VOTE: Logisys 480W vs. L&C 450W
  • everell
    • Jan 2009
    • 1514
    Re: VOTE: Logisys 480W vs. L&C 450W
    More work on my Raptor L&C 400 watt - lets see what this puppy can take.
    Capacitors replaced:
    On 12 volt line: two 1000 Mfd/16 volt Su'scon replaced with 3300 Mfd/16 volt Samyoung SXE and 2700 Mfd/16 volt Nichicon PW
    On 5 volt line: two 1000 Mfd/10 volt Koshin replaced with two 3300 Mfd/10 volt Samyoung SXE
    On 3.3 volt line: two 1000 Mfd/10 volt Koshin replaced with two 3300 Mfd/6.3 volt Nichicon PW
    Input capacitors after bridge diode: two 330 Mfd/200 volt Koshin replaced with two 470 Mfd/250 volt Samyoung SMK
    Powered up - didn't blow!
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • everell
      • Jan 2009
      • 1514
      The main switching transformer marking on Newbie2's 450 watt L&C is "EI-33 ASG". The transformer on my 400 watt L&C is marked "ERL-35-2005". Does anyone know the significance or meaning of these markings. The transformer in my L&C looks somewhat larger.
        master hoarder
        • May 2008
        • 12170
        • Bulgaria
        Not sure about the EI/ERL markings (I think those have to do something with the manufacturer), but the two digit number on both transformers is to indicate their size.
        According to CanardPC.com , a 28-sized transformer can handle up to 200 watts, while a 35-sized one can handle 350 watts or more. So my guess for the 33 one is somewhere between 250 and 300 watts (most likely 250).
        Of course the switching frequency probably plays a role in that as well. The higher the frequency, the more power that can go through the transformer.
        • linuxguru
          • Apr 2005
          • 1564
          It depends on the core material, as well. The core power loss (which is dissipated as heat in the core) depends on the kind of ferrite - and increases with increasing frequency. Generally, around 100 KHz is the about the highest switching frequency with most commodity ferrites. However, there are specialty ferrites from the Japanese majors (TDK, Fuji, etc.) that can be used up to about 500 kHz and higher, with low core losses.
          Most commodity PC PSUs with BJT switchers (which includes about 99.9% of the PSUs that are commonly encountered) switch in the range of ~40 kHz to 80 kHz.
          In my experience, 28-sized EI or EE cores (made of commodity ferrites) are rarely capable of over 135 W; 33 up to 200 W; and 35 up to 250 W. Anything higher will require specialty cores, MOSFET switchers and switching frequencies in the low 100s of kHz.
          • Newbie2
            • Sep 2005
            • 885
            everell's Raptor 400W power supply appears to a high-end L&C power supply in my opinion:
            It has a proper input filtering stage (coil, X cap, two Y caps, and an MOV) along with an actual bridge rectifier. It also has larger heatsinks than the typical L&C power supply. There are power inductors on the secondary side along with a proper amount of capacitors installed. I don't find it surprising that a larger transformer was put into it too.
            It doesn't look like it has the common "Y-B200ATX" PCB design of many L&C power supplies, but everell's power supply is no doubt built very well from the factory. I guess it can put out a reliable 300W or slightly more.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              #26
              linuxguru: thanks for the info, it was really helpful.
              So to my understanding from your post, those higher-end 400-700 watt power supplies that use a single transformer only, probably use a specialty ferrite core and higher switching frequencies (and this is why they get higher efficiency as well) - or did I get that wrong?
              Also, given the same transformer using a regular ferrite core, would a MOSFET switcher be able to get more power through it than a regular BJT switcher?
              I feel like I know some of the basics of SMPSs but there's probably still a lot more to learn. Again, thanks for all the info.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                that looks like my allied 350w i will recap soon...
                sigpic
                (Insert witty quote here)
                • linuxguru
                  • Apr 2005
                  • 1564
                  #28
                  The good 300 W to 400 W units (say Delta or Hi-Pro) have fairly large transformers - even in 35 size, they tend to be taller. This allows better heat dissipation, even with commodity ferrites.
                  A MOSFET can switch faster than a BJT, allowing higher switching frequencies - in the 80 kHz to 300 kHz range. In conjunction with better ferrites, shielding, output rectifiers and capacitors, this helps in the design of higher power PSUs with comparatively compact transformers. However, the relatively low margins in the PC PSU business don't easily permit the use of specialty/premium components for high-volume products.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3112
                    Looks like my 500W rosewill but with smaller heatsinks, smaller input caps, and less transient filter. My 500W rosewill/allied also has a little pcb above the ac receptacle that has a couple of Y caps, a coil, and maybe a X cap, can't remember.
