily basis.
    The caps I used for replacement were of a larger diameter than the originals, ~3/8" vs ~ 1/2", so they did not sit down on the pcb, and were more or less left on longer leads raised a bit from the board in some cases.
    Did I just buy a little time, or did I use decent caps. I guess if they cannot put their name on the product, it is not of high quality.
    I have not looked at the motherboards, but they are ECS model 741GX-M2.
    tom
  • Newbie2
    • Sep 2005
    • 885
    Re: GQ 3151 w/ Macron model MPT-251 PS
    tom
    I'm guessing the failed capacitors that you replaced were "Goldlink" brand capacitors. Here is the logo that the "Goldlink" brand of capacitors uses:
    Your replacement capacitors are not of a brand that is common, but with some research online, I think that you might have Chinese "Huayu" capacitors. Here is that brand's logo:
    A picture of Huayu brand capacitors:
    The link to the Huayu brand capacitor website (English): http://www.cn-huayue.com/en/about.htm
    I haven't heard anything about that brand of capacitors you used to replace your faulty capacitors.
    If your power supply is working for now, I'd say they are buying you time to get high quality capacitors from known brands such as Rubycon, Panasonic, Nichicon, United Chemi-con, and Sanyo. But since I don't know anything or have any experience regarding the capacitors that you used, if they work for a good amount of time (like a few months or a year) then I'd say they're decent for what you're using them for.
    However, if possible, I still recommend you get high quality replacement capacitors from the known brands I mentioned before.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • linuxguru
      • Apr 2005
      • 1564
      GL are known bad, no surprise there. I wonder if Huayu is related to the "Saturn" brand that is encountered frequently in cheap PSUs like Deer and Powmax, since the logos bear a passing resemblance to each other - "Saturn" is also a known crap cap.
      • Newbie2
        • Sep 2005
        • 885
        The "Saturn" brand is probably "YC" which is from "YANG-CHUN ELECTRONICS FACTORY" (no website).
        I have a "Saturn" cap, and here are two pictures of it:
        It is "TK" series I'd assume judging from the cap, and the Huayu capacitor brand I mentioned earlier has two TK series on their website, with descriptions that would sound reasonable for the "Saturn" brand capacitor I have.
        If the Chinese "Huayu" capacitor brand is related to the "Saturn" YC brand, then I would recommend that tmwalsh get good capacitors for his power supplies as soon as possible to avoid another failure of capacitors.
        My gaming PC:
        • tmwalsh
          • Jan 2009
          • 119
          Ummh, Does adding a few(6) more volts tolerance increase the longevity? I hope.
          The G_L__ symbol is right on. The PS itself appeared to have decent layout and assembly compared to the pics I saw in the other section. Just picked one(so far) bad component source.
          The symbol for the H in a circle is very close to the caps listed. It is my eyes that are so cr*ppy, but I think you are right on the money.
          Acme in FL seems to be a small organization that is responsive. They do not list their capacitor by manufacturer, so I'd guess if I want brands mentioned above, I have get another supplier.
          tom
          added:
          The H-circle caps have NO series or other marking other than a "-40+105c" imprint directly under the logo. BTW, the logo has the "R in a circle" indicating it is trademarked. If they went so far as to trademark their logo, they must 1)believe it is worth something or 2)want customers to believe #1...
          I kind of trust ACME, as their newsletter/sales flyer is plain text with no apparent bogosity. The items on 'sale' are various and are marked down from their website prices. Shipping costs are decent too. No, I don't own stock.
          acme-sales.net on the web. Low key, low budget, down to earth. Maybe I am being duped, so what's new???
          tom
          Last edited by tmwalsh; 08-08-2009, 11:42 AM. Reason: New post popped while typing...
          • Newbie2
            • Sep 2005
            • 885
            tom
            Since the original capacitors were rated at 10V, chances are they would be on either the +3.3V or +5V rails of your power supply. A capacitor rated at 16V would not be stressed on either those two rails.
            I know one supplier, Digikey (www.digikey.com), which sells high-quality Panasonic, United Chemi-con, and Nichicon capacitors.
            My gaming PC:
            • tmwalsh
              • Jan 2009
              • 119
              I have purchased from Digikey in the past with no problems. I am rounding up a list of needed caps for my herd of old RCA CTC169 chassis, and just might order from them.
              I went to the Changzhou Huayue site, and poked around. If they are truly an ISO firm, then they have a process that is documented and has been inspected for compliance. ISO compliance is not a cheap thing to get, requiring inspectors to validate process, and it can be revoked if it is found that the Co is not following the procedures. You can make a concrete life preserver and it can be ISO-9001 compliant. They document the process, not the product, but if the process is good, the product will be good too. Waste of time and money for a fly-by-night company because it is expensive and requires documentable process, not Uncle Ling Zhou adding a few extra kilos of dried goat droppings to make the batch weigh correct...
              Guess I will find out how well they do. Think I might put the Blue ESR to work again.
              tom
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Macron power supplies are usually good and worth the recaping.
                Also make sure to replace any caps that might be rated 25v 22uF, 25v 47uF, 50v 22uF, or 50v 47uF.
