Zig X70 Caravan battery Charger Component identification
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi, there I got this battery charger in for repair. The component is all burnt so I am struggling to identify the part number I think its a metal oxide varistor but don't know its value can anyone confirm this component and its possible values..any info would be much appreciated
    Your never to old to learn
  • R_J
    • 9602
    Re: Zig X70 Caravan battery Charger Component identification
    If you remove the black heatshrink can you read any numbers? what is its board designation? is it across the a/c line?
    If not it should not be to difficult to find a replacement
    something like a 7D471K
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Thanks for your reply I removed the heat shrink but nothing is visible and yes it's across the ac line straight after the fuse before going to the rest of the board..thanks
        I would remove that blown MOV and start checking to see if anything else got damaged or not and see if the unit still working since MOV is not needed for the unit to function, it is for protection.
        If you find not damaged component then you can power it up using 100W incandescent lamp in place of the fuse and no load connected to see if come alive or not, if it does, the measure the diameter of the MOV, then it is just a meter of getting the rated clamping Voltage that is above you normal AC LINE Voltage.
        • petehall347
          • Jan 2015
          • 4440
          • United Kingdom
          is it powered from mains or generator ?
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            Okey budm i will remove it see if anything else was damaged and see if it will power up
            Petehall347 it was running off a generator as it wasn't on a caravan site to hook up too but it was my generator he used which has built-in surge protection as I use it for outside pa
            • garrymc123
              • Apr 2010
              • 336
              • United Kingdom
              I have removed the component and can just see the part number (471kd07 ) but can't find a replacement in the Uk is there a compatible replacement I can get. thanks
                Just look for 7D471K Varistor.
                7D = 7mm dia.
                471 = is the Voltage rating.
                I.E. https://irishelectronics.ie/7D471K-Varistor-Resistor
                • redwire
                  • 3912
                  The generator is the problem if it's blowing 300VAC MOV that turns on at 423-517VDC. I would check if it's working. The regulator might be pooched or it needs a minimum load, as most generators are savage.
                  For replacement, consider Epcos/TDK S07K300 (B72207S0301K101) or bigger 10mm S10K300 if it will fit.
                  • garrymc123
                    • Apr 2010
                    • 336
                    • United Kingdom
                    Thanks for the information I have ordered a new one and will let you know the outcome.
                    • stmaster3600
                      • Jul 2023
                      • 6
                      • Ukraine
                      ZIC x-80 is a similar story, but another detail burned down. Please help me determine its meaning. Thank you for any information. Highlighted in red in the photo
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        That is a high voltage film capacitor, likely rated for at least 400v and something like 1uF of capacitance.
                        Most likely it is parallel to the two large filter capacitors and it is very strange that it would fail and nothing else...
                        • stmaster3600
                          • Jul 2023
                          • 6
                          • Ukraine
                          Thank you for your time. Below are real photos of the place of the fire. Visually, no other damage is visible. Unfortunately, there is no ZIC X-80 scheme available, I have to bother you. If you need to take any additional photo, tell me which one. We really need the parameters of this part.
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Desolder the capacitor and clean the area well.
                            Then check on the underside what it connects to.
                            If it is in parallel with the two large caps you can just give it a test without that capacitor present.
                            But check first if the fuse is blown.
                            And I recommend to use an incandescent light bulb in series with the unit, for example directly replacing the fuse:
                            If the lamp turns on and remains bright you still have a big problem on the primary side...
                            • stmaster3600
                              • Jul 2023
                              • 6
                              • Ukraine
                              Thank you, I will do it. I will definitely give you the information. Please tell me, is it really not realistic to find the circuit of this device?
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Probably not possible to find this exact units schematic, but you can use any TL494 based schematic as a reference, see here for example, there are a couple TL494 schematics for AT and ATX power supplies for computers: https://danyk.cz/s_atx_en.html
                                In these schematics it looks like the capacitor that burned up is not in parallel with the big filtering capacitors, so if that is correct you will need to replace it.
                                A good starting point is probably 1uF and at a minimum a 230v rating, but much better with 400v.
                                • stmaster3600
                                  • Jul 2023
                                  • 6
                                  • Ukraine
                                  thank you very much, I will try. I'll let you know what happens
                                  • stmaster3600
                                    • Jul 2023
                                    • 6
                                    • Ukraine
                                    As promised, I share the result. A 0.63mF 400V film capacitor was installed. I turned on all the 12 V equipment of the Caravan, while the battery was half discharged. After 8 hours of operation, the battery was charged. Then I connected the compressor and pumped up the wheels of the caravan. It works! I think that everything is fine at this stage. What are your opinions?
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      Sounds good to me!
                                      It is unusual but sometimes capacitors short internally.
                                      I guess that is what happened here so that is why nothing else was damaged...
                                      • stmaster3600
                                        • Jul 2023
                                        • 6
                                        • Ukraine
                                        Sounds good to me!
                                        I think that's a bit not the reason. I didn't know about the existence of X80 in my caravan. at the time when the caravan was connected to the 240V network, I connected a separate charger to the battery terminals. P.S. it's bad not to know the device and the devices of what you use)))). Thanks again to everyone
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
                                        • flat-earther
                                          how to prevent a connected charger from draining battery when not charging?
                                          by flat-earther
                                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                          So the battery is backfeeding the charger and being drained.
                                          How can I prevent...
                                          08-07-2025, 01:04 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                          Bauer tool battery pack charging with a HERCULES charger modification
                                          by sam_sam_sam
                                          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                          05-06-2023, 12:17 PM