                    • Newbie2
                      • Sep 2005
                      • 885
                      From this I see that Deer/L&C/Allied/Solytech can produce a decent good power supply when they put the proper components into a power supply, since their designs aren't bad at all. Also, looking at the Rosewill Stallion Series power supplies on Newegg they are reasonably priced too if someone is serious about saving some money on a computer power supply.
                      In fact my favorite power supply manufacturer for budget and lower cost power supplies is Deer/L&C/Allied/Solytech, after a good recap (I'm not a fan of the Jun Fu, "Saturn" YC, G-LUXON, HERMEI, Canicon, and other cheap Taiwanese capacitors they use) their decently-made power supplies are great for many computers up to the mid-end level.
                      My gaming PC:
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        G-luxon has been bought by teapo not too long ago. There are many series of g-luxon's that are rebranded teapo's.
                        That picture of my rosewill solytech build is a stallion series 500W.
                        JG did a review of the same model, but the allied/apex version. It was too labeled as 500W. It only did 350W before the primary side blew. The secondary side was up to spec with the rating, but the primary couldn't supply the needed juice to get more than 350w. Other than that though, the ripple was actually very well regulated, and it didn't get that hot. If i recall, the 5v was very stable due to having 60A of capacity on the secondary for it.
                        Rosewill tech support is pretty down to earth, when I read that review on jonnyguru I was a little afraid because they are based on the same design, and have all the same parts except the apex/allied had asia-x caps, while the rosewill has all YC. Anyway, I sent them that link in the email, and asked them if that would happen to my psu if I put it under a heavier load. They said that when they order them they order them with a higher rated primary side, as well as "higher" grade capacitors. Don't know how much of that was BS, but it was nice to see a tech support say something other than "sorry, I not know how use compooter"
                        • Newbie2
                          • Sep 2005
                          • 885
                          I saw that review some time ago, and I'd say that power supply in the review would still be respectable for something that doesn't need say more than 300W of power.
                          I don't think YC is "higher" grade compared to Asia-X since they're both cheap Taiwanese/Chinese brands of capacitors, but technical support wouldn't know anyway.
                          My gaming PC:
                          • 370forlife
                            Large Marge
                            • Aug 2008
                            • 3112
                            I just wonder if you could order some higher capacity stuff for the primary side and replace it.
                            Then there's the question of the transformer, it is labeled as a 35, but can it do 500w?
                              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                              by momaka
                              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                              And a shot of the label:...
                              01-26-2022, 03:26 AM
                            • bauto601
                              KDM 480W PSU upgrade succes! (opinions?)
                              by bauto601
                              Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                              A "nice" YoungYear unit? - Badcaps
                              The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                              12-26-2023, 03:05 PM
                            • AdrenalinTL
                              450W PSU capacitor Identification and where to get another one?
                              by AdrenalinTL
                              Howdy peeps.
                              Can someone tell me where to get another one of these? google doesn't seem to have a 560uF and I am still quite a newbie to the whole world of electronics so trying to learn as I go. The one to the right of this pic is definitely swollen. PSU does random shut downs / no power on etc
                              Also, can it be replaced with a higher uF cap ? Same voltage?
                              Thanks...
                              12-11-2024, 02:20 AM
                            • harp
                              Learning with ATX CHIEFTEC 450W PSU
                              by harp
                              I have a little question regardless a way to repair ATX power supply CHIEFTEC MODEL: GPS-450AA-101 A. It is 450w power for computer.
                              The psu has initial short on +5VSB (purple), and I found and replace shorted diode SB340. After replace, unpowered measurement of all outputs seems fine. All other big double diode on heatsink are ok in secondary side. I connect psu with 60w bulb in serial, and bulb shortley flash as it would be. There is steady 5.2v on +5VSB and PS-ON, on any other is nothing, like 0.00v. So the primary is ok, right?
                              But, when I PS-ON (green) connect, bulb...
                              06-17-2022, 05:04 PM
                            • ntoskrnl
                              [FIXED] XFX Core Edition Pro 450W ticking noise
                              by ntoskrnl
                              My XFX Core Edition Pro 450W power supply started making a weird ticking noise some time ago. Eventually, I figured out what the issue was, and managed to fix it. I purchased this unit back in 2012, so it's an old model, but I'm still posting this in case someone finds it helpful or interesting.
                              THE PROBLEM
                              The power supply started making an irregular ticking noise when running, but would otherwise work perfectly fine. The issue would sometimes come and go. A Google search for "xfx core ticking" found multiple other people reporting the same issue, so I assume this...
                              04-19-2022, 10:36 AM