                If you order caps from Digikey, they have FC and FM (Panasonic), PW and HE (Nichicon), and KY, KZE, LXY, and LXZ (United Chemicon). Those are all 105C low-ESR caps suitable for power supplies.
                • jpdoe
                  • May 2007
                  • 237
                  Hi all.
                  I'm trying to learn which of the small caps present on most PSUs are worth recapping.
                  Would someone be so kind as to explain which caps is Momaka aiming at with the specs he gave? (22uf or 47uf, 25v or 50v). Are those the filter caps present on the 5vsb feedback loop Everell mentioned on another thread?
                  • Newbie2
                    • Sep 2005
                    • 885
                    Originally posted by jpdoe
                    Hi all.
                    I guess if you see little capacitors in your power supply around the values that momaka said, just replace them.
                    My gaming PC:
                    • jpdoe
                      • May 2007
                      • 237
                      Ok. I'll give it a try. It will be a good way to practice soldering.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Hi all.
                        I'm trying to learn which of the small caps present on most PSUs are worth recapping... Are those the filter caps present on the 5vsb feedback loop Everell mentioned on another thread?
                        Yes. They're usually around the 5vsb transformer or primary side next to the 5vsb transistor.
                        • jpdoe
                          • May 2007
                          • 237
                          Thanks, Momaka. I've been wondering about those caps for a while now.
                          • linuxguru
                            • Apr 2005
                            • 1564
                            It would seem that Huayu and YC (Saturn) are related entities - they have similar logos, and similar gold-on-black colour schemes, similar series (TK) and probably similar specs.
                            As has been mentioned, ISO 9001 is a process certification, and is no guarantee of product quality. They could be making concrete life-jackets, and still retain an ISO 9001 certification as long as they have the paperwork and a process for contacting the next-of-kin. These ISO certifications are hugely popular in China and other Asian companies which work on price-arbitrage - in the absence of a differentiator on the basis of product quality, they use the certification instead as a selling point.
                            • tmwalsh
                              • Jan 2009
                              • 119
                              linuxguru, can't say if they are saturn related or not. the caps i have are black in color with white stripe and lettering. looking at the site, i think they are TR, TF or TK series. I did not load the chinese character set/font, so don't know if the description matches exactly the CY (saturn) description.
                              momaka: I did not find any caps in the 22 or 47uf range and none at 25 or 50 volts. There were 4 = 10uf/50 scattered, 3 = 1uf/50 near the regulator IC and comparator IC, 2 = 220uf/16(-12v out), 1 - 470uf/16 between the heatsinkd, 6 = 2200/10(2 5v, 1 3.3vout), 1 = 3300uf/16(12v out) and 2 = 470uf/200 input caps.
                              I *think* they are all the Goldlink brand except for the 2 =470/200v, but none have gold colored markings, and there are two colors (orange and blue) for the 1uf/50v. The two 470's are Fuhjyyu.
                              I replaced the 6 2200/10's, and found that the 3300/16 is bulging at the top. I didn't notice the bulge until I had replaced the 6 2200's. The machine did not boot. The fans started to turn, and then shut off. I disconnected the HDD's, and the machine booted. That removed the 12v load. I then found the 3300 bulge, and figured that my re-cap was successful (for the 5v), but I needed to find a 3300 replacement to get the 12v back on line. This PS has likely less than 100 hours of use total, and the caps were bulged and had brown exudate on the top.
                              After reading the posts, I took the inventory of caps as noted above.
                              Would it be useful to replace all the Goldlink and Fuhjyyu caps even though they show no evidence of failure? From what I have gathered, they are likely signal cleanup rather than 'load bearing' caps. [my description...]
                              tom
                              • rolexwatch
                                • Nov 2009
                                Look at watches.
                                Look at watches. Look at watches.
                                • 370forlife
                                  Large Marge
                                  • Aug 2008
                                  • 3113
                                  Re: Look at watches.
                                  wat
                                  • dragon3x
                                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                    by dragon3x
                                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                    power on.
                                    Here are some examples :
                                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                    switching supply area).
                                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                    than 6.3 V.)
                                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                    I replaced capacitors with aluminum-polymer.
                                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                    03-21-2025, 02:46 PM
                                  • slybunda
                                    AA and AAA battery charger capacitors?
                                    by slybunda
                                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                    it has inside:
                                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                    2 x 470uf 16v LZ105c branded as G.Luxon
                                    not heard of these brands are they any good?
                                    iv attached photos of the charger and the board inside for an idea on the type of...
                                    12-24-2023, 04:41 AM
                                  • Cama
                                    Solar Inverter - SMH-II - 2 missing capacitors
                                    by Cama
                                    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                    My model is : EASUN SMH-II 7 KW
                                    Mother Board : P/N 18947-002401250250
                                    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                    Thank you...
                                    09-12-2025, 02:50 AM
                                  • Ady2017
                                    Are there any datasheets available for Elna RJG capacitors?
                                    by Ady2017
                                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                    05-25-2025, 02:19 PM
                                  • DXseekerMO
                                    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                    by DXseekerMO
                                    Hello everyone!
                                    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                    Yes
                                    0%
                                    1
                                    All backlight strips are the same quality
                                    0%
                                    1
                                    No
                                    0%
                                    0
                                    12-16-2021, 03:58 PM
